Quick Question..How do I adjust the crossfader settings.. VDJ v6.01 or at least default the crossfader settings back to default..Thanks :)
geposted Thu 10 Sep 09 @ 5:54 am
just go into (conif) then click on options.... then set it to 3.9 or 4.0 this should work...you also can move it up or down..to set it where you prefer.. good luck!!
geposted Thu 10 Sep 09 @ 6:44 am
