Hello has all, I make a first attempt for the skin v-mix 6.0 of DJ FORMAT. I have to work quite some time above. If there is an error or a lack which you would see fit to have without modifying (too much) the bmp, made the I to know about this post
The skin is available under the image.
https://virtualdj.com/addons/9174/V-Mix_6_0.html
pasco123
pasco123
geposted Thu 10 Sep 09 @ 5:32 pm
It does not show.
geposted Fri 11 Sep 09 @ 8:24 am
New Beta 1.1 will be available soon.
geposted Fri 11 Sep 09 @ 8:32 am
Hi!
I hope you can add a "scratch" panel. At present this version does not exploit new features of Vdj 6.
geposted Fri 11 Sep 09 @ 11:36 am
im working for a new scratch pannel
geposted Fri 11 Sep 09 @ 9:49 pm
mmmhh...why orizzantol position?
not better to be in the mixer zone?
I think that 2 waveform must be near to make better comparisons.
geposted Sat 12 Sep 09 @ 4:28 am
yes i work for a center pannel
geposted Sat 12 Sep 09 @ 7:35 am
watch update
beta 1.2
version beta. need your help for suggestion
beta 1.0 - first test
beta 1.1 - 4 corrections
beta 1.2 - ad skratch pannel
- new option with automix button
pasco123
beta 1.2
pasco123
geposted Sat 12 Sep 09 @ 8:10 am
in my opinion it is unnecessary to have a waveform in deck zone....
geposted Sun 13 Sep 09 @ 12:32 pm
I understand, but as I had already created him, I decided to leave them.
If it can be of use to somebody, then...
But if you has the other ideas, lets you go.
Do you like the skin at the moment??
geposted Sun 13 Sep 09 @ 2:12 pm
good work pasco !!!
@hackid: nel + ci stà il -
geposted Sun 13 Sep 09 @ 7:01 pm
thanks
geposted Sun 13 Sep 09 @ 9:45 pm
good work pasco123
geposted Mon 14 Sep 09 @ 7:51 am
hey!! hi format you are here???
thanks for compliment
geposted Mon 14 Sep 09 @ 11:33 am
I love this skin.
geposted Mon 14 Sep 09 @ 1:52 pm
see
geposted Mon 14 Sep 09 @ 1:53 pm
that is ok m8
geposted Mon 14 Sep 09 @ 3:06 pm
I have a special request :
I would like see name of cue points featured and not just the passage of mouse on.
This is very important for me....
I use cue point to know intro and outro of all my videos. I named all cue point 1 for example "loop 8" or "voice" or "instrumental".... and same thing with cue point 2 set at the end of the video...
sorry for my bad english :(
geposted Tue 15 Sep 09 @ 12:54 pm
Yes, saddened, it is an oversight. had modified him on the panel center plant. Now, wait for the nex updated beta 1.3, panels are ready
a+
a+
geposted Tue 15 Sep 09 @ 10:06 pm
No pasco...
I no want change pannels to have other info...I would like to have all most important info on only one screen....
an example of my idea :
geposted Wed 16 Sep 09 @ 6:33 am
