Can anyone help me with some mapping. I currently have the mapping below and it maps the loop_move to the jog wheel on the same side as the pressed button. I would like to have the left jog = loop_move and the right jog = loop_length while_pressed. Thanks for the help fellas.
wheel_mode "loop_move" while_pressed
geposted Fri 11 Sep 09 @ 2:08 pm
bump ???? any answer ?
geposted Tue 22 Sep 09 @ 12:54 pm
This is the way I got this to work, not exactly the way I would have liked it but it works...
Any button = set $loop while_pressed
Jog Wheel = var $loop ? loop_length :
While the button is pressed, the jog wheel on that side will adjust the loop length.
Thanks to SP33DJr for the help!!
geposted Fri 02 Oct 09 @ 2:53 pm
