last nite in the middle of a gig one of my s1200 got disconnected. I had to restart both s1200 and vdj 6.0.2. to get it up back. any ideas??
geposted Fri 11 Sep 09 @ 5:56 pm
change the pc screan resolution use 1024x768 the same the skin vdj 1024x768,or try disable the camera from pc,i have 2 denons1200 y use 7 hours & work perfect w my laptop,long time ago i have the same problem,now i dont have any problem,djio make that problem,or total control,i dont use anymore total control or djio,now i use the same sound card denons1200,u are use for video or music,y use olny for music now,i use the same vesrion 6.0.2.
geposted Mon 21 Sep 09 @ 10:04 am
will check my resolution and see if that helps
thanks Selvin
thanks Selvin
geposted Tue 06 Oct 09 @ 5:02 pm
