hey wasup uhm i just bought simple stanton turntables and mixer cost bought 500 so there beginner turntables uhm i want to become a dj but so far i no nothing bout how to really be a dj im only 15. ive mixed songs on virtual dj but not good just messing with effects there just me messing around there not good..but the more i watch videos of real DJ's the more i think im not going to be good at it at all so if u have anything thing to help explain things to do....good songs....uhm anything really.......and another question what type of cable to i need to hook them up to my laptop so what i do on the turntables happens on virtual DJ....thank you
geposted Sat 12 Sep 09 @ 12:48 pm
How to be a dj
1 - Find someone that is in the business and that can point you in the right direction.
2 - Only pick up good habits, meaning no pirated music and/or software, this will show that you are being professional and serious about your work and you will earn respect from club owners and fellow djs.
3 - You don't have to start with expensive equipment a simple setup will do.
This is the setup im using right now, its very reliable, good quality, and reasonably priced.
i suggest you start with something like the Hercules RMX, it comes with a legal copy of virtual Dj and you can add more equipment as go.
To connect turntables/ CD players to your computer you need a sound card with 2 Inputs and 2 Outputs, the RMX will work as a sound card and a mixer at the same time.
PM me if you have anymore questions, Cheers!... OH wait you are only 15, no cheers, no cheers.... lol
geposted Sat 12 Sep 09 @ 2:52 pm
how much were thoes
geposted Sat 12 Sep 09 @ 2:54 pm
The Hercules RMX will cost about $300 to $400, Turntables are about $300 each
geposted Sat 12 Sep 09 @ 2:56 pm
o well i got stanton turntables and mixers i think there pretty good but idk.. once i get tht wire to hook up my laptop to em i can play any song from my coumputer and lik idk strach on the turntables and it would do it to the song right??
geposted Sat 12 Sep 09 @ 3:35 pm
your just joking around right?
Maybe you should search youtube for dj am videos then you can be awesome.
geposted Sun 13 Sep 09 @ 2:56 am
Thats not quite how it works mate.
If you want to use your Turntables to control music on your laptop you need to have a special sound card which provides at least 2 stereo inputs and 2 stereo outputs and a special type of vinyl disc (called Timecode Vinyl). The disc has a code on it which is read by VDJ software but it must pass into the sound card first.
The code controls starting stoping and speed/pitch/tempo of the track you are playing on the computer.
There are lots of helpfull posts on this forum that will help you set this up.
Daz
Daz
geposted Sun 13 Sep 09 @ 7:44 am
In other words, you cannot control the music with your turntables without a sound card and "Time Coded Vinyls".
Many recommend this card. You must connect this card to your computer through a USB port. You then connect your turntables to this card through the inputs and then to the mixer thought the outputs.
So your setup will look something like this.....
geposted Sun 13 Sep 09 @ 10:47 am
how much does that cost??
geposted Mon 14 Sep 09 @ 8:53 pm
under $100 look in ebay for MAYA 44
geposted Mon 14 Sep 09 @ 9:55 pm
k ty
geposted Tue 15 Sep 09 @ 9:47 pm
Ca I use RMX as a sound card?? I was thinking to use 2 cdjs and 2 turntable + xone s2
if I use turntables Timecoded using RMX as a soundcard, do I have to use 2 channel in the mixer?
geposted Fri 08 Oct 10 @ 9:25 am
