I recently tried to install 6.0 and it worked horribly, so I uninstalled and decided to go back to 5.2. Now for some reason my database won't save. Everytime I open VDJ my database is gone and and I have to add my drive to the DB again. I checked where the database used to be located and no database is ever created when I add my drive.
Any Help is appreciated, thanks.
geposted Sat 12 Sep 09 @ 2:59 pm
same for me : the application was Read Only for System. now work great
Ed
Ed
geposted Sat 12 Sep 09 @ 3:19 pm
system and admin are read and write, but it still won't save. also in the "browser" section of the config menu, under the database window, the "drive" line is empty and it wont let me select something, I dont know if that has anything to do with it
geposted Sat 12 Sep 09 @ 6:04 pm
uninstall and reinstall should create a new database file and resolve the problem
geposted Sat 12 Sep 09 @ 6:17 pm
How do you properly uninstall on a mac? I have been just deleting it from the "applications" window in the finder window and then emptying the trash.
geposted Sun 13 Sep 09 @ 11:08 am
dowload an application called "appzapper" then drag and drop the VDJ into it and that'll do the trick.
geposted Sun 13 Sep 09 @ 12:10 pm
I did this twice still to no avail. No database file is being produced. Are there any people from atomix that could help me out?
geposted Mon 14 Sep 09 @ 12:36 am
As SpinnaJ says - this was my next point of call.
Run the uninstall in appzapper then delete the preferences file (as spinna said)
Then do another install. If if still isnt there then i am stumped.
geposted Mon 14 Sep 09 @ 5:24 pm
By preference file I assume that you mean the "Virtual DJ" folder that resides in "Documents." I've done this every time I've uninstalled and still no good. Thanks for your help anyway.
geposted Mon 14 Sep 09 @ 9:16 pm
Hi jaygabs, it is not that.
Follow the step to where to find the preference file at the above post by me. Have you tried it?
geposted Tue 15 Sep 09 @ 4:32 am
SpinnaJ FYI for the forum - for some reason, when I'm on mac os at home I cannot see your first post in safari. But when I'm running boot camp windows at work, I can see it in internet explorer. Very odd, right?
geposted Tue 15 Sep 09 @ 11:27 pm
scratch that, after posting that your post popped up - still really weird. Anyway...I tried looking for that preference file and couldn't find it, so I think appzapper got it. any other ideas??
Thanks again for your input guys
geposted Tue 15 Sep 09 @ 11:34 pm
I figured it out. As Edzz0 said, but I had to make the Virtual Dj Documents folder Read and Write, not the application. Thanks for everything!!
geposted Thu 17 Sep 09 @ 11:50 pm
Im having the same problem..How do you make the virtual dj read and write?
geposted Sun 11 Apr 10 @ 4:44 am
