Just looked and cant find jp's his mapper?
does it not work on vdj? is it worth resinstalling the old vdj and installing is mapper?
geposted Sun 13 Sep 09 @ 10:38 am
Hi JPBoggis is working on a new mapper I think. unfortunatly it does not work on newer versions of Virtual DJ to keep using it you will have to go back using 5.2 and wait till he's ready to post new version of mapper. I am still running 5.2 as I love the mapper and it works very well for me.
geposted Sun 13 Sep 09 @ 12:18 pm
i hav had to wipe me computer, need to download the 5.2 and the jp mapper for it? where can i find it on ere?
geposted Sun 13 Sep 09 @ 1:03 pm
unless you have 5.2 backed up on a CD the only other way is to send a support ticket to the team. the jpboggis mapper is available still on the tools & drivers section of the site. Good luck
geposted Sun 13 Sep 09 @ 1:18 pm
jp's mapper aint there any more :(
geposted Sun 13 Sep 09 @ 3:18 pm
thanks for tht, did'nt appear on mine???
VirtualDJ v5.2 where can i get that?
geposted Sun 13 Sep 09 @ 5:33 pm
You have to contact support to get older versions.
geposted Sun 13 Sep 09 @ 6:26 pm
CI NEED HELP PLEASE MY HC4500 WORKS REALY GOOD ON VDJ 5.2 AND J.P.Boggis Denon DN-HC4500 Custom Mapper v1.3 BUT ON VDJ 6 NO RUNS GOOD HOW CAN CONFIG A1 & A2 TANKSSSSSSSSSSSSSSSSSSSSSSSS
geposted Fri 06 Nov 09 @ 8:48 am
Use the mapper window to view existing assignments and to change them.
geposted Fri 06 Nov 09 @ 10:08 am
Custom mappers should only be available to licenced users.
geposted Fri 06 Nov 09 @ 10:11 am
They are only available to Licensed Users ... what you are clearly seeing is someone tipping their hand and showing the fact that they are a crack user and has aquired the software and mapper illegally.
geposted Fri 06 Nov 09 @ 10:17 am
