help vdj is keep closeing down when I'm using the xfade effects help !
geposted Tue 19 Apr 05 @ 6:45 pm
Open program file-vdj-effects....and remove that plug in
Andre
Andre
geposted Wed 20 Apr 05 @ 8:39 am
Remove my plugin??
Yes you're right but it's not nice to tell me that lol
What is exactly the problem with my plugin? Explain me what you do, if you use it with the DJ Console and if there is a bug inside, i will try to correct it. Go to the plugins section on this forum to explain me the issue. I prefer
geposted Wed 20 Apr 05 @ 7:22 pm
