Im using the trial of VD6 with the VDJ 6 skin & notice there is no loop buttons to instantly loop by 2 4 or 8 beats etc at any point in the song as you can on the VDJ 5 skin. Is there any way of getting this on the VDJ 6 Skin?
I have been using VDJ 5 on my brothers laptop & the instant loop buttons are very handy.
Just wondered if this is possible before I purchase
Thanks
Thanks
geposted Mon 14 Sep 09 @ 12:49 pm
Yes I remember remember seeing a code for an automatic loop when I was working on my mapper a few weeks ago.
geposted Mon 14 Sep 09 @ 2:05 pm
you can either add some in with some knowledge or keep using the v5 skin ;) or even setup a mapping shortcut
geposted Mon 14 Sep 09 @ 2:15 pm
Depends which skin you use as to whether they are there. The widescreen and hi-res skins have predefined loop buttons rather than a loop size select.
Of course, you can always map your own shortcut. "loop 4" should be self explanatory.
geposted Mon 14 Sep 09 @ 4:00 pm
Thanks for the reply's, really helpful. Where do I go to find out on how to map this shortcut in or whatever I have to do to addd this in a skin?
Thanks
Thanks
geposted Tue 15 Sep 09 @ 11:33 am
