Forum: Old versions
Topic: ClipBank, some video not playing.....
some users mentioned this before
but couldn't find any answers
all videos play on VDJ's decks without any problems,
but some do not play in the ClipBank
everything up to date, latest direct x, visual c etc...
does ClipBank use VDJ's internal video codecs, too, or ... ?
is ClipBank "supposed" to play "all" videos, that play on VDJ's decks, no limitations at all ... ? (for the teamers, just curious)
thanx,
matt
geposted Wed 16 Sep 09 @ 3:10 am
Clipbank doesn't use VDJ's internal video decoders because it's a plugin; it doesn't have access to the decoders.
try converting one or two files to mpg2 if their not already and see how they go.
already tried different formats(mpg2, avi, mp4...)
should i install one of the latest codec packs ?
would ffdshow be fine ?
klite is usually the most popular to recommend.
I met similar problem but i solved it!
All pathnames to your videos must contain english (latin) characters only!
For Example:
E:/Video/file.avi
Surely, the name of file must be in english too.
Sometimes this rule is to audio files also.
For Example:
E:/Video/file.avi
made a few tests
and i think you're right
funny...
well...
it would be nice if a mod. can add this to the "bug" list
thanks
I met same problem but Rafinade solved it!
For Example:
E:/Video/file.avi
Rafinade, Thanks to you
Hope they fix this in the next update!
