Just want to know if there is a plug in or anything elase that would let me use a mic with virtual dj. I want to use a controller but very few have a decent mic input. Is there any plan to make a mic input part of virtual dj. thanks in advance
geposted Wed 16 Sep 09 @ 7:57 am
You can always look into something like the Alesis Multimix 8 USB. Once it is connected you will need to set it up in the Windows OS. But is works great, has four XLR Mic inputs, and sound quality.
geposted Wed 16 Sep 09 @ 8:17 am
Many thanks for the reply, really appreciate it. I was thinking more along the lines of the vestax VCI300 ie a controller ith a good mic input with 3 band eq and gain. I believe that there is a problem using the mic on this in the form of a delay when you talk. Can anyone throw any light opn this. Thanks
geposted Wed 16 Sep 09 @ 10:29 am
I own a VCI 300, have yet to get the mic to work right though (I am still playing with it though). If you are wanting to broadcast, I also own an RMX. It works great for broadcasting with a mic via VDJ. If, your just looking to use a mic PA style with VDJ any sound mixer like this one would work better than any controller mic input would work.
geposted Wed 16 Sep 09 @ 10:49 am
