I will try the post here.
Just to open up VDJ and have it do nothing is running 30% CPU power. When I exit the program it goes down to 0% CPU power. What on my laptop is causing this. I have all the services off and it is tweaked good.
geposted Wed 16 Sep 09 @ 7:04 pm
What "skin" are you using, and what is the screen resolution of your laptop set at?
geposted Thu 17 Sep 09 @ 11:42 am
I am using a skin called Multi Functions that I downloaded.
My laptop resolution is 1024 X 768
I tried other skins but they all ran the same CPU at 30% with nothing going.
geposted Thu 17 Sep 09 @ 1:26 pm
You don't need to open another thread on the same issue, I'll lock this one since the other one already has 20 posts.
geposted Sat 19 Sep 09 @ 5:40 am
