Does the Rane MP4 move the fader on the VDJ screen? Mine does not move on the screen.
What is the best sound setup with the MP4 mixer?
geposted Wed 16 Sep 09 @ 7:18 pm
Anyone know the answer if the Rane MP4 fader moves the fader on the VDJ screen?
geposted Thu 17 Sep 09 @ 8:00 am
No it does not.
geposted Thu 17 Sep 09 @ 8:14 pm
Is there a way to map the MP4 to control the VDJ crossfader through Midi? Does VDJ have any plan on ever including MP4 in sound config options?
geposted Tue 24 Nov 09 @ 3:49 pm
I can't see anything in the MP4 overview to suggest it supports MIDI - if it does, it would be plug and play...
geposted Tue 24 Nov 09 @ 4:41 pm
No it is not supportable ... it is tied to the SSL software.
geposted Tue 24 Nov 09 @ 6:22 pm
SSL Support indicated that the auto start controls were HID coding in the software. Is this a Proprietary issue?
If I'm looking to have fader start controls, would Denon DX0500/900 be my best alternative since I already have HC4500 controller?
geposted Tue 24 Nov 09 @ 8:00 pm
Yes those would work for what you are lookin to do.
geposted Fri 27 Nov 09 @ 6:31 am
