I'm trying to get my VDJ skin Play buttons to replicate my Dac2 play buttons but just cant seem to get it to work. The code for the mapper for the play LED is:
loaded ? play ? automix ? blink 700ms : on : blink 1000ms : off
The result is slow flashing if paused, faster flashing (In time with the cue led) when automix is active on that deck, Off if not loaded, and on if just playing.
All I could work out for the skin that everything needed to be preceded with "deck 2" but everything I tried would not work for me, as I am not very script strong!
Im guessing the code for the cue button will be simpler... Current mapper code is:
automix ? blink 700ms : cue ? on : off
I sort of understand how vdj script works, but not quite weel enough to work out the path that the complex scripting uses.
Thanks in advance
Kym
geposted Thu 17 Sep 09 @ 12:56 am
Pleeeaaasseeee... ;-)
geposted Tue 22 Sep 09 @ 1:01 am
I think your answer would be easier found if you post in the Hardware Forum. This is the Skin Forum and allthough some of the skinners use a liitle VDJ Script the ScriptMAsters have helpled a lot of users in the Hardware Forum. Try there.
geposted Tue 22 Sep 09 @ 3:19 pm
