How do you load a preset. ?
geposted Thu 17 Sep 09 @ 3:35 am
geposted Thu 17 Sep 09 @ 6:56 pm
A preset for what ?
geposted Thu 17 Sep 09 @ 10:25 pm
for virtual dj
geposted Fri 18 Sep 09 @ 12:04 am
geposted Fri 18 Sep 09 @ 6:48 pm
when your in VDJ and you are in configuration and in mappers, in the old Virtual dj you just loaded the preset XML but...
How can you do this. Thanks if someone can help.
Lee.
Lee.
geposted Mon 21 Sep 09 @ 11:50 pm
The mapping engine was changed in VDJ6; there are no longer "presets" as such, just MIDI mappings. These are stored in files in the Docs\VirtualDJ\Mappers folder.
geposted Tue 22 Sep 09 @ 5:03 am
ok thanks.
Yes but how do you load them.
geposted Tue 22 Sep 09 @ 6:43 pm
As I said in my previous post, you don't load mappers any more. VDJ automatically loads the relevant mapper from the above folder for you when the device is detected.
You can't load older XML versions; as I said the mapping engine is completely different now.
geposted Wed 23 Sep 09 @ 4:15 am
I didn't know. Thanks.
geposted Wed 23 Sep 09 @ 4:22 am
geposted Wed 23 Sep 09 @ 4:25 am
