I fellow Dj and licensed user of Virtual DJ came to me with an issue when he is using Karaoke files and Mac. The are all zipped files
His system - MacBook Pro 13inch 10.5.8 & VDJ 5.21
Mine iMac 10.6.1 and VDJ 6.0.2 & Mac Book Pro 10.5.6 and VDJ 5.2.1
All of these machines are experiencing the same issue with Karaoke
The files read correctly for a few minutes then you loose them, u can search for the karaoke files and select them but VDJ crashes when the they are selected. More importantly why are the files no longer visible when the should be in their folders.
To recreate, click on the left browser and use the arrow keys to go up and down folders of karaoke songs, after s short period of doing this the songs will stop displaying.
I could not believe it when I saw it first.
Things that I have tried,
-verify disk
-repair permissions
-readded the karaoke folder
When you re-launch VDJ the files return
Can someone offer some assistance
-verify disk
-repair permissions
geposted Thu 17 Sep 09 @ 6:16 am
This problem has been there for a while now.
I havent tried it with 6.0.2 yet, as i havent had a need to plug my KJ drive in.
geposted Thu 17 Sep 09 @ 8:05 am
Your kidding me and it made it through a major point upgrade version 5 - 6, thats unbelievable.
geposted Thu 17 Sep 09 @ 8:25 am
My Support ticket when i first had this problem - (check the dates out)
Date: Wed 14 Jan 09 @ 1:49 pm
Message: I am having problems with VDJ picking up my karaoke files.
I have the files in ZIP files but sometimes virtual dj will find them during a search and other times it wont.
There seems to be no pattern with it.
_________________________________
Date: Thu 15 Jan 09 @ 3:11 pm
Teamer: cstoll
Message: Suggest you re-add the files to the search database.
This is an issue that has been reported to the developers for resolution in the next update.
Teamer: cstoll
geposted Thu 17 Sep 09 @ 8:29 am
Here I took a screen capture of this happening
[youtube]http://www.youtube.com/watch?v=9ILk1VYdgpw[/youtube]
geposted Thu 17 Sep 09 @ 8:33 am
Here is the link to the video im not sure if i posted that correctly
geposted Thu 17 Sep 09 @ 8:36 am
Yep thats exactly what happened to me.
VERY frustrating that it still isn't resolved. I assume you're using 6.0.2??
geposted Thu 17 Sep 09 @ 8:44 am
Yeah 6.0.2 and 5.2.1 dont work
geposted Thu 17 Sep 09 @ 8:53 am
