Hey i was just wondering what is the difference between a MIDI I/O sound card and one with out it?
Because the Audio 4 dj does not have MIDI I/O but the Audio 8 dj does. Whats the difference?
Wanting to know this because i am trying o figure out what sound card to buy
thanks =?
thanks =?
geposted Thu 17 Sep 09 @ 4:52 pm
MIDI DIN 5 Inputs & Outputs are usefull if you want/need to connect MIDI devices (samples, controllers,etc) and link them together.
However, if you are not using such devices, you don't need them.
geposted Thu 17 Sep 09 @ 8:17 pm
Well i am using midi controllers and midi mixers but i don't need to hook that up to the sound card right i just hook them up to the computer running VDJ. Right? Wrong? I mean i can get the audio 4 dj sound card and still use it with midi controllers even tho it does not have MIDI I/O because i just hook up the midi controller to my computer running virtual dj.
So a sound card with MIDI I/O you can directly attach to the sound card?
A little confused help me out
Thanks =?
Thanks =?
geposted Thu 17 Sep 09 @ 10:58 pm
It's for connecting MIDI devices that don't have their own built-in MIDI interface.
Most DJ MIDI controllers have their own built-in USB MIDI interface to make them plug & play, so a separate MIDI interface is not required.
geposted Fri 18 Sep 09 @ 12:29 pm
ooo ok thanks
geposted Fri 18 Sep 09 @ 1:40 pm
