Any recommendations?
geposted Fri 18 Sep 09 @ 9:30 am
Alot of people on here will tell you not to use them but from my own experiance i have never had a problem with them and have always used them due to never having enough usbs on a laptop.
I have been using a Trust 4 Port USB2 Powered Hub HU-5440 for around 2 years and never had a problem with it.
geposted Fri 18 Sep 09 @ 10:43 am
Rob is correct. There is absolutely nothing wrong with using a hub as long as it has it's own power source. Some periphery requires a direct connection though such as my Rane Serato SL3. But everything else runs flawlessly.
This is the one I'm using. I bought it at the Guitar Center...
http://www.belkin.com/IWCatProductPage.process?Product_Id=158910
http://www.guitarcenter.com/Belkin-Hi-Speed-USB-2-0-7-Port-Hub-102575776-i1442110.gc
I run my CDJ-400s from it as well as 3 external hard drives, my Akai APC40 for Ableton, USB wireless mouse & external keyboard, and one extra port is left for whatever.
These units are stackable so you can add another one to it for more ports if needed!
DJ RuDe
DJ RuDe
geposted Fri 18 Sep 09 @ 12:21 pm
