I am currently trialing Virtual DJ 6.0.2, everything works find i can play videos and cdgs, on my compaq r3000 with 9000/9001 igp. but when it comes to video plugins i can not for the life of me get them working i am using windows xp.
I have updated all my direct x drivers. Any solutions if i am going to buy a product i need to work. The machine use it on only has 3 programs on virtual dj, torq.
If i can find solution i will have to use swift elite as there plugins work.
geposted Fri 18 Sep 09 @ 11:19 am
when selecting a plugin did you remember to activate it, usually a bluish box in centre of browser window.
geposted Fri 18 Sep 09 @ 2:52 pm
Be sure to use the hardware acceleration for videos.
geposted Sat 19 Sep 09 @ 4:17 am
You'll have to be a bit more specific;
What plugin?
What happens?
Any errors?
All the plugins available work...
What plugin?
What happens?
Any errors?
geposted Sat 19 Sep 09 @ 5:27 am
I have a similar problem with video:
Effect Video clipbank doesn't work, there are 16 windows for videos but i can't put any video to them, error message appears...
geposted Sat 19 Sep 09 @ 6:07 am
see if this helps
remember to have your vids stored where they are accessable for clipbank as they need to be in the same location each time you open up VDJ
geposted Sat 19 Sep 09 @ 6:28 am
Usually it works so, but now only "Clpbank OLD" can work properly...
geposted Sat 19 Sep 09 @ 10:01 am
