I have downloaded and used Text2. Problem is when I activate this effect I am unable to type anything in the search field. This sometimes happens with Text also.
I am usiing 5.2 , how can I fix this.???? I have tried 6.2 but I could not get my DMCc and Hercules controllers to act the same way, so I am back to 5.2.
geposted Fri 18 Sep 09 @ 1:23 pm
This problem has never been corrected but to get your keyboard to type again you either click your mouse somewhere on the vdj skin or open a note pad and type a letter and voila your keyboard will work in the search field again. I can only use note pad the other way doesn't work for me. I just leave notepad open in the background it doesn't take any resources away from vdj
geposted Fri 18 Sep 09 @ 2:15 pm
Thanks,
The Notepad worked for me. Clicking anywhere on the VDJ skin did not work. Wish someone could fix this bug.
geposted Fri 18 Sep 09 @ 2:25 pm
It's not a bug but a question of focus on windows. Indeed, these plugins have their own window so as you would do it with a software you have to click on the skin to switch the windows
geposted Fri 18 Sep 09 @ 2:54 pm
