Topic: Pitch Reset- extend time???
Hi does anybody know of a way to increase the time that the pitch reset works as sometimes its a bit harsh and the object is so that it doesnt notice when a track is playing....
geposted Sat 19 Sep 09 @ 9:28 am
This will have the answers you are looking for:
https://virtualdj.com/wiki/VDJscript_verbs.html
pitch_reset : slowly brings the pitch back to 0%. you can specify the speed in % per second (default 1% per second): 'pitch_reset 5%'
So just create a hotkey or something and give it a small value for pitch reset like 'pitch_reset 0.3%'. In VideoVision I used a low value like this on the pitch reset button for gradual changes, and for rightclick I used a high number for quick resets.
Ok got it but how do i change the pitch value by 0.3%. i tried to set it up in the mapper but no ption to change the value
Do you use the pitch reset in skin (with mouse), or do you use pitch reset at a controller?
pitch reset in controller with RMX.... i hate manually doing this!
Cuando coloco una canción que empieza a reproducir este botón (pitch reset) me aparece automáticamente en un valor 7.50 % y hasta mas alto. Como colocaría esta función para que no funcione así automático que siempre este 00.0 % cada que las canciones inicien?
