I'm wondering if anyone can recommend a good plugin for VDJ that I can use for mastering my mix?
Can't seem to find any that work with VDJ.
geposted Sat 19 Sep 09 @ 4:44 pm
What about T-Racks?
Anyone used that with VDJ?
geposted Sun 20 Sep 09 @ 3:21 pm
mastering??
what do you mean?
what do you mean?
geposted Sun 20 Sep 09 @ 3:38 pm
Most people these days dont just mix off the turntables and record it the way it is. Usually, a producer or the DJ will do some type of mastering on the mix so you don't lose quality.
The problem with recording an hours worth of music to a CD is that once the full space of the cd is used, you lose quite a bit of quality.
I need to counter that problem - and need to produce a mix cd that is just as good as other mix cd's out there.
Maybe something like a compression plugin will help?
geposted Sun 20 Sep 09 @ 4:32 pm
mastering software wouldn't be a plug in .....
geposted Sun 20 Sep 09 @ 8:12 pm
You should use a program like Adobe Audition or something similar to record and master your mix then.
However, MASTERING is a tricky thing and you'll have to study a few things about the sound before you proceed to a decent mastering result. Using a compressor (or a multi-band compressor) is not everything on the mastering procedure. It is only/just a basic step... ;)
geposted Mon 21 Sep 09 @ 5:06 am
Use Ableton Case Closed.
Joey....
Joey....
geposted Mon 21 Sep 09 @ 10:46 pm
That's what I use.
geposted Tue 22 Sep 09 @ 12:23 am
