Hi. I just installed the demo of VDJ6 and loving it. BUT. Yep, always a BUT.
I have a BCD3000 and at the moment I couldn't use VDJ and BCD3000 live as I have to tap all buttons on the BCD3000 twice for anything to happen. Which means, in 'manual' DJ mode I miss the beat I wanted to start the next track on.
Is there a cure for this and is there full BCD3000 support as I have just wasted money on another (which will remain nameless even though I want to shout from the rooftops) DJ software that turned out not to do all it claimed and I can;t get my money back. I want to buy VDJ but won't spend anymore money on any software until I see it working completely - and that means full support and easy use of BCD3000.
Cheers.
Martin
Cheers.
Martin
geposted Sun 20 Sep 09 @ 4:00 am
The trial version is v6.0.1 which had an incorrect definition for the BCD controllers. This was corrected in the current production version 6.0.2.
Trial version will be updated in the near future and I don't have a date to give you.
geposted Sun 20 Sep 09 @ 9:09 am
Well, I bought the pro version today and still I have to double tap the buttons on BCD3000...
Surely there's a way to fix this?
Martin
Martin
geposted Tue 29 Sep 09 @ 1:03 pm
Got the double tapping fixed.
Installed the driver in compatibility mode.
Now if only I can get the mapping to work perfectly and it waill be so sweet!.
Loving VDJ6
Martin
Loving VDJ6
Martin
geposted Tue 29 Sep 09 @ 1:44 pm
Here's how I fixed the double tap problem.
Using a full pro version of VDJ6.
You need to run the driver for BCD3000 in XP Compatible Mode.
Get the latest XP/Vista Driver installation file and, before you run it, right click the installer file and choose 'Properties'.
Select the 'Compatibility' tab.
Select 'Run This Program in Compatibility Mode' option.
From the operating systems options, choose XP.
I usually also choose to run in Administrator mode too.
Click OK and then run the program.
That worked for me.
That worked for me.
geposted Tue 17 Nov 09 @ 1:29 am
Hey i just found out how to fix the double tap problem.....is simple as hello....you just need to open up bcd3000 control panel and set it to standard not advanced....that's all
geposted Sat 19 Feb 11 @ 2:01 am
