i find that when i mix one song on the same bpm.....with another...it sounds slightly different ...even thought they are the sam bpm and matched up well...it sounds a bit faster or slower....is it the pitch IS there something i can adjust ....am i being clear///HELPPPP.and thanks
geposted Sun 20 Sep 09 @ 3:08 pm
If I well understand, you should enable the master_tempo/key_lock feature
geposted Sun 20 Sep 09 @ 3:40 pm
where do i locate that feature?
geposted Sun 20 Sep 09 @ 5:11 pm
Well it depends on what skin you use. Generally the "key" button will be above, or below the pitch control slider. Click it on and the pitch or key of the song will stay the same no matter where your tempo slider is set.
I'm using MFF VJ 6.4 skin and the small button marked "key"... is above the slider. It is blue for the left deck, and red for the right.
On this skin you also have a key change knob that displays "Am" - A minor... and can change key up or down in increments. Like Am to G#m to Gm to F#m to Fm to Em ending with D#m.
Turing the knob to the left takes the song and scales down it's key as listed above. Twist to the right and go up in scale ending with D#m but 1 octive above the low D#m. It makes Madonna sound like a guy turning the knob to the left, and like a chipmunk member turning to the right.
Pretty cool stuff. Learn to use it right... and you should be able to create some pretty cool music and mixes.
Jim-e-L
geposted Mon 21 Sep 09 @ 12:31 am
i am now using that skin...very nice, just dont see that am to gm keys that u speak of....guide mi
geposted Tue 22 Sep 09 @ 8:55 am
