I try to connect my midi controller to my trial version of VDJ, and it's not able to do more than 1 midi command at once.. is it just me?
My midi controller is the Behringer DDM4000. I created my own mapper and it seems to work fine, when I press the buttons.
However, problems come when I try to map my LEDs. Sometimes I would put 2 LEDs to do the same command, and only 1 LED will perform it. Is it VirtualDJ? Is it able to output more then one command to my Behringer, at once?
Thanks so much!!
Thanks so much!!
geposted Sun 20 Sep 09 @ 3:28 pm
