hello everyone ok i have a question for all.. i have a few systems, and they are all running very slow with the new update ver 6.0 and to newer.
i was able to run ver 5 ish with no problems but now i notice that now the cpu power at idle just running vj is around 48 to 52%
then when i load a song it goes to about 80% and when i load a video 100% cpu power.
one syste is a intel 2.0g pros with 2gigs of memory windows xp pro with ser pack 3 nvidia video
the other system is a asus mother board amd 64 bit dual core pros 2 gigs of memory windows xp pro with ser pack 3 nvidia video
i even uninstalled ver 6.02 and went back to ver 5 and no problems both systems went back to normal
i am asking if anyone else is having any of the same issues
thanks
thanks
geposted Sun 20 Sep 09 @ 7:37 pm
Make sure you dont have the skin maximised. Use a skin that matches your screen resolution. You will always see the cpu shoot up when loading a song.
geposted Mon 21 Sep 09 @ 1:54 am
