1. Some of the samples I have put into VDJ do not play to the end, any ideas.
2. My samle and FX buttons have changed round FX now contains the samples and vice versa, how do i change this back?
Thanks
VoodooSi
Thanks
VoodooSi
geposted Thu 21 Apr 05 @ 4:57 pm
open the xml file in notepad and search for sample..and do the same but type effect....you just change the position of the buttons. just switch them.
geposted Fri 22 Apr 05 @ 1:13 pm
Thank you very much!
geposted Fri 22 Apr 05 @ 5:39 pm
er sorry! which XML file, whats its name?
geposted Fri 22 Apr 05 @ 5:42 pm
