13" or 15"?????
Looking on running VDJ on MAc or Win7 using bootcamp or parallels...
Either way just looking on opinions in screen size
geposted Mon 21 Sep 09 @ 10:08 pm
Do you want to use video? if yes, buy the model with a 2.8 core 2 duo cpu and the 9600GT or an older model with the 9600GT (video card), if you are not going to use video it's a matter of screen and the laptop size that you prefer.
geposted Tue 22 Sep 09 @ 10:47 am
It is also a matter of whether you want to run firewire or use express cards. If so, you will need a pro. the 13" is USB only.
geposted Tue 22 Sep 09 @ 12:50 pm
The Macbook Pro 13.3 does have a 800 firewire port.
#two USB 2.0 ports (up to 480 Mbps), one FireWire 800 (up to 800 Mbps), SD card slot
geposted Tue 22 Sep 09 @ 4:42 pm
