I would like to know if anybody has manage to work with 6.02 version without any video freezing problems?? I am a new of virtual dj and I love when use with mp3 but hate when using video caause I am trying to impress with my videos I bought 2 laptops and video projectro big screen = vj to impress and my videos freeze on the main screen but as soon as I upload my next video in to the other player the video comesback I has to be fast so that people don't notice what is going. my clients like th ideo of vj, but it makes me a fool when they freeze cause they are watching... Anybody please share your setting for windows vista.
video freezin happens in both of my laptops.
LAPTOP 1.
HP PAVILION DV7
WINDOW VISTA 32 BIT, SERVICE PACK 2
INTEL CORE 2 QUAND 2.0GHZ, ATI RADEON HD 4650 1GB, 4GB OF RAM, RUNNING VISTA FOR BEST PERFORMANCE AND DISABLE ANTIVIRUS, RUNNING ONLY THE ESSENTIAL SOFTWARE.
LAPTOP 2
TOSHIBA SATELLITE
INTEL CORE DUO 2.GHZ, ATI RADEON, ATI RADEON HD 4600 1GB, 4GB OF RAN, RUNNING VISTA FOR BEST PERFORMANCE AND DISABLE ANTIVIRUS, RUNNING ONLY THE ESSENTIAL SOFTWARE.
PLEASE HELP..
Dj Memo - Australia
LAPTOP 1.
HP PAVILION DV7
LAPTOP 2
TOSHIBA SATELLITE
PLEASE HELP..
Dj Memo - Australia
geposted Tue 22 Sep 09 @ 1:10 am
As you are using laptops I assume you are using an external HDD.
Try running a couple of vids from the computers internal drive and see if you get any improvement. Some external drives can be a little slow when loading video especialy when playing another video at the same time.
Try to keep the USB load down by using as few USB devices as you can.
Make shure you have gone through the basic tweaks for laptop use IE switch off and shut down any wireles apps and software that you don't use.
Daz
Daz
geposted Tue 22 Sep 09 @ 2:33 am
Daz
Daz
Hi Daz
Thanks for your help. @ the moment am using the internal HDD as I got 1 terrabite in my laptop and still have plenty of space. the only usb that am using is TOTAL CONTRAL and EXTERNAL SOUND CARD. but to be honest it seens to be fine just for videos at least for an hour, then when I mix mp3 convine with videos, that when it start to freeze. normally I shut down all programs and disable untivirus. and Iam running vista for best perfomance.. any suggestion...?
geposted Tue 22 Sep 09 @ 2:47 am
Just a thought. How hot is youre laptop getting?
If its running ok for a hour or so, could it be overheating?
Daz
Daz
geposted Tue 22 Sep 09 @ 3:07 am
Plenty of people mix video without issue; myself included. The key is usually the video card and OS version - both of those are DX10 cards.
geposted Tue 22 Sep 09 @ 4:22 am
great question SBDJ..
geposted Tue 22 Sep 09 @ 10:39 am
Yes both cards has the latest DX10>> according to some website they come with sercive pack 1, I just installed service parck 2.
Just to make sure do you know how to check what version I have?? Running windows vista.
geposted Wed 23 Sep 09 @ 12:22 am
Vista is DX10.. I've had an issue as u but I have a pc... Receiving a DX9 card his week and will c If it fixes my freezing....
What make card are they?
geposted Wed 23 Sep 09 @ 2:36 am
It's a hardware thing on the card itself as to whether it is DX10 capable. VirtualDJ is a DX9 application - running it under Vista (which supports DX10) with a DX10 capable card seems to cause some people issues.
geposted Wed 23 Sep 09 @ 4:17 am
Run the DirectX 9c install on your Vista O/S --
http://www.microsoft.com/downloads/details.aspx?FamilyID=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
geposted Wed 23 Sep 09 @ 7:08 am
well i dont know if this will help you but it helped me i have an hp pavillion dv6000 i upgraded to 2 gigs of ddr ram i have vdj 6 and a terrabite of external hd, also maya 44 and m audio x session pro all of this was causing my video to freeze so i installed ram boost master and whalah problem solved istantly now i can do some x-treme scratching with my numark axis 9 cd dec time coded :)............
geposted Fri 25 Sep 09 @ 12:06 am
