okay, so i've updated the 6.0.1 to 6.0.2 and these are the still continuing issues from previous version of 5.2.1
1) I have a shortcut key created to increase/decrease the volume gains for the selected player, both are created at the same increments (+0.02 for arrow up for increase) (-0.02 for arrow down for decrease)..but the change in the volumes are never consistent..sometimes the volume will increase/decrease (display on the gain) .03 then 1.2 then .09..they are never constant, they are always changing each time i use the arrow up/down...
(would like this solved if anyone has any input)
2) i created a shortcut key to jump 8 beats forward/backward within the song, in the previous version 5.2.1 it would jump seamlessly when the song was being played and i would use the shortcut key, now when i atttemp this, its sounds like the song is skipping even though the song beat grid is correct..i love this previous shortcut usage when the song had endless loops that i could foward thru and reduce the song length..now its not possible
(another solution please from someone)
Thanks
Thanks
geposted Tue 22 Sep 09 @ 1:32 am
