Has anyone made a mapper for the rane ttm-57sl mixer for V6. If so, where do I find it and if not then why not lol. Thanxs for all the help, and also has all or majority of the bugs been worked out for V6 on mac, I know at first I was having problems and what not so I just reinstalled V5.
Thanks,
Mike
Thanks,
Mike
geposted Tue 22 Sep 09 @ 11:02 am
I would like to know the same thing.
Thanx
Thanx
geposted Tue 02 Feb 10 @ 2:16 pm
Unfortunately that is not possible because Rane TTM-57SL is not MIDI compatible - It uses a proprietary protocol and is currently locked to Serato.
It also cannot be used for timecode either - The inputs do not function (Serato has proprietary support.)
You would be better using a standard MIDI compatible mixer that is compatible with ANY DJ software, e.g; Pioneer DJM-800
geposted Wed 03 Feb 10 @ 12:18 pm
