Topic: it seems to be a windows7 compatibility issue - Page: 1
Hi there. Saturday at a wedding party I have got a crash. Search crash but not to desktop, just search crash to freeze :)
A crashguard report has been created but it is empty.
1. searched for a song
2.clicked on the title tab in order to sort alphabetically
3. clicked on the search field
4. error mesage without the restarting vdj option (close program and send report only) than freeze
Today I have checked the windows messages with the event viewer. I have found 2 error mesages:
first error 19.09.2009 17:32:25
Faulting application name: virtualdj.exe, version: 6.0.0.0, time stamp: 0x4a97f052
Faulting module name: virtualdj.exe, version: 6.0.0.0, time stamp: 0x4a97f052
Exception code: 0xc0000005
Fault offset: 0x000b331a
Faulting process id: 0x294
Faulting application start time: 0x01ca3915157c35cf
Faulting application path: C:\Program Files\VirtualDJ\virtualdj.exe
Faulting module path: C:\Program Files\VirtualDJ\virtualdj.exe
Report Id: 3f3e1718-a529-11de-b7a6-862d5b7e8463
second error 19.09.2009 17:35:58
The program virtualdj.exe version 6.0.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center
control panel.
Process ID: e94
Start Time: 01ca39361ef235fe
Termination Time: 0
Application Path: C:\Program Files\VirtualDJ\virtualdj.exe
Report Id: ab2479d9-a529-11de-b7a6-862d5b7e8463
After scaning for solution in action center I get this:
Problem: VirtualDj
Program compatibility problem
Files that help describe the problem:
appcompat.txt
This is appcompat.txt:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="install_virtualdj_pro_v6.0.2.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="install_virtualdj_pro_v6.0.1.exe" SIZE="21113513" CHECKSUM="0xE12B2326" BIN_FILE_VERSION="6.0.1.0" BIN_PRODUCT_VERSION="6.0.1.0" FILE_DESCRIPTION="Virtual DJ"
COMPANY_NAME="Atomix Productions" FILE_VERSION="6.0.1" LEGAL_COPYRIGHT="(c) Atomix Productions" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x10001" VERFILETYPE="0x1" MODULE_TYPE="WIN32"
PE_CHECKSUM="0x0" LINKER_VERSION="0x40000" UPTO_BIN_FILE_VERSION="6.0.1.0" UPTO_BIN_PRODUCT_VERSION="6.0.1.0" LINK_DATE="04/25/2000 14:37:12" UPTO_LINK_DATE="04/25/2000 14:37:12"
EXPORT_NAME="STUB32.EXE" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="install_virtualdj_pro_v6.0.2.exe" SIZE="21097984" CHECKSUM="0xE12B2326" BIN_FILE_VERSION="6.0.2.0" BIN_PRODUCT_VERSION="6.0.2.0" FILE_DESCRIPTION="Virtual DJ"
COMPANY_NAME="Atomix Productions" FILE_VERSION="6.0.2" LEGAL_COPYRIGHT="(c) Atomix Productions" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x10001" VERFILETYPE="0x1" MODULE_TYPE="WIN32"
PE_CHECKSUM="0x0" LINKER_VERSION="0x40000" UPTO_BIN_FILE_VERSION="6.0.2.0" UPTO_BIN_PRODUCT_VERSION="6.0.2.0" LINK_DATE="04/25/2000 14:37:12" UPTO_LINK_DATE="04/25/2000 14:37:12"
<MATCHING_FILE NAME="install_virtualdj_pro_v6.0.exe" SIZE="21188983" CHECKSUM="0xE12B2326" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" FILE_DESCRIPTION="Virtual DJ" COMPANY_NAME="Atomix
Productions" FILE_VERSION="6.0" LEGAL_COPYRIGHT="(c) Atomix Productions" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x10001" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0"
LINKER_VERSION="0x40000" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="04/25/2000 14:37:12" UPTO_LINK_DATE="04/25/2000 14:37:12" EXPORT_NAME="STUB32.EXE"
</EXE>
</DATABASE>
This was my second crush with vdj6
The first crush was back on july 25 and I have reported it here: https://virtualdj.com/forums/113169/PC_Version_Technical_Support/Crashguard_report.html?search=g2p%20windows7&page=1
geposted Tue 22 Sep 09 @ 5:56 pm
I hope you find the answer but did you really DJ a wedding using Windows 7 which isnt properly released until late October? Are you serious?? Its a wedding! You dont use pre-release software for a wedding! (or any paid performance)
My question is.. Why would you use Windows 7 on a laptop being used for DJ use.. Especially on a wedding. Your laptop is something you don't mess with. Only use what is proven to work and not something that hasnt been tested. Fact.. The Best OS for DJ software is Windows XP Not Vista.
Hey now, lovin my Vista..
LOL.. Whats up brian. Vista works good but XP has a very low latecity.
The laptop with windows7 was for backup. As for the tested os......come on, there are plenty of user who have problems with every os, including xp. :) So let\'s focus on those crashes not on the reason a person would consider to use an operating sistem or another, or cd-players or laptop :)
So, Caliente, I want to ask you something. Did you manage to play flawless with maximum performance settings? I mean this settings:
And the keylock (mastertempo) must be checked.
I'm asking you this because when I check the keylock something strange happens: let's say deck1 plays a song....when I want to cue a song in deck2 the song in deck1 start to sound like double flip effect. I repeat, only with master tempo active. I've tested on 2 different systems:
1. asus g2p laptop (core2duo t7200, 2GB ram, ati x1700 ) and creative X-Fi Xtreme Audio Notebook soundcard, both xp and w7
2. desktop (amd x64, 2gb ram) and m-audio delta1010 soundcard, only xp
So i have installed windows xp a week ago. And guess what: I just get another crash. I was searching for a song, than I have pressed backspace button and the send report window has appeared. After I have sent report I have checked the crasguard report file from vdj folder and I saw there is no such file. In computer management I can see this event:
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 04.10.2009
Time: 14:21:48
User: N/A
Computer: MOBILE
Description:
Faulting application virtualdj.exe, version 6.0.0.0, faulting module ntdll.dll, version 5.1.2600.5755, fault address 0x0001b21a.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 76 69 72 ure vir
0018: 74 75 61 6c 64 6a 2e 65 tualdj.e
0020: 78 65 20 36 2e 30 2e 30 xe 6.0.0
0028: 2e 30 20 69 6e 20 6e 74 .0 in nt
0030: 64 6c 6c 2e 64 6c 6c 20 dll.dll
0038: 35 2e 31 2e 32 36 30 30 5.1.2600
0040: 2e 35 37 35 35 20 61 74 .5755 at
0048: 20 6f 66 66 73 65 74 20 offset
0050: 30 30 30 31 62 32 31 61 0001b21a
0058: 0d 0a ..
and dr. watson say this:
Event Type: Information
Event Source: DrWatson
Event ID: 4097
Date: 04.10.2009
Time: 14:22:02
User: N/A
Computer: MOBILE
Description:
The application, C:\Program Files\VirtualDJ\virtualdj.exe, generated an application error The error occurred on 10/04/2009 @ 14:22:02.390 The exception generated was c0000005 at address 7C91B21A (ntdll!RtlpWaitForCriticalSection)
Data:
00000: 0d 00 0a 00 0d 00 0a 00 ........
00008: 41 00 70 00 70 00 6c 00 A.p.p.l.
00010: 69 00 63 00 61 00 74 00 i.c.a.t.
00018: 69 00 6f 00 6e 00 20 00 i.o.n. .
00020: 65 00 78 00 63 00 65 00 e.x.c.e.
00028: 70 00 74 00 69 00 6f 00 p.t.i.o.
00030: 6e 00 20 00 6f 00 63 00 n. .o.c.
00038: 63 00 75 00 72 00 72 00 c.u.r.r.
00040: 65 00 64 00 3a 00 0d 00 e.d.:...
00048: 0a 00 20 00 20 00 20 00 .. . . .
00050: 20 00 20 00 20 00 20 00 . . . .
00058: 20 00 41 00 70 00 70 00 .A.p.p.
00060: 3a 00 20 00 43 00 3a 00 :. .C.:.
00068: 5c 00 50 00 72 00 6f 00 \.P.r.o.
00070: 67 00 72 00 61 00 6d 00 g.r.a.m.
00078: 20 00 46 00 69 00 6c 00 .F.i.l.
00080: 65 00 73 00 5c 00 56 00 e.s.\.V.
00088: 69 00 72 00 74 00 75 00 i.r.t.u.
00090: 61 00 6c 00 44 00 4a 00 a.l.D.J.
00098: 5c 00 76 00 69 00 72 00 \.v.i.r.
000a0: 74 00 75 00 61 00 6c 00 t.u.a.l.
000a8: 64 00 6a 00 2e 00 65 00 d.j...e.
000b0: 78 00 65 00 20 00 28 00 x.e. .(.
000b8: 70 00 69 00 64 00 3d 00 p.i.d.=.
000c0: 34 00 37 00 39 00 36 00 4.7.9.6.
000c8: 29 00 0d 00 0a 00 20 00 )..... .
000d0: 20 00 20 00 20 00 20 00 . . . .
000d8: 20 00 20 00 20 00 57 00 . . .W.
000e0: 68 00 65 00 6e 00 3a 00 h.e.n.:.
000e8: 20 00 30 00 34 00 2e 00 .0.4...
000f0: 31 00 30 00 2e 00 32 00 1.0...2.
000f8: 30 00 30 00 39 00 20 00 0.0.9. .
00100: 40 00 20 00 31 00 34 00 @. .1.4.
00108: 3a 00 32 00 32 00 3a 00 :.2.2.:.
00110: 30 00 32 00 2e 00 33 00 0.2...3.
00118: 39 00 30 00 0d 00 0a 00 9.0.....
00120: 20 00 20 00 20 00 20 00 . . . .
00128: 20 00 20 00 20 00 20 00 . . . .
00130: 45 00 78 00 63 00 65 00 E.x.c.e.
00138: 70 00 74 00 69 00 6f 00 p.t.i.o.
00140: 6e 00 20 00 6e 00 75 00 n. .n.u.
00148: 6d 00 62 00 65 00 72 00 m.b.e.r.
00150: 3a 00 20 00 63 00 30 00 :. .c.0.
00158: 30 00 30 00 30 00 30 00 0.0.0.0.
00160: 30 00 35 00 20 00 28 00 0.5. .(.
00168: 61 00 63 00 63 00 65 00 a.c.c.e.
00170: 73 00 73 00 20 00 76 00 s.s. .v.
00178: 69 00 6f 00 6c 00 61 00 i.o.l.a.
00180: 74 00 69 00 6f 00 6e 00 t.i.o.n.
00188: 29 00 0d 00 0a 00 0d 00 ).......
00190: 0a 00 2a 00 2d 00 2d 00 ..*.-.-.
00198: 2d 00 2d 00 3e 00 20 00 -.-.>. .
001a0: 53 00 79 00 73 00 74 00 S.y.s.t.
001a8: 65 00 6d 00 20 00 49 00 e.m. .I.
001b0: 6e 00 66 00 6f 00 72 00 n.f.o.r.
001b8: 6d 00 61 00 74 00 69 00 m.a.t.i.
001c0: 6f 00 6e 00 20 00 3c 00 o.n. .<.
001c8: 2d 00 2d 00 2d 00 2d 00 -.-.-.-.
001d0: 2a 00 0d 00 0a 00 20 00 *..... .
001d8: 20 00 20 00 20 00 20 00 . . . .
001e0: 20 00 20 00 20 00 43 00 . . .C.
001e8: 6f 00 6d 00 70 00 75 00 o.m.p.u.
001f0: 74 00 65 00 72 00 20 00 t.e.r. .
001f8: 4e 00 61 00 6d 00 65 00 N.a.m.e.
00200: 3a 00 20 00 4d 00 4f 00 :. .M.O.
00208: 42 00 49 00 4c 00 45 00 B.I.L.E.
00210: 0d 00 0a 00 20 00 20 00 .... . .
00218: 20 00 20 00 20 00 20 00 . . . .
00220: 20 00 20 00 55 00 73 00 . .U.s.
00228: 65 00 72 00 20 00 4e 00 e.r. .N.
00230: 61 00 6d 00 65 00 3a 00 a.m.e.:.
00238: 20 00 4d 00 61 00 72 00 .M.a.r.
00240: 69 00 75 00 73 00 0d 00 i.u.s...
00248: 0a 00 20 00 20 00 20 00 .. . . .
00250: 20 00 20 00 20 00 20 00 . . . .
00258: 20 00 54 00 65 00 72 00 .T.e.r.
00260: 6d 00 69 00 6e 00 61 00 m.i.n.a.
00268: 6c 00 20 00 53 00 65 00 l. .S.e.
00270: 73 00 73 00 69 00 6f 00 s.s.i.o.
00278: 6e 00 20 00 49 00 64 00 n. .I.d.
00280: 3a 00 20 00 30 00 0d 00 :. .0...
00288: 0a 00 20 00 20 00 20 00 .. . . .
00290: 20 00 20 00 20 00 20 00 . . . .
00298: 20 00 4e 00 75 00 6d 00 .N.u.m.
002a0: 62 00 65 00 72 00 20 00 b.e.r. .
002a8: 6f 00 66 00 20 00 50 00 o.f. .P.
002b0: 72 00 6f 00 63 00 65 00 r.o.c.e.
002b8: 73 00 73 00 6f 00 72 00 s.s.o.r.
002c0: 73 00 3a 00 20 00 32 00 s.:. .2.
002c8: 0d 00 0a 00 20 00 20 00 .... . .
002d0: 20 00 20 00 20 00 20 00 . . . .
002d8: 20 00 20 00 50 00 72 00 . .P.r.
002e0: 6f 00 63 00 65 00 73 00 o.c.e.s.
002e8: 73 00 6f 00 72 00 20 00 s.o.r. .
002f0: 54 00 79 00 70 00 65 00 T.y.p.e.
002f8: 3a 00 20 00 78 00 38 00 :. .x.8.
00300: 36 00 20 00 46 00 61 00 6. .F.a.
00308: 6d 00 69 00 6c 00 79 00 m.i.l.y.
00310: 20 00 36 00 20 00 4d 00 .6. .M.
00318: 6f 00 64 00 65 00 6c 00 o.d.e.l.
00320: 20 00 31 00 35 00 20 00 .1.5. .
00328: 53 00 74 00 65 00 70 00 S.t.e.p.
00330: 70 00 69 00 6e 00 67 00 p.i.n.g.
00338: 20 00 36 00 0d 00 0a 00 .6.....
00340: 20 00 20 00 20 00 20 00 . . . .
00348: 20 00 20 00 20 00 20 00 . . . .
00350: 57 00 69 00 6e 00 64 00 W.i.n.d.
00358: 6f 00 77 00 73 00 20 00 o.w.s. .
00360: 56 00 65 00 72 00 73 00 V.e.r.s.
00368: 69 00 6f 00 6e 00 3a 00 i.o.n.:.
00370: 20 00 35 00 2e 00 31 00 .5...1.
00378: 0d 00 0a 00 20 00 20 00 .... . .
00380: 20 00 20 00 20 00 20 00 . . . .
00388: 20 00 20 00 43 00 75 00 . .C.u.
00390: 72 00 72 00 65 00 6e 00 r.r.e.n.
00398: 74 00 20 00 42 00 75 00 t. .B.u.
003a0: 69 00 6c 00 64 00 3a 00 i.l.d.:.
003a8: 20 00 32 00 36 00 30 00 .2.6.0.
003b0: 30 00 0d 00 0a 00 20 00 0..... .
003b8: 20 00 20 00 20 00 20 00 . . . .
003c0: 20 00 20 00 20 00 53 00 . . .S.
003c8: 65 00 72 00 76 00 69 00 e.r.v.i.
003d0: 63 00 65 00 20 00 50 00 c.e. .P.
003d8: 61 00 63 00 6b 00 3a 00 a.c.k.:.
003e0: 20 00 33 00 0d 00 0a 00 .3.....
003e8: 20 00 20 00 20 00 20 00 . . . .
003f0: 20 00 20 00 20 00 20 00 . . . .
003f8: 43 00 75 00 72 00 72 00 C.u.r.r.
00400: 65 00 6e 00 74 00 20 00 e.n.t. .
00408: 54 00 79 00 70 00 65 00 T.y.p.e.
00410: 3a 00 20 00 4d 00 75 00 :. .M.u.
00418: 6c 00 74 00 69 00 70 00 l.t.i.p.
00420: 72 00 6f 00 63 00 65 00 r.o.c.e.
00428: 73 00 73 00 6f 00 72 00 s.s.o.r.
00430: 20 00 46 00 72 00 65 00 .F.r.e.
00438: 65 00 0d 00 0a 00 20 00 e..... .
00440: 20 00 20 00 20 00 20 00 . . . .
00448: 20 00 20 00 20 00 52 00 . . .R.
00450: 65 00 67 00 69 00 73 00 e.g.i.s.
00458: 74 00 65 00 72 00 65 00 t.e.r.e.
00460: 64 00 20 00 4f 00 72 00 d. .O.r.
00468: 67 00 61 00 6e 00 69 00 g.a.n.i.
00470: 7a 00 61 00 74 00 69 00 z.a.t.i.
00478: 6f 00 6e 00 3a 00 20 00 o.n.:. .
00480: 48 00 6f 00 6d 00 65 00 H.o.m.e.
00488: 0d 00 0a 00 20 00 20 00 .... . .
00490: 20 00 20 00 20 00 20 00 . . . .
00498: 20 00 20 00 52 00 65 00 . .R.e.
004a0: 67 00 69 00 73 00 74 00 g.i.s.t.
004a8: 65 00 72 00 65 00 64 00 e.r.e.d.
004b0: 20 00 4f 00 77 00 6e 00 .O.w.n.
004b8: 65 00 72 00 3a 00 20 00 e.r.:. .
004c0: 4d 00 61 00 72 00 69 00 M.a.r.i.
004c8: 75 00 73 00 0d 00 0a 00 u.s.....
004d0: 0d 00 0a 00 2a 00 2d 00 ....*.-.
004d8: 2d 00 2d 00 2d 00 3e 00 -.-.-.>.
004e0: 20 00 54 00 61 00 73 00 .T.a.s.
004e8: 6b 00 20 00 4c 00 69 00 k. .L.i.
004f0: 73 00 74 00 20 00 3c 00 s.t. .<.
004f8: 2d 00 2d 00 2d 00 2d 00 -.-.-.-.
00500: 2a 00 0d 00 0a 00 20 00 *..... .
00508: 20 00 20 00 30 00 20 00 . .0. .
00510: 53 00 79 00 73 00 74 00 S.y.s.t.
00518: 65 00 6d 00 20 00 50 00 e.m. .P.
00520: 72 00 6f 00 63 00 65 00 r.o.c.e.
00528: 73 00 73 00 0d 00 0a 00 s.s.....
00530: 20 00 20 00 20 00 34 00 . . .4.
00538: 20 00 53 00 79 00 73 00 .S.y.s.
00540: 74 00 65 00 6d 00 0d 00 t.e.m...
00548: 0a 00 20 00 37 00 30 00 .. .7.0.
00550: 38 00 20 00 73 00 6d 00 8. .s.m.
00558: 73 00 73 00 2e 00 65 00 s.s...e.
00560: 78 00 65 00 0d 00 0a 00 x.e.....
00568: 31 00 30 00 35 00 36 00 1.0.5.6.
00570: 20 00 63 00 73 00 72 00 .c.s.r.
00578: 73 00 73 00 2e 00 65 00 s.s...e.
00580: 78 00 65 00 0d 00 0a 00 x.e.....
00588: 31 00 30 00 38 00 38 00 1.0.8.8.
00590: 20 00 77 00 69 00 6e 00 .w.i.n.
00598: 6c 00 6f 00 67 00 6f 00 l.o.g.o.
005a0: 6e 00 2e 00 65 00 78 00 n...e.x.
005a8: 65 00 0d 00 0a 00 31 00 e.....1.
005b0: 31 00 33 00 32 00 20 00 1.3.2. .
005b8: 73 00 65 00 72 00 76 00 s.e.r.v.
005c0: 69 00 63 00 65 00 73 00 i.c.e.s.
005c8: 2e 00 65 00 78 00 65 00 ..e.x.e.
005d0: 0d 00 0a 00 31 00 31 00 ....1.1.
005d8: 34 00 34 00 20 00 6c 00 4.4. .l.
005e0: 73 00 61 00 73 00 73 00 s.a.s.s.
005e8: 2e 00 65 00 78 00 65 00 ..e.x.e.
005f0: 0d 00 0a 00 31 00 33 00 ....1.3.
005f8: 31 00 32 00 20 00 41 00 1.2. .A.
00600: 74 00 69 00 32 00 65 00 t.i.2.e.
00608: 76 00 78 00 78 00 2e 00 v.x.x...
00610: 65 00 78 00 65 00 0d 00 e.x.e...
00618: 0a 00 31 00 33 00 33 00 ..1.3.3.
00620: 32 00 20 00 73 00 76 00 2. .s.v.
00628: 63 00 68 00 6f 00 73 00 c.h.o.s.
00630: 74 00 2e 00 65 00 78 00 t...e.x.
00638: 65 00 0d 00 0a 00 31 00 e.....1.
00640: 34 00 33 00 32 00 20 00 4.3.2. .
00648: 73 00 76 00 63 00 68 00 s.v.c.h.
00650: 6f 00 73 00 74 00 2e 00 o.s.t...
00658: 65 00 78 00 65 00 0d 00 e.x.e...
00660: 0a 00 31 00 34 00 37 00 ..1.4.7.
00668: 32 00 20 00 73 00 76 00 2. .s.v.
00670: 63 00 68 00 6f 00 73 00 c.h.o.s.
00678: 74 00 2e 00 65 00 78 00 t...e.x.
00680: 65 00 0d 00 0a 00 31 00 e.....1.
00688: 35 00 31 00 32 00 20 00 5.1.2. .
00690: 45 00 76 00 74 00 45 00 E.v.t.E.
00698: 6e 00 67 00 2e 00 65 00 n.g...e.
006a0: 78 00 65 00 0d 00 0a 00 x.e.....
006a8: 31 00 35 00 36 00 34 00 1.5.6.4.
006b0: 20 00 41 00 74 00 69 00 .A.t.i.
006b8: 32 00 65 00 76 00 78 00 2.e.v.x.
006c0: 78 00 2e 00 65 00 78 00 x...e.x.
006c8: 65 00 0d 00 0a 00 31 00 e.....1.
006d0: 38 00 30 00 38 00 20 00 8.0.8. .
006d8: 45 00 78 00 70 00 6c 00 E.x.p.l.
006e0: 6f 00 72 00 65 00 72 00 o.r.e.r.
006e8: 2e 00 45 00 58 00 45 00 ..E.X.E.
006f0: 0d 00 0a 00 31 00 39 00 ....1.9.
006f8: 32 00 30 00 20 00 53 00 2.0. .S.
00700: 32 00 34 00 45 00 76 00 2.4.E.v.
00708: 4d 00 6f 00 6e 00 2e 00 M.o.n...
00710: 65 00 78 00 65 00 0d 00 e.x.e...
00718: 0a 00 32 00 30 00 31 00 ..2.0.1.
00720: 36 00 20 00 73 00 76 00 6. .s.v.
00728: 63 00 68 00 6f 00 73 00 c.h.o.s.
00730: 74 00 2e 00 65 00 78 00 t...e.x.
00738: 65 00 0d 00 0a 00 20 00 e..... .
00740: 32 00 30 00 30 00 20 00 2.0.0. .
00748: 73 00 76 00 63 00 68 00 s.v.c.h.
00750: 6f 00 73 00 74 00 2e 00 o.s.t...
00758: 65 00 78 00 65 00 0d 00 e.x.e...
00760: 0a 00 20 00 34 00 36 00 .. .4.6.
00768: 30 00 20 00 73 00 70 00 0. .s.p.
00770: 6f 00 6f 00 6c 00 73 00 o.o.l.s.
00778: 76 00 2e 00 65 00 78 00 v...e.x.
00780: 65 00 0d 00 0a 00 20 00 e..... .
00788: 35 00 30 00 30 00 20 00 5.0.0. .
00790: 43 00 54 00 41 00 75 00 C.T.A.u.
00798: 64 00 53 00 76 00 63 00 d.S.v.c.
007a0: 2e 00 65 00 78 00 65 00 ..e.x.e.
007a8: 0d 00 0a 00 20 00 35 00 .... .5.
007b0: 34 00 34 00 20 00 73 00 4.4. .s.
007b8: 76 00 63 00 68 00 6f 00 v.c.h.o.
007c0: 73 00 74 00 2e 00 65 00 s.t...e.
007c8: 78 00 65 00 0d 00 0a 00 x.e.....
007d0: 20 00 36 00 32 00 30 00 .6.2.0.
007d8: 20 00 52 00 65 00 6d 00 .R.e.m.
007e0: 6f 00 74 00 65 00 43 00 o.t.e.C.
007e8: 6f 00 6e 00 74 00 72 00 o.n.t.r.
007f0: 6f 00 6c 00 53 00 65 00 o.l.S.e.
007f8: 72 00 76 00 69 00 63 00 r.v.i.c.
00800: 65 00 2e 00 65 00 78 00 e...e.x.
00808: 65 00 0d 00 0a 00 20 00 e..... .
00810: 36 00 34 00 34 00 20 00 6.4.4. .
00818: 6a 00 71 00 73 00 2e 00 j.q.s...
00820: 65 00 78 00 65 00 0d 00 e.x.e...
00828: 0a 00 20 00 38 00 37 00 .. .8.7.
00830: 32 00 20 00 52 00 65 00 2. .R.e.
00838: 67 00 53 00 72 00 76 00 g.S.r.v.
00840: 63 00 2e 00 65 00 78 00 c...e.x.
00848: 65 00 0d 00 0a 00 20 00 e..... .
00850: 39 00 30 00 34 00 20 00 9.0.4. .
00858: 73 00 76 00 63 00 68 00 s.v.c.h.
00860: 6f 00 73 00 74 00 2e 00 o.s.t...
00868: 65 00 78 00 65 00 0d 00 e.x.e...
00870: 0a 00 20 00 39 00 34 00 .. .9.4.
00878: 34 00 20 00 54 00 65 00 4. .T.e.
00880: 61 00 6d 00 56 00 69 00 a.m.V.i.
00888: 65 00 77 00 65 00 72 00 e.w.e.r.
00890: 5f 00 53 00 65 00 72 00 _.S.e.r.
00898: 76 00 69 00 63 00 65 00 v.i.c.e.
008a0: 2e 00 65 00 78 00 65 00 ..e.x.e.
008a8: 0d 00 0a 00 20 00 39 00 .... .9.
008b0: 38 00 38 00 20 00 77 00 8.8. .w.
008b8: 64 00 66 00 6d 00 67 00 d.f.m.g.
008c0: 72 00 2e 00 65 00 78 00 r...e.x.
008c8: 65 00 0d 00 0a 00 31 00 e.....1.
008d0: 37 00 30 00 38 00 20 00 7.0.8. .
008d8: 54 00 65 00 61 00 6d 00 T.e.a.m.
008e0: 56 00 69 00 65 00 77 00 V.i.e.w.
008e8: 65 00 72 00 2e 00 65 00 e.r...e.
008f0: 78 00 65 00 0d 00 0a 00 x.e.....
008f8: 32 00 30 00 36 00 38 00 2.0.6.8.
00900: 20 00 61 00 6c 00 67 00 .a.l.g.
00908: 2e 00 65 00 78 00 65 00 ..e.x.e.
00910: 0d 00 0a 00 32 00 35 00 ....2.5.
00918: 39 00 36 00 20 00 48 00 9.6. .H.
00920: 43 00 6f 00 6e 00 74 00 C.o.n.t.
00928: 72 00 6f 00 6c 00 2e 00 r.o.l...
00930: 65 00 78 00 65 00 0d 00 e.x.e...
00938: 0a 00 32 00 36 00 31 00 ..2.6.1.
00940: 36 00 20 00 52 00 54 00 6. .R.T.
00948: 48 00 44 00 43 00 50 00 H.D.C.P.
00950: 4c 00 2e 00 45 00 58 00 L...E.X.
00958: 45 00 0d 00 0a 00 32 00 E.....2.
00960: 36 00 34 00 38 00 20 00 6.4.8. .
00968: 43 00 4c 00 49 00 2e 00 C.L.I...
00970: 45 00 58 00 45 00 0d 00 E.X.E...
00978: 0a 00 32 00 37 00 33 00 ..2.7.3.
00980: 36 00 20 00 73 00 6d 00 6. .s.m.
00988: 35 00 36 00 68 00 6c 00 5.6.h.l.
00990: 70 00 72 00 2e 00 65 00 p.r...e.
00998: 78 00 65 00 0d 00 0a 00 x.e.....
009a0: 32 00 37 00 35 00 32 00 2.7.5.2.
009a8: 20 00 41 00 70 00 6f 00 .A.p.o.
009b0: 69 00 6e 00 74 00 2e 00 i.n.t...
009b8: 65 00 78 00 65 00 0d 00 e.x.e...
009c0: 0a 00 32 00 37 00 36 00 ..2.7.6.
009c8: 30 00 20 00 5a 00 43 00 0. .Z.C.
009d0: 66 00 67 00 53 00 76 00 f.g.S.v.
009d8: 63 00 2e 00 65 00 78 00 c...e.x.
009e0: 65 00 0d 00 0a 00 32 00 e.....2.
009e8: 37 00 36 00 38 00 20 00 7.6.8. .
009f0: 69 00 66 00 72 00 6d 00 i.f.r.m.
009f8: 65 00 77 00 72 00 6b 00 e.w.r.k.
00a00: 2e 00 65 00 78 00 65 00 ..e.x.e.
00a08: 0d 00 0a 00 32 00 37 00 ....2.7.
00a10: 39 00 32 00 20 00 77 00 9.2. .w.
00a18: 63 00 6f 00 75 00 72 00 c.o.u.r.
00a20: 69 00 65 00 72 00 2e 00 i.e.r...
00a28: 65 00 78 00 65 00 0d 00 e.x.e...
00a30: 0a 00 32 00 38 00 30 00 ..2.8.0.
00a38: 30 00 20 00 4c 00 43 00 0. .L.C.
00a40: 4d 00 50 00 2e 00 45 00 M.P...E.
00a48: 58 00 45 00 0d 00 0a 00 X.E.....
00a50: 32 00 38 00 31 00 32 00 2.8.1.2.
00a58: 20 00 43 00 54 00 41 00 .C.T.A.
00a60: 50 00 52 00 32 00 2e 00 P.R.2...
00a68: 65 00 78 00 65 00 0d 00 e.x.e...
00a70: 0a 00 32 00 38 00 32 00 ..2.8.2.
00a78: 30 00 20 00 56 00 6f 00 0. .V.o.
00a80: 6c 00 50 00 61 00 6e 00 l.P.a.n.
00a88: 6c 00 75 00 2e 00 65 00 l.u...e.
00a90: 78 00 65 00 0d 00 0a 00 x.e.....
00a98: 32 00 38 00 33 00 32 00 2.8.3.2.
00aa0: 20 00 52 00 75 00 6e 00 .R.u.n.
00aa8: 64 00 6c 00 6c 00 33 00 d.l.l.3.
00ab0: 32 00 2e 00 65 00 78 00 2...e.x.
00ab8: 65 00 0d 00 0a 00 32 00 e.....2.
00ac0: 38 00 37 00 32 00 20 00 8.7.2. .
00ac8: 48 00 69 00 64 00 46 00 H.i.d.F.
00ad0: 69 00 6e 00 64 00 2e 00 i.n.d...
00ad8: 65 00 78 00 65 00 0d 00 e.x.e...
00ae0: 0a 00 32 00 38 00 38 00 ..2.8.8.
00ae8: 30 00 20 00 41 00 70 00 0. .A.p.
00af0: 6e 00 74 00 65 00 78 00 n.t.e.x.
00af8: 2e 00 65 00 78 00 65 00 ..e.x.e.
00b00: 0d 00 0a 00 32 00 39 00 ....2.9.
00b08: 32 00 30 00 20 00 4f 00 2.0. .O.
00b10: 55 00 54 00 4c 00 4f 00 U.T.L.O.
00b18: 4f 00 4b 00 2e 00 45 00 O.K...E.
00b20: 58 00 45 00 0d 00 0a 00 X.E.....
00b28: 32 00 39 00 34 00 30 00 2.9.4.0.
00b30: 20 00 41 00 70 00 76 00 .A.p.v.
00b38: 66 00 62 00 2e 00 65 00 f.b...e.
00b40: 78 00 65 00 0d 00 0a 00 x.e.....
00b48: 33 00 31 00 30 00 34 00 3.1.0.4.
00b50: 20 00 6a 00 75 00 73 00 .j.u.s.
00b58: 63 00 68 00 65 00 64 00 c.h.e.d.
00b60: 2e 00 65 00 78 00 65 00 ..e.x.e.
00b68: 0d 00 0a 00 33 00 31 00 ....3.1.
00b70: 31 00 32 00 20 00 77 00 1.2. .w.
00b78: 69 00 6e 00 61 00 6d 00 i.n.a.m.
00b80: 70 00 61 00 2e 00 65 00 p.a...e.
00b88: 78 00 65 00 0d 00 0a 00 x.e.....
00b90: 33 00 32 00 32 00 30 00 3.2.2.0.
00b98: 20 00 63 00 74 00 66 00 .c.t.f.
00ba0: 6d 00 6f 00 6e 00 2e 00 m.o.n...
00ba8: 65 00 78 00 65 00 0d 00 e.x.e...
00bb0: 0a 00 33 00 32 00 32 00 ..3.2.2.
00bb8: 38 00 20 00 50 00 43 00 8. .P.C.
00bc0: 53 00 75 00 69 00 74 00 S.u.i.t.
00bc8: 65 00 2e 00 65 00 78 00 e...e.x.
00bd0: 65 00 0d 00 0a 00 33 00 e.....3.
00bd8: 32 00 39 00 32 00 20 00 2.9.2. .
00be0: 54 00 6f 00 73 00 42 00 T.o.s.B.
00be8: 74 00 4d 00 6e 00 67 00 t.M.n.g.
00bf0: 2e 00 65 00 78 00 65 00 ..e.x.e.
00bf8: 0d 00 0a 00 33 00 35 00 ....3.5.
00c00: 34 00 38 00 20 00 54 00 4.8. .T.
00c08: 6f 00 73 00 41 00 32 00 o.s.A.2.
00c10: 64 00 70 00 2e 00 65 00 d.p...e.
00c18: 78 00 65 00 0d 00 0a 00 x.e.....
00c20: 33 00 35 00 38 00 38 00 3.5.8.8.
00c28: 20 00 54 00 6f 00 73 00 .T.o.s.
00c30: 42 00 74 00 48 00 69 00 B.t.H.i.
00c38: 64 00 2e 00 65 00 78 00 d...e.x.
00c40: 65 00 0d 00 0a 00 33 00 e.....3.
00c48: 36 00 30 00 34 00 20 00 6.0.4. .
00c50: 54 00 6f 00 73 00 42 00 T.o.s.B.
00c58: 74 00 48 00 73 00 70 00 t.H.s.p.
00c60: 2e 00 65 00 78 00 65 00 ..e.x.e.
00c68: 0d 00 0a 00 34 00 30 00 ....4.0.
00c70: 37 00 36 00 20 00 41 00 7.6. .A.
00c78: 54 00 4b 00 4f 00 53 00 T.K.O.S.
00c80: 44 00 2e 00 65 00 78 00 D...e.x.
00c88: 65 00 0d 00 0a 00 34 00 e.....4.
00c90: 30 00 38 00 34 00 20 00 0.8.4. .
00c98: 63 00 6c 00 69 00 2e 00 c.l.i...
00ca0: 65 00 78 00 65 00 0d 00 e.x.e...
00ca8: 0a 00 31 00 36 00 37 00 ..1.6.7.
00cb0: 32 00 20 00 63 00 6c 00 2. .c.l.
00cb8: 69 00 2e 00 65 00 78 00 i...e.x.
00cc0: 65 00 0d 00 0a 00 20 00 e..... .
00cc8: 38 00 30 00 34 00 20 00 8.0.4. .
00cd0: 44 00 6f 00 74 00 31 00 D.o.t.1.
00cd8: 58 00 43 00 66 00 67 00 X.C.f.g.
00ce0: 2e 00 65 00 78 00 65 00 ..e.x.e.
00ce8: 0d 00 0a 00 33 00 33 00 ....3.3.
00cf0: 39 00 36 00 20 00 53 00 9.6. .S.
00cf8: 65 00 72 00 76 00 69 00 e.r.v.i.
00d00: 63 00 65 00 4c 00 61 00 c.e.L.a.
00d08: 79 00 65 00 72 00 2e 00 y.e.r...
00d10: 65 00 78 00 65 00 0d 00 e.x.e...
00d18: 0a 00 34 00 30 00 34 00 ..4.0.4.
00d20: 34 00 20 00 4e 00 63 00 4. .N.c.
00d28: 6c 00 55 00 53 00 42 00 l.U.S.B.
00d30: 53 00 72 00 76 00 2e 00 S.r.v...
00d38: 65 00 78 00 65 00 0d 00 e.x.e...
00d40: 0a 00 32 00 32 00 34 00 ..2.2.4.
00d48: 30 00 20 00 4e 00 63 00 0. .N.c.
00d50: 6c 00 52 00 53 00 53 00 l.R.S.S.
00d58: 72 00 76 00 2e 00 65 00 r.v...e.
00d60: 78 00 65 00 0d 00 0a 00 x.e.....
00d68: 32 00 33 00 34 00 34 00 2.3.4.4.
00d70: 20 00 4e 00 63 00 6c 00 .N.c.l.
00d78: 54 00 6f 00 42 00 54 00 T.o.B.T.
00d80: 53 00 72 00 76 00 2e 00 S.r.v...
00d88: 65 00 78 00 65 00 0d 00 e.x.e...
00d90: 0a 00 35 00 37 00 39 00 ..5.7.9.
00d98: 32 00 20 00 66 00 69 00 2. .f.i.
00da0: 72 00 65 00 66 00 6f 00 r.e.f.o.
00da8: 78 00 2e 00 65 00 78 00 x...e.x.
00db0: 65 00 0d 00 0a 00 34 00 e.....4.
00db8: 36 00 36 00 34 00 20 00 6.6.4. .
00dc0: 59 00 61 00 68 00 6f 00 Y.a.h.o.
00dc8: 6f 00 4d 00 65 00 73 00 o.M.e.s.
00dd0: 73 00 65 00 6e 00 67 00 s.e.n.g.
00dd8: 65 00 72 00 2e 00 65 00 e.r...e.
00de0: 78 00 65 00 0d 00 0a 00 x.e.....
00de8: 32 00 34 00 35 00 36 00 2.4.5.6.
00df0: 20 00 77 00 6d 00 69 00 .w.m.i.
00df8: 70 00 72 00 76 00 73 00 p.r.v.s.
00e00: 65 00 2e 00 65 00 78 00 e...e.x.
00e08: 65 00 0d 00 0a 00 35 00 e.....5.
00e10: 30 00 38 00 34 00 20 00 0.8.4. .
00e18: 54 00 4f 00 54 00 41 00 T.O.T.A.
00e20: 4c 00 43 00 4d 00 44 00 L.C.M.D.
00e28: 2e 00 45 00 58 00 45 00 ..E.X.E.
00e30: 0d 00 0a 00 35 00 39 00 ....5.9.
00e38: 36 00 30 00 20 00 53 00 6.0. .S.
00e40: 75 00 70 00 65 00 72 00 u.p.e.r.
00e48: 46 00 6c 00 65 00 78 00 F.l.e.x.
00e50: 69 00 62 00 6c 00 65 00 i.b.l.e.
00e58: 53 00 79 00 6e 00 63 00 S.y.n.c.
00e60: 68 00 72 00 6f 00 6e 00 h.r.o.n.
00e68: 69 00 7a 00 65 00 72 00 i.z.e.r.
00e70: 2e 00 65 00 78 00 65 00 ..e.x.e.
00e78: 0d 00 0a 00 34 00 37 00 ....4.7.
00e80: 39 00 36 00 20 00 76 00 9.6. .v.
00e88: 69 00 72 00 74 00 75 00 i.r.t.u.
00e90: 61 00 6c 00 64 00 6a 00 a.l.d.j.
00e98: 2e 00 65 00 78 00 65 00 ..e.x.e.
00ea0: 0d 00 0a 00 34 00 31 00 ....4.1.
00ea8: 30 00 30 00 20 00 77 00 0.0. .w.
00eb0: 69 00 6e 00 61 00 6d 00 i.n.a.m.
00eb8: 70 00 2e 00 65 00 78 00 p...e.x.
00ec0: 65 00 0d 00 0a 00 35 00 e.....5.
00ec8: 31 00 35 00 32 00 20 00 1.5.2. .
00ed0: 64 00 77 00 77 00 69 00 d.w.w.i.
00ed8: 6e 00 2e 00 65 00 78 00 n...e.x.
00ee0: 65 00 0d 00 0a 00 34 00 e.....4.
00ee8: 38 00 34 00 34 00 20 00 8.4.4. .
00ef0: 64 00 72 00 77 00 74 00 d.r.w.t.
00ef8: 73 00 6e 00 33 00 32 00 s.n.3.2.
00f00: 2e 00 65 00 78 00 65 00 ..e.x.e.
00f08: 0d 00 0a 00 0d 00 0a 00 ........
00f10: 2a 00 2d 00 2d 00 2d 00 *.-.-.-.
00f18: 2d 00 3e 00 20 00 4d 00 -.>. .M.
00f20: 6f 00 64 00 75 00 6c 00 o.d.u.l.
00f28: 65 00 20 00 4c 00 69 00 e. .L.i.
00f30: 73 00 74 00 20 00 3c 00 s.t. .<.
00f38: 2d 00 2d 00 2d 00 2d 00 -.-.-.-.
00f40: 2a 00 0d 00 0a 00 28 00 *.....(.
00f48: 30 00 30 00 30 00 30 00 0.0.0.0.
00f50: 30 00 30 00 30 00 30 00 0.0.0.0.
00f58: 30 00 30 00 34 00 30 00 0.0.4.0.
00f60: 30 00 30 00 30 00 30 00 0.0.0.0.
00f68: 20 00 2d 00 20 00 30 00 .-. .0.
00f70: 30 00 30 00 30 00 30 00 0.0.0.0.
00f78: 30 00 30 00 30 00 30 00 0.0.0.0.
00f80: 31 00 31 00 62 00 36 00 1.1.b.6.
00f88: 30 00 30 00 30 00 3a 00 0.0.0.:.
00f90: 20 00 43 00 3a 00 5c 00 .C.:.\.
00f98: 50 00 72 00 6f 00 67 00 P.r.o.g.
00fa0: 72 00 61 00 6d 00 20 00 r.a.m. .
00fa8: 46 00 69 00 6c 00 65 00 F.i.l.e.
00fb0: 73 00 5c 00 56 00 69 00 s.\.V.i.
00fb8: 72 00 74 00 75 00 61 00 r.t.u.a.
00fc0: 6c 00 44 00 4a 00 5c 00 l.D.J.\.
00fc8: 76 00 69 00 72 00 74 00 v.i.r.t.
00fd0: 75 00 61 00 6c 00 64 00 u.a.l.d.
00fd8: 6a 00 2e 00 65 00 78 00 j...e.x.
00fe0: 65 00 0d 00 0a 00 28 00 e.....(.
00fe8: 30 00 30 00 30 00 30 00 0.0.0.0.
00ff0: 30 00 30 00 30 00 30 00 0.0.0.0.
00ff8: 30 00 32 00 38 00 36 00 0.2.8.6.
01000: 30 00 30 00 30 00 30 00 0.0.0.0.
01008: 20 00 2d 00 20 00 30 00 .-. .0.
01010: 30 00 30 00 30 00 30 00 0.0.0.0.
01018: 30 00 30 00 30 00 30 00 0.0.0.0.
01020: 32 00 38 00 39 00 62 00 2.8.9.b.
01028: 30 00 30 00 30 00 3a 00 0.0.0.:.
01030: 20 00 43 00 3a 00 5c 00 .C.:.\.
01038: 57 00 49 00 4e 00 44 00 W.I.N.D.
01040: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01048: 73 00 79 00 73 00 74 00 s.y.s.t.
01050: 65 00 6d 00 33 00 32 00 e.m.3.2.
01058: 5c 00 57 00 4d 00 41 00 \.W.M.A.
01060: 53 00 46 00 2e 00 44 00 S.F...D.
01068: 4c 00 4c 00 0d 00 0a 00 L.L.....
01070: 28 00 30 00 30 00 30 00 (.0.0.0.
01078: 30 00 30 00 30 00 30 00 0.0.0.0.
01080: 30 00 30 00 32 00 38 00 0.0.2.8.
01088: 62 00 30 00 30 00 30 00 b.0.0.0.
01090: 30 00 20 00 2d 00 20 00 0. .-. .
01098: 30 00 30 00 30 00 30 00 0.0.0.0.
010a0: 30 00 30 00 30 00 30 00 0.0.0.0.
010a8: 30 00 32 00 38 00 63 00 0.2.8.c.
010b0: 37 00 30 00 30 00 30 00 7.0.0.0.
010b8: 3a 00 20 00 43 00 3a 00 :. .C.:.
010c0: 5c 00 57 00 49 00 4e 00 \.W.I.N.
010c8: 44 00 4f 00 57 00 53 00 D.O.W.S.
010d0: 5c 00 73 00 79 00 73 00 \.s.y.s.
010d8: 74 00 65 00 6d 00 33 00 t.e.m.3.
010e0: 32 00 5c 00 6f 00 64 00 2.\.o.d.
010e8: 62 00 63 00 69 00 6e 00 b.c.i.n.
010f0: 74 00 2e 00 64 00 6c 00 t...d.l.
010f8: 6c 00 0d 00 0a 00 28 00 l.....(.
01100: 30 00 30 00 30 00 30 00 0.0.0.0.
01108: 30 00 30 00 30 00 30 00 0.0.0.0.
01110: 30 00 33 00 39 00 62 00 0.3.9.b.
01118: 30 00 30 00 30 00 30 00 0.0.0.0.
01120: 20 00 2d 00 20 00 30 00 .-. .0.
01128: 30 00 30 00 30 00 30 00 0.0.0.0.
01130: 30 00 30 00 30 00 30 00 0.0.0.0.
01138: 33 00 63 00 37 00 35 00 3.c.7.5.
01140: 30 00 30 00 30 00 3a 00 0.0.0.:.
01148: 20 00 43 00 3a 00 5c 00 .C.:.\.
01150: 57 00 49 00 4e 00 44 00 W.I.N.D.
01158: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01160: 73 00 79 00 73 00 74 00 s.y.s.t.
01168: 65 00 6d 00 33 00 32 00 e.m.3.2.
01170: 5c 00 78 00 70 00 73 00 \.x.p.s.
01178: 70 00 32 00 72 00 65 00 p.2.r.e.
01180: 73 00 2e 00 64 00 6c 00 s...d.l.
01188: 6c 00 0d 00 0a 00 28 00 l.....(.
01190: 30 00 30 00 30 00 30 00 0.0.0.0.
01198: 30 00 30 00 30 00 30 00 0.0.0.0.
011a0: 30 00 34 00 35 00 38 00 0.4.5.8.
011a8: 30 00 30 00 30 00 30 00 0.0.0.0.
011b0: 20 00 2d 00 20 00 30 00 .-. .0.
011b8: 30 00 30 00 30 00 30 00 0.0.0.0.
011c0: 30 00 30 00 30 00 30 00 0.0.0.0.
011c8: 34 00 35 00 39 00 39 00 4.5.9.9.
011d0: 30 00 30 00 30 00 3a 00 0.0.0.:.
011d8: 20 00 43 00 3a 00 5c 00 .C.:.\.
011e0: 44 00 6f 00 63 00 75 00 D.o.c.u.
011e8: 6d 00 65 00 6e 00 74 00 m.e.n.t.
011f0: 73 00 20 00 61 00 6e 00 s. .a.n.
011f8: 64 00 20 00 53 00 65 00 d. .S.e.
01200: 74 00 74 00 69 00 6e 00 t.t.i.n.
01208: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01210: 61 00 72 00 69 00 75 00 a.r.i.u.
01218: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01220: 20 00 44 00 6f 00 63 00 .D.o.c.
01228: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01230: 74 00 73 00 5c 00 56 00 t.s.\.V.
01238: 69 00 72 00 74 00 75 00 i.r.t.u.
01240: 61 00 6c 00 44 00 4a 00 a.l.D.J.
01248: 5c 00 50 00 6c 00 75 00 \.P.l.u.
01250: 67 00 69 00 6e 00 73 00 g.i.n.s.
01258: 5c 00 56 00 69 00 64 00 \.V.i.d.
01260: 65 00 6f 00 54 00 72 00 e.o.T.r.
01268: 61 00 6e 00 73 00 69 00 a.n.s.i.
01270: 74 00 69 00 6f 00 6e 00 t.i.o.n.
01278: 5c 00 64 00 65 00 66 00 \.d.e.f.
01280: 61 00 75 00 6c 00 74 00 a.u.l.t.
01288: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01290: 0d 00 0a 00 28 00 30 00 ....(.0.
01298: 30 00 30 00 30 00 30 00 0.0.0.0.
012a0: 30 00 30 00 30 00 30 00 0.0.0.0.
012a8: 34 00 36 00 32 00 30 00 4.6.2.0.
012b0: 30 00 30 00 30 00 20 00 0.0.0. .
012b8: 2d 00 20 00 30 00 30 00 -. .0.0.
012c0: 30 00 30 00 30 00 30 00 0.0.0.0.
012c8: 30 00 30 00 30 00 34 00 0.0.0.4.
012d0: 36 00 33 00 33 00 30 00 6.3.3.0.
012d8: 30 00 30 00 3a 00 20 00 0.0.:. .
012e0: 43 00 3a 00 5c 00 44 00 C.:.\.D.
012e8: 6f 00 63 00 75 00 6d 00 o.c.u.m.
012f0: 65 00 6e 00 74 00 73 00 e.n.t.s.
012f8: 20 00 61 00 6e 00 64 00 .a.n.d.
01300: 20 00 53 00 65 00 74 00 .S.e.t.
01308: 74 00 69 00 6e 00 67 00 t.i.n.g.
01310: 73 00 5c 00 4d 00 61 00 s.\.M.a.
01318: 72 00 69 00 75 00 73 00 r.i.u.s.
01320: 5c 00 4d 00 79 00 20 00 \.M.y. .
01328: 44 00 6f 00 63 00 75 00 D.o.c.u.
01330: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01338: 73 00 5c 00 56 00 69 00 s.\.V.i.
01340: 72 00 74 00 75 00 61 00 r.t.u.a.
01348: 6c 00 44 00 4a 00 5c 00 l.D.J.\.
01350: 50 00 6c 00 75 00 67 00 P.l.u.g.
01358: 69 00 6e 00 73 00 5c 00 i.n.s.\.
01360: 53 00 6f 00 75 00 6e 00 S.o.u.n.
01368: 64 00 45 00 66 00 66 00 d.E.f.f.
01370: 65 00 63 00 74 00 5c 00 e.c.t.\.
01378: 65 00 63 00 68 00 6f 00 e.c.h.o.
01380: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01388: 0d 00 0a 00 28 00 30 00 ....(.0.
01390: 30 00 30 00 30 00 30 00 0.0.0.0.
01398: 30 00 30 00 30 00 30 00 0.0.0.0.
013a0: 38 00 63 00 61 00 30 00 8.c.a.0.
013a8: 30 00 30 00 30 00 20 00 0.0.0. .
013b0: 2d 00 20 00 30 00 30 00 -. .0.0.
013b8: 30 00 30 00 30 00 30 00 0.0.0.0.
013c0: 30 00 30 00 30 00 38 00 0.0.0.8.
013c8: 63 00 62 00 39 00 30 00 c.b.9.0.
013d0: 30 00 30 00 3a 00 20 00 0.0.:. .
013d8: 43 00 3a 00 5c 00 44 00 C.:.\.D.
013e0: 6f 00 63 00 75 00 6d 00 o.c.u.m.
013e8: 65 00 6e 00 74 00 73 00 e.n.t.s.
013f0: 20 00 61 00 6e 00 64 00 .a.n.d.
013f8: 20 00 53 00 65 00 74 00 .S.e.t.
01400: 74 00 69 00 6e 00 67 00 t.i.n.g.
01408: 73 00 5c 00 4d 00 61 00 s.\.M.a.
01410: 72 00 69 00 75 00 73 00 r.i.u.s.
01418: 5c 00 4d 00 79 00 20 00 \.M.y. .
01420: 44 00 6f 00 63 00 75 00 D.o.c.u.
01428: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01430: 73 00 5c 00 56 00 69 00 s.\.V.i.
01438: 72 00 74 00 75 00 61 00 r.t.u.a.
01440: 6c 00 44 00 4a 00 5c 00 l.D.J.\.
01448: 50 00 6c 00 75 00 67 00 P.l.u.g.
01450: 69 00 6e 00 73 00 5c 00 i.n.s.\.
01458: 53 00 6f 00 75 00 6e 00 S.o.u.n.
01460: 64 00 45 00 66 00 66 00 d.E.f.f.
01468: 65 00 63 00 74 00 5c 00 e.c.t.\.
01470: 62 00 61 00 63 00 6b 00 b.a.c.k.
01478: 73 00 70 00 69 00 6e 00 s.p.i.n.
01480: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01488: 0d 00 0a 00 28 00 30 00 ....(.0.
01490: 30 00 30 00 30 00 30 00 0.0.0.0.
01498: 30 00 30 00 30 00 30 00 0.0.0.0.
014a0: 38 00 64 00 34 00 30 00 8.d.4.0.
014a8: 30 00 30 00 30 00 20 00 0.0.0. .
014b0: 2d 00 20 00 30 00 30 00 -. .0.0.
014b8: 30 00 30 00 30 00 30 00 0.0.0.0.
014c0: 30 00 30 00 30 00 38 00 0.0.0.8.
014c8: 64 00 35 00 39 00 30 00 d.5.9.0.
014d0: 30 00 30 00 3a 00 20 00 0.0.:. .
014d8: 43 00 3a 00 5c 00 44 00 C.:.\.D.
014e0: 6f 00 63 00 75 00 6d 00 o.c.u.m.
014e8: 65 00 6e 00 74 00 73 00 e.n.t.s.
014f0: 20 00 61 00 6e 00 64 00 .a.n.d.
014f8: 20 00 53 00 65 00 74 00 .S.e.t.
01500: 74 00 69 00 6e 00 67 00 t.i.n.g.
01508: 73 00 5c 00 4d 00 61 00 s.\.M.a.
01510: 72 00 69 00 75 00 73 00 r.i.u.s.
01518: 5c 00 4d 00 79 00 20 00 \.M.y. .
01520: 44 00 6f 00 63 00 75 00 D.o.c.u.
01528: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01530: 73 00 5c 00 56 00 69 00 s.\.V.i.
01538: 72 00 74 00 75 00 61 00 r.t.u.a.
01540: 6c 00 44 00 4a 00 5c 00 l.D.J.\.
01548: 50 00 6c 00 75 00 67 00 P.l.u.g.
01550: 69 00 6e 00 73 00 5c 00 i.n.s.\.
01558: 53 00 6f 00 75 00 6e 00 S.o.u.n.
01560: 64 00 45 00 66 00 66 00 d.E.f.f.
01568: 65 00 63 00 74 00 5c 00 e.c.t.\.
01570: 62 00 72 00 61 00 6b 00 b.r.a.k.
01578: 65 00 2e 00 64 00 6c 00 e...d.l.
01580: 6c 00 0d 00 0a 00 28 00 l.....(.
01588: 30 00 30 00 30 00 30 00 0.0.0.0.
01590: 30 00 30 00 30 00 30 00 0.0.0.0.
01598: 30 00 38 00 64 00 65 00 0.8.d.e.
015a0: 30 00 30 00 30 00 30 00 0.0.0.0.
015a8: 20 00 2d 00 20 00 30 00 .-. .0.
015b0: 30 00 30 00 30 00 30 00 0.0.0.0.
015b8: 30 00 30 00 30 00 30 00 0.0.0.0.
015c0: 38 00 65 00 36 00 39 00 8.e.6.9.
015c8: 30 00 30 00 30 00 3a 00 0.0.0.:.
015d0: 20 00 43 00 3a 00 5c 00 .C.:.\.
015d8: 44 00 6f 00 63 00 75 00 D.o.c.u.
015e0: 6d 00 65 00 6e 00 74 00 m.e.n.t.
015e8: 73 00 20 00 61 00 6e 00 s. .a.n.
015f0: 64 00 20 00 53 00 65 00 d. .S.e.
015f8: 74 00 74 00 69 00 6e 00 t.t.i.n.
01600: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01608: 61 00 72 00 69 00 75 00 a.r.i.u.
01610: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01618: 20 00 44 00 6f 00 63 00 .D.o.c.
01620: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01628: 74 00 73 00 5c 00 56 00 t.s.\.V.
01630: 69 00 72 00 74 00 75 00 i.r.t.u.
01638: 61 00 6c 00 44 00 4a 00 a.l.D.J.
01640: 5c 00 50 00 6c 00 75 00 \.P.l.u.
01648: 67 00 69 00 6e 00 73 00 g.i.n.s.
01650: 5c 00 53 00 6f 00 75 00 \.S.o.u.
01658: 6e 00 64 00 45 00 66 00 n.d.E.f.
01660: 66 00 65 00 63 00 74 00 f.e.c.t.
01668: 5c 00 42 00 65 00 61 00 \.B.e.a.
01670: 74 00 47 00 72 00 69 00 t.G.r.i.
01678: 64 00 2e 00 64 00 6c 00 d...d.l.
01680: 6c 00 0d 00 0a 00 28 00 l.....(.
01688: 30 00 30 00 30 00 30 00 0.0.0.0.
01690: 30 00 30 00 30 00 30 00 0.0.0.0.
01698: 30 00 38 00 66 00 37 00 0.8.f.7.
016a0: 30 00 30 00 30 00 30 00 0.0.0.0.
016a8: 20 00 2d 00 20 00 30 00 .-. .0.
016b0: 30 00 30 00 30 00 30 00 0.0.0.0.
016b8: 30 00 30 00 30 00 30 00 0.0.0.0.
016c0: 39 00 30 00 30 00 36 00 9.0.0.6.
016c8: 30 00 30 00 30 00 3a 00 0.0.0.:.
016d0: 20 00 43 00 3a 00 5c 00 .C.:.\.
016d8: 44 00 6f 00 63 00 75 00 D.o.c.u.
016e0: 6d 00 65 00 6e 00 74 00 m.e.n.t.
016e8: 73 00 20 00 61 00 6e 00 s. .a.n.
016f0: 64 00 20 00 53 00 65 00 d. .S.e.
016f8: 74 00 74 00 69 00 6e 00 t.t.i.n.
01700: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01708: 61 00 72 00 69 00 75 00 a.r.i.u.
01710: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01718: 20 00 44 00 6f 00 63 00 .D.o.c.
01720: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01728: 74 00 73 00 5c 00 56 00 t.s.\.V.
01730: 69 00 72 00 74 00 75 00 i.r.t.u.
01738: 61 00 6c 00 44 00 4a 00 a.l.D.J.
01740: 5c 00 50 00 6c 00 75 00 \.P.l.u.
01748: 67 00 69 00 6e 00 73 00 g.i.n.s.
01750: 5c 00 53 00 6f 00 75 00 \.S.o.u.
01758: 6e 00 64 00 45 00 66 00 n.d.E.f.
01760: 66 00 65 00 63 00 74 00 f.e.c.t.
01768: 5c 00 66 00 69 00 6c 00 \.f.i.l.
01770: 74 00 65 00 72 00 2e 00 t.e.r...
01778: 64 00 6c 00 6c 00 0d 00 d.l.l...
01780: 0a 00 28 00 30 00 30 00 ..(.0.0.
01788: 30 00 30 00 30 00 30 00 0.0.0.0.
01790: 30 00 30 00 30 00 64 00 0.0.0.d.
01798: 34 00 31 00 30 00 30 00 4.1.0.0.
017a0: 30 00 30 00 20 00 2d 00 0.0. .-.
017a8: 20 00 30 00 30 00 30 00 .0.0.0.
017b0: 30 00 30 00 30 00 30 00 0.0.0.0.
017b8: 30 00 30 00 64 00 36 00 0.0.d.6.
017c0: 35 00 37 00 30 00 30 00 5.7.0.0.
017c8: 30 00 3a 00 20 00 43 00 0.:. .C.
017d0: 3a 00 5c 00 57 00 49 00 :.\.W.I.
017d8: 4e 00 44 00 4f 00 57 00 N.D.O.W.
017e0: 53 00 5c 00 73 00 79 00 S.\.s.y.
017e8: 73 00 74 00 65 00 6d 00 s.t.e.m.
017f0: 33 00 32 00 5c 00 77 00 3.2.\.w.
017f8: 6d 00 76 00 63 00 6f 00 m.v.c.o.
01800: 72 00 65 00 2e 00 64 00 r.e...d.
01808: 6c 00 6c 00 0d 00 0a 00 l.l.....
01810: 28 00 30 00 30 00 30 00 (.0.0.0.
01818: 30 00 30 00 30 00 30 00 0.0.0.0.
01820: 30 00 31 00 30 00 30 00 0.1.0.0.
01828: 30 00 30 00 30 00 30 00 0.0.0.0.
01830: 30 00 20 00 2d 00 20 00 0. .-. .
01838: 30 00 30 00 30 00 30 00 0.0.0.0.
01840: 30 00 30 00 30 00 30 00 0.0.0.0.
01848: 31 00 30 00 30 00 30 00 1.0.0.0.
01850: 39 00 30 00 30 00 30 00 9.0.0.0.
01858: 3a 00 20 00 43 00 3a 00 :. .C.:.
01860: 5c 00 50 00 72 00 6f 00 \.P.r.o.
01868: 67 00 72 00 61 00 6d 00 g.r.a.m.
01870: 20 00 46 00 69 00 6c 00 .F.i.l.
01878: 65 00 73 00 5c 00 41 00 e.s.\.A.
01880: 53 00 55 00 53 00 5c 00 S.U.S.\.
01888: 41 00 53 00 55 00 53 00 A.S.U.S.
01890: 20 00 44 00 69 00 72 00 .D.i.r.
01898: 65 00 63 00 74 00 20 00 e.c.t. .
018a0: 43 00 6f 00 6e 00 73 00 C.o.n.s.
018a8: 6f 00 6c 00 65 00 5c 00 o.l.e.\.
018b0: 4d 00 53 00 4e 00 48 00 M.S.N.H.
018b8: 4f 00 4f 00 4b 00 2e 00 O.O.K...
018c0: 44 00 4c 00 4c 00 0d 00 D.L.L...
018c8: 0a 00 28 00 30 00 30 00 ..(.0.0.
018d0: 30 00 30 00 30 00 30 00 0.0.0.0.
018d8: 30 00 30 00 34 00 65 00 0.0.4.e.
018e0: 63 00 35 00 30 00 30 00 c.5.0.0.
018e8: 30 00 30 00 20 00 2d 00 0.0. .-.
018f0: 20 00 30 00 30 00 30 00 .0.0.0.
018f8: 30 00 30 00 30 00 30 00 0.0.0.0.
01900: 30 00 34 00 65 00 64 00 0.4.e.d.
01908: 66 00 36 00 30 00 30 00 f.6.0.0.
01910: 30 00 3a 00 20 00 43 00 0.:. .C.
01918: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01920: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01928: 53 00 5c 00 57 00 69 00 S.\.W.i.
01930: 6e 00 53 00 78 00 53 00 n.S.x.S.
01938: 5c 00 78 00 38 00 36 00 \.x.8.6.
01940: 5f 00 4d 00 69 00 63 00 _.M.i.c.
01948: 72 00 6f 00 73 00 6f 00 r.o.s.o.
01950: 66 00 74 00 2e 00 57 00 f.t...W.
01958: 69 00 6e 00 64 00 6f 00 i.n.d.o.
01960: 77 00 73 00 2e 00 47 00 w.s...G.
01968: 64 00 69 00 50 00 6c 00 d.i.P.l.
01970: 75 00 73 00 5f 00 36 00 u.s._.6.
01978: 35 00 39 00 35 00 62 00 5.9.5.b.
01980: 36 00 34 00 31 00 34 00 6.4.1.4.
01988: 34 00 63 00 63 00 66 00 4.c.c.f.
01990: 31 00 64 00 66 00 5f 00 1.d.f._.
01998: 31 00 2e 00 30 00 2e 00 1...0...
019a0: 32 00 36 00 30 00 30 00 2.6.0.0.
019a8: 2e 00 35 00 35 00 38 00 ..5.5.8.
019b0: 31 00 5f 00 78 00 2d 00 1._.x.-.
019b8: 77 00 77 00 5f 00 64 00 w.w._.d.
019c0: 66 00 62 00 63 00 34 00 f.b.c.4.
019c8: 66 00 63 00 34 00 5c 00 f.c.4.\.
019d0: 67 00 64 00 69 00 70 00 g.d.i.p.
019d8: 6c 00 75 00 73 00 2e 00 l.u.s...
019e0: 64 00 6c 00 6c 00 0d 00 d.l.l...
019e8: 0a 00 28 00 30 00 30 00 ..(.0.0.
019f0: 30 00 30 00 30 00 30 00 0.0.0.0.
019f8: 30 00 30 00 35 00 39 00 0.0.5.9.
01a00: 33 00 66 00 30 00 30 00 3.f.0.0.
01a08: 30 00 30 00 20 00 2d 00 0.0. .-.
01a10: 20 00 30 00 30 00 30 00 .0.0.0.
01a18: 30 00 30 00 30 00 30 00 0.0.0.0.
01a20: 30 00 35 00 39 00 34 00 0.5.9.4.
01a28: 38 00 32 00 30 00 30 00 8.2.0.0.
01a30: 30 00 3a 00 20 00 43 00 0.:. .C.
01a38: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01a40: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01a48: 53 00 5c 00 73 00 79 00 S.\.s.y.
01a50: 73 00 74 00 65 00 6d 00 s.t.e.m.
01a58: 33 00 32 00 5c 00 77 00 3.2.\.w.
01a60: 69 00 61 00 73 00 68 00 i.a.s.h.
01a68: 65 00 78 00 74 00 2e 00 e.x.t...
01a70: 64 00 6c 00 6c 00 0d 00 d.l.l...
01a78: 0a 00 28 00 30 00 30 00 ..(.0.0.
01a80: 30 00 30 00 30 00 30 00 0.0.0.0.
01a88: 30 00 30 00 35 00 61 00 0.0.5.a.
01a90: 64 00 37 00 30 00 30 00 d.7.0.0.
01a98: 30 00 30 00 20 00 2d 00 0.0. .-.
01aa0: 20 00 30 00 30 00 30 00 .0.0.0.
01aa8: 30 00 30 00 30 00 30 00 0.0.0.0.
01ab0: 30 00 35 00 61 00 64 00 0.5.a.d.
01ab8: 61 00 38 00 30 00 30 00 a.8.0.0.
01ac0: 30 00 3a 00 20 00 43 00 0.:. .C.
01ac8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01ad0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01ad8: 53 00 5c 00 73 00 79 00 S.\.s.y.
01ae0: 73 00 74 00 65 00 6d 00 s.t.e.m.
01ae8: 33 00 32 00 5c 00 75 00 3.2.\.u.
01af0: 78 00 74 00 68 00 65 00 x.t.h.e.
01af8: 6d 00 65 00 2e 00 64 00 m.e...d.
01b00: 6c 00 6c 00 0d 00 0a 00 l.l.....
01b08: 28 00 30 00 30 00 30 00 (.0.0.0.
01b10: 30 00 30 00 30 00 30 00 0.0.0.0.
01b18: 30 00 35 00 62 00 30 00 0.5.b.0.
01b20: 61 00 30 00 30 00 30 00 a.0.0.0.
01b28: 30 00 20 00 2d 00 20 00 0. .-. .
01b30: 30 00 30 00 30 00 30 00 0.0.0.0.
01b38: 30 00 30 00 30 00 30 00 0.0.0.0.
01b40: 35 00 62 00 30 00 61 00 5.b.0.a.
01b48: 37 00 30 00 30 00 30 00 7.0.0.0.
01b50: 3a 00 20 00 43 00 3a 00 :. .C.:.
01b58: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01b60: 44 00 4f 00 57 00 53 00 D.O.W.S.
01b68: 5c 00 73 00 79 00 73 00 \.s.y.s.
01b70: 74 00 65 00 6d 00 33 00 t.e.m.3.
01b78: 32 00 5c 00 75 00 6d 00 2.\.u.m.
01b80: 64 00 6d 00 78 00 66 00 d.m.x.f.
01b88: 72 00 6d 00 2e 00 64 00 r.m...d.
01b90: 6c 00 6c 00 0d 00 0a 00 l.l.....
01b98: 28 00 30 00 30 00 30 00 (.0.0.0.
01ba0: 30 00 30 00 30 00 30 00 0.0.0.0.
01ba8: 30 00 35 00 62 00 38 00 0.5.b.8.
01bb0: 36 00 30 00 30 00 30 00 6.0.0.0.
01bb8: 30 00 20 00 2d 00 20 00 0. .-. .
01bc0: 30 00 30 00 30 00 30 00 0.0.0.0.
01bc8: 30 00 30 00 30 00 30 00 0.0.0.0.
01bd0: 35 00 62 00 38 00 62 00 5.b.8.b.
01bd8: 35 00 30 00 30 00 30 00 5.0.0.0.
01be0: 3a 00 20 00 43 00 3a 00 :. .C.:.
01be8: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01bf0: 44 00 4f 00 57 00 53 00 D.O.W.S.
01bf8: 5c 00 73 00 79 00 73 00 \.s.y.s.
01c00: 74 00 65 00 6d 00 33 00 t.e.m.3.
01c08: 32 00 5c 00 4e 00 45 00 2.\.N.E.
01c10: 54 00 41 00 50 00 49 00 T.A.P.I.
01c18: 33 00 32 00 2e 00 64 00 3.2...d.
01c20: 6c 00 6c 00 0d 00 0a 00 l.l.....
01c28: 28 00 30 00 30 00 30 00 (.0.0.0.
01c30: 30 00 30 00 30 00 30 00 0.0.0.0.
01c38: 30 00 35 00 63 00 61 00 0.5.c.a.
01c40: 64 00 30 00 30 00 30 00 d.0.0.0.
01c48: 30 00 20 00 2d 00 20 00 0. .-. .
01c50: 30 00 30 00 30 00 30 00 0.0.0.0.
01c58: 30 00 30 00 30 00 30 00 0.0.0.0.
01c60: 35 00 63 00 61 00 66 00 5.c.a.f.
01c68: 37 00 30 00 30 00 30 00 7.0.0.0.
01c70: 3a 00 20 00 43 00 3a 00 :. .C.:.
01c78: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01c80: 44 00 4f 00 57 00 53 00 D.O.W.S.
01c88: 5c 00 73 00 79 00 73 00 \.s.y.s.
01c90: 74 00 65 00 6d 00 33 00 t.e.m.3.
01c98: 32 00 5c 00 73 00 68 00 2.\.s.h.
01ca0: 6d 00 65 00 64 00 69 00 m.e.d.i.
01ca8: 61 00 2e 00 64 00 6c 00 a...d.l.
01cb0: 6c 00 0d 00 0a 00 28 00 l.....(.
01cb8: 30 00 30 00 30 00 30 00 0.0.0.0.
01cc0: 30 00 30 00 30 00 30 00 0.0.0.0.
01cc8: 35 00 63 00 64 00 37 00 5.c.d.7.
01cd0: 30 00 30 00 30 00 30 00 0.0.0.0.
01cd8: 20 00 2d 00 20 00 30 00 .-. .0.
01ce0: 30 00 30 00 30 00 30 00 0.0.0.0.
01ce8: 30 00 30 00 30 00 35 00 0.0.0.5.
01cf0: 63 00 64 00 37 00 37 00 c.d.7.7.
01cf8: 30 00 30 00 30 00 3a 00 0.0.0.:.
01d00: 20 00 43 00 3a 00 5c 00 .C.:.\.
01d08: 57 00 49 00 4e 00 44 00 W.I.N.D.
01d10: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01d18: 73 00 79 00 73 00 74 00 s.y.s.t.
01d20: 65 00 6d 00 33 00 32 00 e.m.3.2.
01d28: 5c 00 73 00 65 00 72 00 \.s.e.r.
01d30: 77 00 76 00 64 00 72 00 w.v.d.r.
01d38: 76 00 2e 00 64 00 6c 00 v...d.l.
01d40: 6c 00 0d 00 0a 00 28 00 l.....(.
01d48: 30 00 30 00 30 00 30 00 0.0.0.0.
01d50: 30 00 30 00 30 00 30 00 0.0.0.0.
01d58: 35 00 64 00 30 00 39 00 5.d.0.9.
01d60: 30 00 30 00 30 00 30 00 0.0.0.0.
01d68: 20 00 2d 00 20 00 30 00 .-. .0.
01d70: 30 00 30 00 30 00 30 00 0.0.0.0.
01d78: 30 00 30 00 30 00 35 00 0.0.0.5.
01d80: 64 00 31 00 32 00 61 00 d.1.2.a.
01d88: 30 00 30 00 30 00 3a 00 0.0.0.:.
01d90: 20 00 43 00 3a 00 5c 00 .C.:.\.
01d98: 57 00 49 00 4e 00 44 00 W.I.N.D.
01da0: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01da8: 73 00 79 00 73 00 74 00 s.y.s.t.
01db0: 65 00 6d 00 33 00 32 00 e.m.3.2.
01db8: 5c 00 43 00 4f 00 4d 00 \.C.O.M.
01dc0: 43 00 54 00 4c 00 33 00 C.T.L.3.
01dc8: 32 00 2e 00 64 00 6c 00 2...d.l.
01dd0: 6c 00 0d 00 0a 00 28 00 l.....(.
01dd8: 30 00 30 00 30 00 30 00 0.0.0.0.
01de0: 30 00 30 00 30 00 30 00 0.0.0.0.
01de8: 36 00 36 00 32 00 62 00 6.6.2.b.
01df0: 30 00 30 00 30 00 30 00 0.0.0.0.
01df8: 20 00 2d 00 20 00 30 00 .-. .0.
01e00: 30 00 30 00 30 00 30 00 0.0.0.0.
01e08: 30 00 30 00 30 00 36 00 0.0.0.6.
01e10: 36 00 33 00 30 00 38 00 6.3.0.8.
01e18: 30 00 30 00 30 00 3a 00 0.0.0.:.
01e20: 20 00 43 00 3a 00 5c 00 .C.:.\.
01e28: 57 00 49 00 4e 00 44 00 W.I.N.D.
01e30: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01e38: 73 00 79 00 73 00 74 00 s.y.s.t.
01e40: 65 00 6d 00 33 00 32 00 e.m.3.2.
01e48: 5c 00 68 00 6e 00 65 00 \.h.n.e.
01e50: 74 00 63 00 66 00 67 00 t.c.f.g.
01e58: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01e60: 0d 00 0a 00 28 00 30 00 ....(.0.
01e68: 30 00 30 00 30 00 30 00 0.0.0.0.
01e70: 30 00 30 00 30 00 36 00 0.0.0.6.
01e78: 38 00 38 00 66 00 30 00 8.8.f.0.
01e80: 30 00 30 00 30 00 20 00 0.0.0. .
01e88: 2d 00 20 00 30 00 30 00 -. .0.0.
01e90: 30 00 30 00 30 00 30 00 0.0.0.0.
01e98: 30 00 30 00 36 00 38 00 0.0.6.8.
01ea0: 38 00 66 00 39 00 30 00 8.f.9.0.
01ea8: 30 00 30 00 3a 00 20 00 0.0.:. .
01eb0: 43 00 3a 00 5c 00 57 00 C.:.\.W.
01eb8: 49 00 4e 00 44 00 4f 00 I.N.D.O.
01ec0: 57 00 53 00 5c 00 73 00 W.S.\.s.
01ec8: 79 00 73 00 74 00 65 00 y.s.t.e.
01ed0: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01ed8: 48 00 49 00 44 00 2e 00 H.I.D...
01ee0: 44 00 4c 00 4c 00 0d 00 D.L.L...
01ee8: 0a 00 28 00 30 00 30 00 ..(.0.0.
01ef0: 30 00 30 00 30 00 30 00 0.0.0.0.
01ef8: 30 00 30 00 37 00 31 00 0.0.7.1.
01f00: 61 00 35 00 30 00 30 00 a.5.0.0.
01f08: 30 00 30 00 20 00 2d 00 0.0. .-.
01f10: 20 00 30 00 30 00 30 00 .0.0.0.
01f18: 30 00 30 00 30 00 30 00 0.0.0.0.
01f20: 30 00 37 00 31 00 61 00 0.7.1.a.
01f28: 38 00 66 00 30 00 30 00 8.f.0.0.
01f30: 30 00 3a 00 20 00 43 00 0.:. .C.
01f38: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01f40: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01f48: 53 00 5c 00 73 00 79 00 S.\.s.y.
01f50: 73 00 74 00 65 00 6d 00 s.t.e.m.
01f58: 33 00 32 00 5c 00 6d 00 3.2.\.m.
01f60: 73 00 77 00 73 00 6f 00 s.w.s.o.
01f68: 63 00 6b 00 2e 00 64 00 c.k...d.
01f70: 6c 00 6c 00 0d 00 0a 00 l.l.....
01f78: 28 00 30 00 30 00 30 00 (.0.0.0.
01f80: 30 00 30 00 30 00 30 00 0.0.0.0.
01f88: 30 00 37 00 31 00 61 00 0.7.1.a.
01f90: 39 00 30 00 30 00 30 00 9.0.0.0.
01f98: 30 00 20 00 2d 00 20 00 0. .-. .
01fa0: 30 00 30 00 30 00 30 00 0.0.0.0.
01fa8: 30 00 30 00 30 00 30 00 0.0.0.0.
01fb0: 37 00 31 00 61 00 39 00 7.1.a.9.
01fb8: 38 00 30 00 30 00 30 00 8.0.0.0.
01fc0: 3a 00 20 00 43 00 3a 00 :. .C.:.
01fc8: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01fd0: 44 00 4f 00 57 00 53 00 D.O.W.S.
01fd8: 5c 00 53 00 79 00 73 00 \.S.y.s.
01fe0: 74 00 65 00 6d 00 33 00 t.e.m.3.
01fe8: 32 00 5c 00 77 00 73 00 2.\.w.s.
01ff0: 68 00 74 00 63 00 70 00 h.t.c.p.
01ff8: 69 00 70 00 2e 00 64 00 i.p...d.
02000: 6c 00 6c 00 0d 00 0a 00 l.l.....
02008: 28 00 30 00 30 00 30 00 (.0.0.0.
02010: 30 00 30 00 30 00 30 00 0.0.0.0.
02018: 30 00 37 00 31 00 61 00 0.7.1.a.
02020: 61 00 30 00 30 00 30 00 a.0.0.0.
02028: 30 00 20 00 2d 00 20 00 0. .-. .
02030: 30 00 30 00 30 00 30 00 0.0.0.0.
02038: 30 00 30 00 30 00 30 00 0.0.0.0.
02040: 37 00 31 00 61 00 61 00 7.1.a.a.
02048: 38 00 30 00 30 00 30 00 8.0.0.0.
02050: 3a 00 20 00 43 00 3a 00 :. .C.:.
02058: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02060: 44 00 4f 00 57 00 53 00 D.O.W.S.
02068: 5c 00 73 00 79 00 73 00 \.s.y.s.
02070: 74 00 65 00 6d 00 33 00 t.e.m.3.
02078: 32 00 5c 00 57 00 53 00 2.\.W.S.
02080: 32 00 48 00 45 00 4c 00 2.H.E.L.
02088: 50 00 2e 00 64 00 6c 00 P...d.l.
02090: 6c 00 0d 00 0a 00 28 00 l.....(.
02098: 30 00 30 00 30 00 30 00 0.0.0.0.
020a0: 30 00 30 00 30 00 30 00 0.0.0.0.
020a8: 37 00 31 00 61 00 62 00 7.1.a.b.
020b0: 30 00 30 00 30 00 30 00 0.0.0.0.
020b8: 20 00 2d 00 20 00 30 00 .-. .0.
020c0: 30 00 30 00 30 00 30 00 0.0.0.0.
020c8: 30 00 30 00 30 00 37 00 0.0.0.7.
020d0: 31 00 61 00 63 00 37 00 1.a.c.7.
020d8: 30 00 30 00 30 00 3a 00 0.0.0.:.
020e0: 20 00 43 00 3a 00 5c 00 .C.:.\.
020e8: 57 00 49 00 4e 00 44 00 W.I.N.D.
020f0: 4f 00 57 00 53 00 5c 00 O.W.S.\.
020f8: 73 00 79 00 73 00 74 00 s.y.s.t.
02100: 65 00 6d 00 33 00 32 00 e.m.3.2.
02108: 5c 00 57 00 53 00 32 00 \.W.S.2.
02110: 5f 00 33 00 32 00 2e 00 _.3.2...
02118: 64 00 6c 00 6c 00 0d 00 d.l.l...
02120: 0a 00 28 00 30 00 30 00 ..(.0.0.
02128: 30 00 30 00 30 00 30 00 0.0.0.0.
02130: 30 00 30 00 37 00 31 00 0.0.7.1.
02138: 61 00 64 00 30 00 30 00 a.d.0.0.
02140: 30 00 30 00 20 00 2d 00 0.0. .-.
02148: 20 00 30 00 30 00 30 00 .0.0.0.
02150: 30 00 30 00 30 00 30 00 0.0.0.0.
02158: 30 00 37 00 31 00 61 00 0.7.1.a.
02160: 64 00 39 00 30 00 30 00 d.9.0.0.
02168: 30 00 3a 00 20 00 43 00 0.:. .C.
02170: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02178: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02180: 53 00 5c 00 73 00 79 00 S.\.s.y.
02188: 73 00 74 00 65 00 6d 00 s.t.e.m.
02190: 33 00 32 00 5c 00 77 00 3.2.\.w.
02198: 73 00 6f 00 63 00 6b 00 s.o.c.k.
021a0: 33 00 32 00 2e 00 64 00 3.2...d.
021a8: 6c 00 6c 00 0d 00 0a 00 l.l.....
021b0: 28 00 30 00 30 00 30 00 (.0.0.0.
021b8: 30 00 30 00 30 00 30 00 0.0.0.0.
021c0: 30 00 37 00 31 00 62 00 0.7.1.b.
021c8: 32 00 30 00 30 00 30 00 2.0.0.0.
021d0: 30 00 20 00 2d 00 20 00 0. .-. .
021d8: 30 00 30 00 30 00 30 00 0.0.0.0.
021e0: 30 00 30 00 30 00 30 00 0.0.0.0.
021e8: 37 00 31 00 62 00 33 00 7.1.b.3.
021f0: 32 00 30 00 30 00 30 00 2.0.0.0.
021f8: 3a 00 20 00 43 00 3a 00 :. .C.:.
02200: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02208: 44 00 4f 00 57 00 53 00 D.O.W.S.
02210: 5c 00 73 00 79 00 73 00 \.s.y.s.
02218: 74 00 65 00 6d 00 33 00 t.e.m.3.
02220: 32 00 5c 00 4d 00 50 00 2.\.M.P.
02228: 52 00 2e 00 64 00 6c 00 R...d.l.
02230: 6c 00 0d 00 0a 00 28 00 l.....(.
02238: 30 00 30 00 30 00 30 00 0.0.0.0.
02240: 30 00 30 00 30 00 30 00 0.0.0.0.
02248: 37 00 31 00 62 00 66 00 7.1.b.f.
02250: 30 00 30 00 30 00 30 00 0.0.0.0.
02258: 20 00 2d 00 20 00 30 00 .-. .0.
02260: 30 00 30 00 30 00 30 00 0.0.0.0.
02268: 30 00 30 00 30 00 37 00 0.0.0.7.
02270: 31 00 63 00 30 00 33 00 1.c.0.3.
02278: 30 00 30 00 30 00 3a 00 0.0.0.:.
02280: 20 00 43 00 3a 00 5c 00 .C.:.\.
02288: 57 00 49 00 4e 00 44 00 W.I.N.D.
02290: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02298: 53 00 79 00 73 00 74 00 S.y.s.t.
022a0: 65 00 6d 00 33 00 32 00 e.m.3.2.
022a8: 5c 00 53 00 41 00 4d 00 \.S.A.M.
022b0: 4c 00 49 00 42 00 2e 00 L.I.B...
022b8: 64 00 6c 00 6c 00 0d 00 d.l.l...
022c0: 0a 00 28 00 30 00 30 00 ..(.0.0.
022c8: 30 00 30 00 30 00 30 00 0.0.0.0.
022d0: 30 00 30 00 37 00 31 00 0.0.7.1.
022d8: 63 00 31 00 30 00 30 00 c.1.0.0.
022e0: 30 00 30 00 20 00 2d 00 0.0. .-.
022e8: 20 00 30 00 30 00 30 00 .0.0.0.
022f0: 30 00 30 00 30 00 30 00 0.0.0.0.
022f8: 30 00 37 00 31 00 63 00 0.7.1.c.
02300: 31 00 65 00 30 00 30 00 1.e.0.0.
02308: 30 00 3a 00 20 00 43 00 0.:. .C.
02310: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02318: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02320: 53 00 5c 00 53 00 79 00 S.\.S.y.
02328: 73 00 74 00 65 00 6d 00 s.t.e.m.
02330: 33 00 32 00 5c 00 6e 00 3.2.\.n.
02338: 74 00 6c 00 61 00 6e 00 t.l.a.n.
02340: 6d 00 61 00 6e 00 2e 00 m.a.n...
02348: 64 00 6c 00 6c 00 0d 00 d.l.l...
02350: 0a 00 28 00 30 00 30 00 ..(.0.0.
02358: 30 00 30 00 30 00 30 00 0.0.0.0.
02360: 30 00 30 00 37 00 31 00 0.0.7.1.
02368: 63 00 38 00 30 00 30 00 c.8.0.0.
02370: 30 00 30 00 20 00 2d 00 0.0. .-.
02378: 20 00 30 00 30 00 30 00 .0.0.0.
02380: 30 00 30 00 30 00 30 00 0.0.0.0.
02388: 30 00 37 00 31 00 63 00 0.7.1.c.
02390: 38 00 37 00 30 00 30 00 8.7.0.0.
02398: 30 00 3a 00 20 00 43 00 0.:. .C.
023a0: 3a 00 5c 00 57 00 49 00 :.\.W.I.
023a8: 4e 00 44 00 4f 00 57 00 N.D.O.W.
023b0: 53 00 5c 00 53 00 79 00 S.\.S.y.
023b8: 73 00 74 00 65 00 6d 00 s.t.e.m.
023c0: 33 00 32 00 5c 00 4e 00 3.2.\.N.
023c8: 45 00 54 00 52 00 41 00 E.T.R.A.
023d0: 50 00 2e 00 64 00 6c 00 P...d.l.
023d8: 6c 00 0d 00 0a 00 28 00 l.....(.
023e0: 30 00 30 00 30 00 30 00 0.0.0.0.
023e8: 30 00 30 00 30 00 30 00 0.0.0.0.
023f0: 37 00 31 00 63 00 39 00 7.1.c.9.
023f8: 30 00 30 00 30 00 30 00 0.0.0.0.
02400: 20 00 2d 00 20 00 30 00 .-. .0.
02408: 30 00 30 00 30 00 30 00 0.0.0.0.
02410: 30 00 30 00 30 00 37 00 0.0.0.7.
02418: 31 00 63 00 64 00 30 00 1.c.d.0.
02420: 30 00 30 00 30 00 3a 00 0.0.0.:.
02428: 20 00 43 00 3a 00 5c 00 .C.:.\.
02430: 57 00 49 00 4e 00 44 00 W.I.N.D.
02438: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02440: 53 00 79 00 73 00 74 00 S.y.s.t.
02448: 65 00 6d 00 33 00 32 00 e.m.3.2.
02450: 5c 00 4e 00 45 00 54 00 \.N.E.T.
02458: 55 00 49 00 31 00 2e 00 U.I.1...
02460: 64 00 6c 00 6c 00 0d 00 d.l.l...
02468: 0a 00 28 00 30 00 30 00 ..(.0.0.
02470: 30 00 30 00 30 00 30 00 0.0.0.0.
02478: 30 00 30 00 37 00 31 00 0.0.7.1.
02480: 63 00 64 00 30 00 30 00 c.d.0.0.
02488: 30 00 30 00 20 00 2d 00 0.0. .-.
02490: 20 00 30 00 30 00 30 00 .0.0.0.
02498: 30 00 30 00 30 00 30 00 0.0.0.0.
024a0: 30 00 37 00 31 00 63 00 0.7.1.c.
024a8: 65 00 37 00 30 00 30 00 e.7.0.0.
024b0: 30 00 3a 00 20 00 43 00 0.:. .C.
024b8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
024c0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
024c8: 53 00 5c 00 53 00 79 00 S.\.S.y.
024d0: 73 00 74 00 65 00 6d 00 s.t.e.m.
024d8: 33 00 32 00 5c 00 4e 00 3.2.\.N.
024e0: 45 00 54 00 55 00 49 00 E.T.U.I.
024e8: 30 00 2e 00 64 00 6c 00 0...d.l.
024f0: 6c 00 0d 00 0a 00 28 00 l.....(.
024f8: 30 00 30 00 30 00 30 00 0.0.0.0.
02500: 30 00 30 00 30 00 30 00 0.0.0.0.
02508: 37 00 32 00 32 00 38 00 7.2.2.8.
02510: 30 00 30 00 30 00 30 00 0.0.0.0.
02518: 20 00 2d 00 20 00 30 00 .-. .0.
02520: 30 00 30 00 30 00 30 00 0.0.0.0.
02528: 30 00 30 00 30 00 37 00 0.0.0.7.
02530: 32 00 32 00 61 00 61 00 2.2.a.a.
02538: 30 00 30 00 30 00 3a 00 0.0.0.:.
02540: 20 00 43 00 3a 00 5c 00 .C.:.\.
02548: 57 00 49 00 4e 00 44 00 W.I.N.D.
02550: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02558: 73 00 79 00 73 00 74 00 s.y.s.t.
02560: 65 00 6d 00 33 00 32 00 e.m.3.2.
02568: 5c 00 44 00 49 00 4e 00 \.D.I.N.
02570: 50 00 55 00 54 00 2e 00 P.U.T...
02578: 44 00 4c 00 4c 00 0d 00 D.L.L...
02580: 0a 00 28 00 30 00 30 00 ..(.0.0.
02588: 30 00 30 00 30 00 30 00 0.0.0.0.
02590: 30 00 30 00 37 00 32 00 0.0.7.2.
02598: 32 00 62 00 30 00 30 00 2.b.0.0.
025a0: 30 00 30 00 20 00 2d 00 0.0. .-.
025a8: 20 00 30 00 30 00 30 00 .0.0.0.
025b0: 30 00 30 00 30 00 30 00 0.0.0.0.
025b8: 30 00 37 00 32 00 32 00 0.7.2.2.
025c0: 62 00 35 00 30 00 30 00 b.5.0.0.
025c8: 30 00 3a 00 20 00 43 00 0.:. .C.
025d0: 3a 00 5c 00 57 00 49 00 :.\.W.I.
025d8: 4e 00 44 00 4f 00 57 00 N.D.O.W.
025e0: 53 00 5c 00 73 00 79 00 S.\.s.y.
025e8: 73 00 74 00 65 00 6d 00 s.t.e.m.
025f0: 33 00 32 00 5c 00 73 00 3.2.\.s.
025f8: 65 00 6e 00 73 00 61 00 e.n.s.a.
02600: 70 00 69 00 2e 00 64 00 p.i...d.
02608: 6c 00 6c 00 0d 00 0a 00 l.l.....
02610: 28 00 30 00 30 00 30 00 (.0.0.0.
02618: 30 00 30 00 30 00 30 00 0.0.0.0.
02620: 30 00 37 00 32 00 64 00 0.7.2.d.
02628: 31 00 30 00 30 00 30 00 1.0.0.0.
02630: 30 00 20 00 2d 00 20 00 0. .-. .
02638: 30 00 30 00 30 00 30 00 0.0.0.0.
02640: 30 00 30 00 30 00 30 00 0.0.0.0.
02648: 37 00 32 00 64 00 31 00 7.2.d.1.
02650: 38 00 30 00 30 00 30 00 8.0.0.0.
02658: 3a 00 20 00 43 00 3a 00 :. .C.:.
02660: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02668: 44 00 4f 00 57 00 53 00 D.O.W.S.
02670: 5c 00 73 00 79 00 73 00 \.s.y.s.
02678: 74 00 65 00 6d 00 33 00 t.e.m.3.
02680: 32 00 5c 00 6d 00 73 00 2.\.m.s.
02688: 61 00 63 00 6d 00 33 00 a.c.m.3.
02690: 32 00 2e 00 64 00 72 00 2...d.r.
02698: 76 00 0d 00 0a 00 28 00 v.....(.
026a0: 30 00 30 00 30 00 30 00 0.0.0.0.
026a8: 30 00 30 00 30 00 30 00 0.0.0.0.
026b0: 37 00 32 00 64 00 32 00 7.2.d.2.
026b8: 30 00 30 00 30 00 30 00 0.0.0.0.
026c0: 20 00 2d 00 20 00 30 00 .-. .0.
026c8: 30 00 30 00 30 00 30 00 0.0.0.0.
026d0: 30 00 30 00 30 00 37 00 0.0.0.7.
026d8: 32 00 64 00 32 00 39 00 2.d.2.9.
026e0: 30 00 30 00 30 00 3a 00 0.0.0.:.
026e8: 20 00 43 00 3a 00 5c 00 .C.:.\.
026f0: 57 00 49 00 4e 00 44 00 W.I.N.D.
026f8: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02700: 73 00 79 00 73 00 74 00 s.y.s.t.
02708: 65 00 6d 00 33 00 32 00 e.m.3.2.
02710: 5c 00 77 00 64 00 6d 00 \.w.d.m.
02718: 61 00 75 00 64 00 2e 00 a.u.d...
02720: 64 00 72 00 76 00 0d 00 d.r.v...
02728: 0a 00 28 00 30 00 30 00 ..(.0.0.
02730: 30 00 30 00 30 00 30 00 0.0.0.0.
02738: 30 00 30 00 37 00 33 00 0.0.7.3.
02740: 30 00 30 00 30 00 30 00 0.0.0.0.
02748: 30 00 30 00 20 00 2d 00 0.0. .-.
02750: 20 00 30 00 30 00 30 00 .0.0.0.
02758: 30 00 30 00 30 00 30 00 0.0.0.0.
02760: 30 00 37 00 33 00 30 00 0.7.3.0.
02768: 32 00 36 00 30 00 30 00 2.6.0.0.
02770: 30 00 3a 00 20 00 43 00 0.:. .C.
02778: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02780: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02788: 53 00 5c 00 73 00 79 00 S.\.s.y.
02790: 73 00 74 00 65 00 6d 00 s.t.e.m.
02798: 33 00 32 00 5c 00 57 00 3.2.\.W.
027a0: 49 00 4e 00 53 00 50 00 I.N.S.P.
027a8: 4f 00 4f 00 4c 00 2e 00 O.O.L...
027b0: 44 00 52 00 56 00 0d 00 D.R.V...
027b8: 0a 00 28 00 30 00 30 00 ..(.0.0.
027c0: 30 00 30 00 30 00 30 00 0.0.0.0.
027c8: 30 00 30 00 37 00 33 00 0.0.7.3.
027d0: 62 00 35 00 30 00 30 00 b.5.0.0.
027d8: 30 00 30 00 20 00 2d 00 0.0. .-.
027e0: 20 00 30 00 30 00 30 00 .0.0.0.
027e8: 30 00 30 00 30 00 30 00 0.0.0.0.
027f0: 30 00 37 00 33 00 62 00 0.7.3.b.
027f8: 36 00 37 00 30 00 30 00 6.7.0.0.
02800: 30 00 3a 00 20 00 43 00 0.:. .C.
02808: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02810: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02818: 53 00 5c 00 73 00 79 00 S.\.s.y.
02820: 73 00 74 00 65 00 6d 00 s.t.e.m.
02828: 33 00 32 00 5c 00 41 00 3.2.\.A.
02830: 56 00 49 00 46 00 49 00 V.I.F.I.
02838: 4c 00 33 00 32 00 2e 00 L.3.2...
02840: 64 00 6c 00 6c 00 0d 00 d.l.l...
02848: 0a 00 28 00 30 00 30 00 ..(.0.0.
02850: 30 00 30 00 30 00 30 00 0.0.0.0.
02858: 30 00 30 00 37 00 33 00 0.0.7.3.
02860: 62 00 61 00 30 00 30 00 b.a.0.0.
02868: 30 00 30 00 20 00 2d 00 0.0. .-.
02870: 20 00 30 00 30 00 30 00 .0.0.0.
02878: 30 00 30 00 30 00 30 00 0.0.0.0.
02880: 30 00 37 00 33 00 62 00 0.7.3.b.
02888: 62 00 33 00 30 00 30 00 b.3.0.0.
02890: 30 00 3a 00 20 00 43 00 0.:. .C.
02898: 3a 00 5c 00 57 00 49 00 :.\.W.I.
028a0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
028a8: 53 00 5c 00 73 00 79 00 S.\.s.y.
028b0: 73 00 74 00 65 00 6d 00 s.t.e.m.
028b8: 33 00 32 00 5c 00 73 00 3.2.\.s.
028c0: 74 00 69 00 2e 00 64 00 t.i...d.
028c8: 6c 00 6c 00 0d 00 0a 00 l.l.....
028d0: 28 00 30 00 30 00 30 00 (.0.0.0.
028d8: 30 00 30 00 30 00 30 00 0.0.0.0.
028e0: 30 00 37 00 33 00 64 00 0.7.3.d.
028e8: 37 00 30 00 30 00 30 00 7.0.0.0.
028f0: 30 00 20 00 2d 00 20 00 0. .-. .
028f8: 30 00 30 00 30 00 30 00 0.0.0.0.
02900: 30 00 30 00 30 00 30 00 0.0.0.0.
02908: 37 00 33 00 64 00 38 00 7.3.d.8.
02910: 33 00 30 00 30 00 30 00 3.0.0.0.
02918: 3a 00 20 00 43 00 3a 00 :. .C.:.
02920: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02928: 44 00 4f 00 57 00 53 00 D.O.W.S.
02930: 5c 00 73 00 79 00 73 00 \.s.y.s.
02938: 74 00 65 00 6d 00 33 00 t.e.m.3.
02940: 32 00 5c 00 73 00 68 00 2.\.s.h.
02948: 67 00 69 00 6e 00 61 00 g.i.n.a.
02950: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
02958: 0d 00 0a 00 28 00 30 00 ....(.0.
02960: 30 00 30 00 30 00 30 00 0.0.0.0.
02968: 30 00 30 00 30 00 37 00 0.0.0.7.
02970: 33 00 65 00 65 00 30 00 3.e.e.0.
02978: 30 00 30 00 30 00 20 00 0.0.0. .
02980: 2d 00 20 00 30 00 30 00 -. .0.0.
02988: 30 00 30 00 30 00 30 00 0.0.0.0.
02990: 30 00 30 00 37 00 33 00 0.0.7.3.
02998: 65 00 65 00 34 00 30 00 e.e.4.0.
029a0: 30 00 30 00 3a 00 20 00 0.0.:. .
029a8: 43 00 3a 00 5c 00 57 00 C.:.\.W.
029b0: 49 00 4e 00 44 00 4f 00 I.N.D.O.
029b8: 57 00 53 00 5c 00 73 00 W.S.\.s.
029c0: 79 00 73 00 74 00 65 00 y.s.t.e.
029c8: 6d 00 33 00 32 00 5c 00 m.3.2.\.
029d0: 4b 00 73 00 55 00 73 00 K.s.U.s.
029d8: 65 00 72 00 2e 00 64 00 e.r...d.
029e0: 6c 00 6c 00 0d 00 0a 00 l.l.....
029e8: 28 00 30 00 30 00 30 00 (.0.0.0.
029f0: 30 00 30 00 30 00 30 00 0.0.0.0.
029f8: 30 00 37 00 33 00 66 00 0.7.3.f.
02a00: 31 00 30 00 30 00 30 00 1.0.0.0.
02a08: 30 00 20 00 2d 00 20 00 0. .-. .
02a10: 30 00 30 00 30 00 30 00 0.0.0.0.
02a18: 30 00 30 00 30 00 30 00 0.0.0.0.
02a20: 37 00 33 00 66 00 36 00 7.3.f.6.
02a28: 63 00 30 00 30 00 30 00 c.0.0.0.
02a30: 3a 00 20 00 43 00 3a 00 :. .C.:.
02a38: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02a40: 44 00 4f 00 57 00 53 00 D.O.W.S.
02a48: 5c 00 73 00 79 00 73 00 \.s.y.s.
02a50: 74 00 65 00 6d 00 33 00 t.e.m.3.
02a58: 32 00 5c 00 44 00 53 00 2.\.D.S.
02a60: 4f 00 55 00 4e 00 44 00 O.U.N.D.
02a68: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
02a70: 0d 00 0a 00 28 00 30 00 ....(.0.
02a78: 30 00 30 00 30 00 30 00 0.0.0.0.
02a80: 30 00 30 00 30 00 37 00 0.0.0.7.
02a88: 34 00 33 00 32 00 30 00 4.3.2.0.
02a90: 30 00 30 00 30 00 20 00 0.0.0. .
02a98: 2d 00 20 00 30 00 30 00 -. .0.0.
02aa0: 30 00 30 00 30 00 30 00 0.0.0.0.
02aa8: 30 00 30 00 37 00 34 00 0.0.7.4.
02ab0: 33 00 35 00 64 00 30 00 3.5.d.0.
02ab8: 30 00 30 00 3a 00 20 00 0.0.:. .
02ac0: 43 00 3a 00 5c 00 57 00 C.:.\.W.
02ac8: 49 00 4e 00 44 00 4f 00 I.N.D.O.
02ad0: 57 00 53 00 5c 00 73 00 W.S.\.s.
02ad8: 79 00 73 00 74 00 65 00 y.s.t.e.
02ae0: 6d 00 33 00 32 00 5c 00 m.3.2.\.
02ae8: 4f 00 44 00 42 00 43 00 O.D.B.C.
02af0: 33 00 32 00 2e 00 64 00 3.2...d.
02af8: 6c 00 6c 00 0d 00 0a 00 l.l.....
02b00: 28 00 30 00 30 00 30 00 (.0.0.0.
02b08: 30 00 30 00 30 00 30 00 0.0.0.0.
02b10: 30 00 37 00 34 00 37 00 0.7.4.7.
02b18: 32 00 30 00 30 00 30 00 2.0.0.0.
02b20: 30 00 20 00 2d 00 20 00 0. .-. .
02b28: 30 00 30 00 30 00 30 00 0.0.0.0.
02b30: 30 00
I forgot to say something. When vdj have closed, strongDC (peer to peer program) has closed too. And one of my 2 external hdd was blocked. The strongDC program downloads file tu that hdd. Could be this (blocked hdd) the problem? The hdd is a maxtor hdd, sata,300GB, 16mb cache, and I have this adaptor http://www.scythe-eu.com/en/products/pc-accessory/kama-connect-2.html that I use for connection with laptop. Once in a while i get no response from it.
ps: I have to mention that this was the only time when vdj have crashed AND the adaptor was blocked.
Thank you for the report. It will be analysed.
I've just had another crash. This time everything is ok but vdj. I have a picture with the message that has appeard:
The event viewer says: application error no.1
Event Type: Error
Event ID: 1000
Date: 07.10.2009
Time: 18:28:48
User: N/A
Computer: MOBILE
Description:
Data:
0058: 0d 0a ..
application error no.2
Event Type: Error
Event ID: 1001
Date: 07.10.2009
Time: 18:36:50
User: N/A
Computer: MOBILE
Description:
Fault bucket 1303406168.
Data:
0000: 42 75 63 6b 65 74 3a 20 Bucket:
0008: 31 33 30 33 34 30 36 31 13034061
0010: 36 38 0d 0a 68..
Dr Watson says:
Event ID: 4097
Date: 07.10.2009
Time: 18:36:51
User: N/A
Computer: MOBILE
Description:
The application, C:\Program Files\VirtualDJ\virtualdj.exe, generated an application error The error occurred on 10/07/2009 @ 18:36:51.000 The exception generated was c0000005 at address 7C91B21A (ntdll!RtlpWaitForCriticalSection)
Data:
000c0: 32 00 31 00 39 00 36 00 2.1.9.6.
000e8: 20 00 30 00 37 00 2e 00 .0.7...
00100: 40 00 20 00 31 00 38 00 @. .1.8.
00108: 3a 00 33 00 36 00 3a 00 :.3.6.:.
00110: 35 00 31 00 2e 00 30 00 5.1...0.
00118: 30 00 30 00 0d 00 0a 00 0.0.....
00568: 31 00 30 00 36 00 30 00 1.0.6.0.
00588: 31 00 30 00 39 00 32 00 1.0.9.2.
005b0: 31 00 33 00 36 00 20 00 1.3.6. .
005d8: 34 00 38 00 20 00 6c 00 4.8. .l.
005f8: 30 00 38 00 20 00 41 00 0.8. .A.
00618: 0a 00 31 00 33 00 32 00 ..1.3.2.
00620: 38 00 20 00 73 00 76 00 8. .s.v.
00688: 35 00 30 00 38 00 20 00 5.0.8. .
006a8: 31 00 35 00 36 00 30 00 1.5.6.0.
006d0: 38 00 30 00 34 00 20 00 8.0.4. .
006f8: 31 00 32 00 20 00 53 00 1.2. .S.
00720: 32 00 20 00 73 00 76 00 2. .s.v.
00740: 31 00 38 00 34 00 20 00 1.8.4. .
00760: 0a 00 20 00 34 00 34 00 .. .4.4.
00768: 34 00 20 00 73 00 70 00 4. .s.p.
00788: 34 00 39 00 36 00 20 00 4.9.6. .
007b0: 33 00 36 00 20 00 73 00 3.6. .s.
007d0: 20 00 36 00 30 00 30 00 .6.0.0.
00810: 36 00 33 00 36 00 20 00 6.3.6. .
00830: 36 00 20 00 52 00 65 00 6. .R.e.
00850: 39 00 33 00 36 00 20 00 9.3.6. .
00870: 0a 00 20 00 39 00 37 00 .. .9.7.
00878: 32 00 20 00 54 00 65 00 2. .T.e.
008b0: 39 00 36 00 20 00 77 00 9.6. .w.
008d0: 36 00 36 00 30 00 20 00 6.6.0. .
008f8: 32 00 30 00 33 00 36 00 2.0.3.6.
00900: 20 00 77 00 6d 00 69 00 .w.m.i.
00908: 70 00 72 00 76 00 73 00 p.r.v.s.
00910: 65 00 2e 00 65 00 78 00 e...e.x.
00918: 65 00 0d 00 0a 00 32 00 e.....2.
00920: 34 00 31 00 36 00 20 00 4.1.6. .
00928: 61 00 6c 00 67 00 2e 00 a.l.g...
00938: 0a 00 32 00 36 00 32 00 ..2.6.2.
00940: 34 00 20 00 48 00 43 00 4. .H.C.
00948: 6f 00 6e 00 74 00 72 00 o.n.t.r.
00950: 6f 00 6c 00 2e 00 65 00 o.l...e.
00958: 78 00 65 00 0d 00 0a 00 x.e.....
00960: 32 00 36 00 39 00 36 00 2.6.9.6.
00968: 20 00 52 00 54 00 48 00 .R.T.H.
00970: 44 00 43 00 50 00 4c 00 D.C.P.L.
00978: 2e 00 45 00 58 00 45 00 ..E.X.E.
00980: 0d 00 0a 00 32 00 37 00 ....2.7.
00988: 32 00 30 00 20 00 73 00 2.0. .s.
00990: 6d 00 35 00 36 00 68 00 m.5.6.h.
00998: 6c 00 70 00 72 00 2e 00 l.p.r...
009a0: 65 00 78 00 65 00 0d 00 e.x.e...
009a8: 0a 00 32 00 37 00 32 00 ..2.7.2.
009b0: 38 00 20 00 43 00 4c 00 8. .C.L.
009b8: 49 00 2e 00 45 00 58 00 I...E.X.
009c0: 45 00 0d 00 0a 00 32 00 E.....2.
009c8: 37 00 33 00 36 00 20 00 7.3.6. .
009d0: 41 00 70 00 6f 00 69 00 A.p.o.i.
009d8: 6e 00 74 00 2e 00 65 00 n.t...e.
009e0: 78 00 65 00 0d 00 0a 00 x.e.....
009e8: 32 00 37 00 36 00 30 00 2.7.6.0.
009f0: 20 00 5a 00 43 00 66 00 .Z.C.f.
009f8: 67 00 53 00 76 00 63 00 g.S.v.c.
00a10: 37 00 32 00 20 00 69 00 7.2. .i.
00a18: 66 00 72 00 6d 00 65 00 f.r.m.e.
00a20: 77 00 72 00 6b 00 2e 00 w.r.k...
00a30: 0a 00 32 00 37 00 38 00 ..2.7.8.
00a38: 30 00 20 00 77 00 63 00 0. .w.c.
00a40: 6f 00 75 00 72 00 69 00 o.u.r.i.
00a48: 65 00 72 00 2e 00 65 00 e.r...e.
00a50: 78 00 65 00 0d 00 0a 00 x.e.....
00a58: 32 00 37 00 38 00 38 00 2.7.8.8.
00a60: 20 00 4c 00 43 00 4d 00 .L.C.M.
00a68: 50 00 2e 00 45 00 58 00 P...E.X.
00a70: 45 00 0d 00 0a 00 32 00 E.....2.
00a78: 38 00 35 00 32 00 20 00 8.5.2. .
00a80: 56 00 6f 00 6c 00 50 00 V.o.l.P.
00a88: 61 00 6e 00 6c 00 75 00 a.n.l.u.
00a90: 2e 00 65 00 78 00 65 00 ..e.x.e.
00a98: 0d 00 0a 00 32 00 38 00 ....2.8.
00aa0: 36 00 38 00 20 00 52 00 6.8. .R.
00aa8: 75 00 6e 00 64 00 6c 00 u.n.d.l.
00ab0: 6c 00 33 00 32 00 2e 00 l.3.2...
00ab8: 65 00 78 00 65 00 0d 00 e.x.e...
00ac0: 0a 00 32 00 39 00 33 00 ..2.9.3.
00ac8: 36 00 20 00 6a 00 75 00 6. .j.u.
00ad0: 73 00 63 00 68 00 65 00 s.c.h.e.
00ad8: 64 00 2e 00 65 00 78 00 d...e.x.
00ae0: 65 00 0d 00 0a 00 32 00 e.....2.
00ae8: 39 00 35 00 32 00 20 00 9.5.2. .
00af0: 77 00 69 00 6e 00 61 00 w.i.n.a.
00af8: 6d 00 70 00 61 00 2e 00 m.p.a...
00b00: 65 00 78 00 65 00 0d 00 e.x.e...
00b08: 0a 00 33 00 30 00 34 00 ..3.0.4.
00b10: 38 00 20 00 4f 00 55 00 8. .O.U.
00b18: 54 00 4c 00 4f 00 4f 00 T.L.O.O.
00b20: 4b 00 2e 00 45 00 58 00 K...E.X.
00b28: 45 00 0d 00 0a 00 33 00 E.....3.
00b30: 30 00 36 00 38 00 20 00 0.6.8. .
00b38: 59 00 41 00 48 00 4f 00 Y.A.H.O.
00b40: 4f 00 4d 00 7e 00 31 00 O.M.~.1.
00b48: 2e 00 45 00 58 00 45 00 ..E.X.E.
00b50: 0d 00 0a 00 33 00 30 00 ....3.0.
00b58: 38 00 30 00 20 00 63 00 8.0. .c.
00b60: 74 00 66 00 6d 00 6f 00 t.f.m.o.
00b68: 6e 00 2e 00 65 00 78 00 n...e.x.
00b70: 65 00 0d 00 0a 00 33 00 e.....3.
00b78: 31 00 31 00 36 00 20 00 1.1.6. .
00b80: 50 00 43 00 53 00 75 00 P.C.S.u.
00b88: 69 00 74 00 65 00 2e 00 i.t.e...
00b90: 65 00 78 00 65 00 0d 00 e.x.e...
00b98: 0a 00 33 00 32 00 32 00 ..3.2.2.
00ba0: 30 00 20 00 54 00 6f 00 0. .T.o.
00ba8: 73 00 42 00 74 00 4d 00 s.B.t.M.
00bb0: 6e 00 67 00 2e 00 65 00 n.g...e.
00bb8: 78 00 65 00 0d 00 0a 00 x.e.....
00bc0: 33 00 32 00 38 00 30 00 3.2.8.0.
00bc8: 20 00 54 00 6f 00 73 00 .T.o.s.
00bd0: 41 00 32 00 64 00 70 00 A.2.d.p.
00bd8: 2e 00 65 00 78 00 65 00 ..e.x.e.
00be0: 0d 00 0a 00 33 00 32 00 ....3.2.
00be8: 39 00 32 00 20 00 41 00 9.2. .A.
00bf0: 70 00 6e 00 74 00 65 00 p.n.t.e.
00bf8: 78 00 2e 00 65 00 78 00 x...e.x.
00c00: 65 00 0d 00 0a 00 33 00 e.....3.
00c08: 33 00 30 00 34 00 20 00 3.0.4. .
00c10: 48 00 69 00 64 00 46 00 H.i.d.F.
00c18: 69 00 6e 00 64 00 2e 00 i.n.d...
00c20: 65 00 78 00 65 00 0d 00 e.x.e...
00c28: 0a 00 33 00 33 00 32 00 ..3.3.2.
00c30: 30 00 20 00 54 00 6f 00 0. .T.o.
00c38: 73 00 42 00 74 00 48 00 s.B.t.H.
00c40: 69 00 64 00 2e 00 65 00 i.d...e.
00c48: 78 00 65 00 0d 00 0a 00 x.e.....
00c50: 33 00 33 00 33 00 36 00 3.3.3.6.
00c58: 20 00 41 00 70 00 76 00 .A.p.v.
00c60: 66 00 62 00 2e 00 65 00 f.b...e.
00c68: 78 00 65 00 0d 00 0a 00 x.e.....
00c70: 33 00 33 00 38 00 38 00 3.3.8.8.
00c78: 20 00 54 00 6f 00 73 00 .T.o.s.
00c80: 42 00 74 00 48 00 73 00 B.t.H.s.
00c88: 70 00 2e 00 65 00 78 00 p...e.x.
00c90: 65 00 0d 00 0a 00 33 00 e.....3.
00c98: 38 00 30 00 34 00 20 00 8.0.4. .
00ca0: 53 00 65 00 72 00 76 00 S.e.r.v.
00ca8: 69 00 63 00 65 00 4c 00 i.c.e.L.
00cb0: 61 00 79 00 65 00 72 00 a.y.e.r.
00cb8: 2e 00 65 00 78 00 65 00 ..e.x.e.
00cc0: 0d 00 0a 00 20 00 38 00 .... .8.
00cc8: 34 00 38 00 20 00 63 00 4.8. .c.
00cd0: 6c 00 69 00 2e 00 65 00 l.i...e.
00cd8: 78 00 65 00 0d 00 0a 00 x.e.....
00ce0: 32 00 39 00 37 00 32 00 2.9.7.2.
00ce8: 20 00 63 00 6c 00 69 00 .c.l.i.
00cf0: 2e 00 65 00 78 00 65 00 ..e.x.e.
00cf8: 0d 00 0a 00 20 00 38 00 .... .8.
00d00: 33 00 36 00 20 00 4e 00 3.6. .N.
00d08: 63 00 6c 00 55 00 53 00 c.l.U.S.
00d10: 42 00 53 00 72 00 76 00 B.S.r.v.
00d18: 2e 00 65 00 78 00 65 00 ..e.x.e.
00d20: 0d 00 0a 00 20 00 38 00 .... .8.
00d28: 32 00 30 00 20 00 4e 00 2.0. .N.
00d30: 63 00 6c 00 52 00 53 00 c.l.R.S.
00d38: 53 00 72 00 76 00 2e 00 S.r.v...
00d40: 65 00 78 00 65 00 0d 00 e.x.e...
00d48: 0a 00 33 00 31 00 34 00 ..3.1.4.
00d50: 30 00 20 00 4e 00 63 00 0. .N.c.
00d58: 6c 00 54 00 6f 00 42 00 l.T.o.B.
00d60: 54 00 53 00 72 00 76 00 T.S.r.v.
00d68: 2e 00 65 00 78 00 65 00 ..e.x.e.
00d70: 0d 00 0a 00 33 00 32 00 ....3.2.
00d78: 34 00 34 00 20 00 41 00 4.4. .A.
00d80: 54 00 4b 00 4f 00 53 00 T.K.O.S.
00d88: 44 00 2e 00 65 00 78 00 D...e.x.
00d90: 65 00 0d 00 0a 00 31 00 e.....1.
00d98: 38 00 34 00 38 00 20 00 8.4.8. .
00da0: 44 00 6f 00 74 00 31 00 D.o.t.1.
00da8: 58 00 43 00 66 00 67 00 X.C.f.g.
00db0: 2e 00 65 00 78 00 65 00 ..e.x.e.
00db8: 0d 00 0a 00 32 00 35 00 ....2.5.
00dc0: 30 00 38 00 20 00 66 00 0.8. .f.
00dc8: 69 00 72 00 65 00 66 00 i.r.e.f.
00dd0: 6f 00 78 00 2e 00 65 00 o.x...e.
00dd8: 78 00 65 00 0d 00 0a 00 x.e.....
00de0: 32 00 33 00 39 00 36 00 2.3.9.6.
00de8: 20 00 54 00 4f 00 54 00 .T.O.T.
00df0: 41 00 4c 00 43 00 4d 00 A.L.C.M.
00df8: 44 00 2e 00 45 00 58 00 D...E.X.
00e00: 45 00 0d 00 0a 00 32 00 E.....2.
00e08: 36 00 38 00 30 00 20 00 6.8.0. .
00e10: 77 00 69 00 6e 00 61 00 w.i.n.a.
00e18: 6d 00 70 00 2e 00 65 00 m.p...e.
00e20: 78 00 65 00 0d 00 0a 00 x.e.....
00e28: 32 00 31 00 33 00 32 00 2.1.3.2.
00e30: 20 00 53 00 74 00 72 00 .S.t.r.
00e38: 6f 00 6e 00 67 00 44 00 o.n.g.D.
00e40: 43 00 2e 00 65 00 78 00 C...e.x.
00e48: 65 00 0d 00 0a 00 32 00 e.....2.
00e50: 31 00 39 00 36 00 20 00 1.9.6. .
00e58: 76 00 69 00 72 00 74 00 v.i.r.t.
00e60: 75 00 61 00 6c 00 64 00 u.a.l.d.
00e68: 6a 00 2e 00 65 00 78 00 j...e.x.
00e70: 65 00 0d 00 0a 00 20 00 e..... .
00e78: 32 00 37 00 36 00 20 00 2.7.6. .
00e80: 64 00 77 00 77 00 69 00 d.w.w.i.
00e88: 6e 00 2e 00 65 00 78 00 n...e.x.
00e90: 65 00 0d 00 0a 00 33 00 e.....3.
00e98: 35 00 33 00 32 00 20 00 5.3.2. .
00ea0: 6d 00 73 00 70 00 61 00 m.s.p.a.
00ea8: 69 00 6e 00 74 00 2e 00 i.n.t...
00eb0: 65 00 78 00 65 00 0d 00 e.x.e...
00eb8: 0a 00 32 00 39 00 32 00 ..2.9.2.
00ec0: 30 00 20 00 41 00 43 00 0. .A.C.
00ec8: 44 00 53 00 65 00 65 00 D.S.e.e.
00ed0: 51 00 56 00 2e 00 65 00 Q.V...e.
00ed8: 78 00 65 00 0d 00 0a 00 x.e.....
00ee0: 31 00 37 00 32 00 30 00 1.7.2.0.
00ee8: 20 00 64 00 72 00 77 00 .d.r.w.
00ef0: 74 00 73 00 6e 00 33 00 t.s.n.3.
00ef8: 32 00 2e 00 65 00 78 00 2...e.x.
00f00: 65 00 0d 00 0a 00 0d 00 e.......
00f08: 0a 00 2a 00 2d 00 2d 00 ..*.-.-.
00f10: 2d 00 2d 00 3e 00 20 00 -.-.>. .
00f18: 4d 00 6f 00 64 00 75 00 M.o.d.u.
00f20: 6c 00 65 00 20 00 4c 00 l.e. .L.
00f28: 69 00 73 00 74 00 20 00 i.s.t. .
00f30: 3c 00 2d 00 2d 00 2d 00 <.-.-.-.
00f38: 2d 00 2a 00 0d 00 0a 00 -.*.....
00f40: 28 00 30 00 30 00 30 00 (.0.0.0.
00f50: 30 00 30 00 30 00 34 00 0.0.0.4.
00f58: 30 00 30 00 30 00 30 00 0.0.0.0.
00f60: 30 00 20 00 2d 00 20 00 0. .-. .
00f68: 30 00 30 00 30 00 30 00 0.0.0.0.
00f78: 30 00 31 00 31 00 62 00 0.1.1.b.
00f80: 36 00 30 00 30 00 30 00 6.0.0.0.
00f88: 3a 00 20 00 43 00 3a 00 :. .C.:.
00f90: 5c 00 50 00 72 00 6f 00 \.P.r.o.
00f98: 67 00 72 00 61 00 6d 00 g.r.a.m.
00fa0: 20 00 46 00 69 00 6c 00 .F.i.l.
00fa8: 65 00 73 00 5c 00 56 00 e.s.\.V.
00fb0: 69 00 72 00 74 00 75 00 i.r.t.u.
00fb8: 61 00 6c 00 44 00 4a 00 a.l.D.J.
00fc0: 5c 00 76 00 69 00 72 00 \.v.i.r.
00fc8: 74 00 75 00 61 00 6c 00 t.u.a.l.
00fd0: 64 00 6a 00 2e 00 65 00 d.j...e.
00fd8: 78 00 65 00 0d 00 0a 00 x.e.....
00fe0: 28 00 30 00 30 00 30 00 (.0.0.0.
00ff0: 30 00 30 00 34 00 35 00 0.0.4.5.
00ff8: 62 00 30 00 30 00 30 00 b.0.0.0.
01000: 30 00 20 00 2d 00 20 00 0. .-. .
01008: 30 00 30 00 30 00 30 00 0.0.0.0.
01018: 30 00 34 00 35 00 63 00 0.4.5.c.
01020: 39 00 30 00 30 00 30 00 9.0.0.0.
01028: 3a 00 20 00 43 00 3a 00 :. .C.:.
01030: 5c 00 44 00 6f 00 63 00 \.D.o.c.
01038: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01040: 74 00 73 00 20 00 61 00 t.s. .a.
01048: 6e 00 64 00 20 00 53 00 n.d. .S.
01050: 65 00 74 00 74 00 69 00 e.t.t.i.
01058: 6e 00 67 00 73 00 5c 00 n.g.s.\.
01060: 4d 00 61 00 72 00 69 00 M.a.r.i.
01068: 75 00 73 00 5c 00 4d 00 u.s.\.M.
01070: 79 00 20 00 44 00 6f 00 y. .D.o.
01078: 63 00 75 00 6d 00 65 00 c.u.m.e.
01080: 6e 00 74 00 73 00 5c 00 n.t.s.\.
01088: 56 00 69 00 72 00 74 00 V.i.r.t.
01090: 75 00 61 00 6c 00 44 00 u.a.l.D.
01098: 4a 00 5c 00 50 00 6c 00 J.\.P.l.
010a0: 75 00 67 00 69 00 6e 00 u.g.i.n.
010a8: 73 00 5c 00 56 00 69 00 s.\.V.i.
010b0: 64 00 65 00 6f 00 54 00 d.e.o.T.
010b8: 72 00 61 00 6e 00 73 00 r.a.n.s.
010c0: 69 00 74 00 69 00 6f 00 i.t.i.o.
010c8: 6e 00 5c 00 64 00 65 00 n.\.d.e.
010d0: 66 00 61 00 75 00 6c 00 f.a.u.l.
010d8: 74 00 2e 00 64 00 6c 00 t...d.l.
010e0: 6c 00 0d 00 0a 00 28 00 l.....(.
010e8: 30 00 30 00 30 00 30 00 0.0.0.0.
010f0: 30 00 30 00 30 00 30 00 0.0.0.0.
010f8: 30 00 34 00 36 00 35 00 0.4.6.5.
01108: 20 00 2d 00 20 00 30 00 .-. .0.
01110: 30 00 30 00 30 00 30 00 0.0.0.0.
01120: 34 00 36 00 36 00 33 00 4.6.6.3.
01128: 30 00 30 00 30 00 3a 00 0.0.0.:.
01130: 20 00 43 00 3a 00 5c 00 .C.:.\.
01138: 44 00 6f 00 63 00 75 00 D.o.c.u.
01140: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01148: 73 00 20 00 61 00 6e 00 s. .a.n.
01150: 64 00 20 00 53 00 65 00 d. .S.e.
01158: 74 00 74 00 69 00 6e 00 t.t.i.n.
01160: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01168: 61 00 72 00 69 00 75 00 a.r.i.u.
01170: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01178: 20 00 44 00 6f 00 63 00 .D.o.c.
01180: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01188: 74 00 73 00 5c 00 56 00 t.s.\.V.
01190: 69 00 72 00 74 00 75 00 i.r.t.u.
01198: 61 00 6c 00 44 00 4a 00 a.l.D.J.
011a0: 5c 00 50 00 6c 00 75 00 \.P.l.u.
011a8: 67 00 69 00 6e 00 73 00 g.i.n.s.
011b0: 5c 00 53 00 6f 00 75 00 \.S.o.u.
011b8: 6e 00 64 00 45 00 66 00 n.d.E.f.
011c0: 66 00 65 00 63 00 74 00 f.e.c.t.
011c8: 5c 00 65 00 63 00 68 00 \.e.c.h.
011d0: 6f 00 2e 00 64 00 6c 00 o...d.l.
011d8: 6c 00 0d 00 0a 00 28 00 l.....(.
011e0: 30 00 30 00 30 00 30 00 0.0.0.0.
011e8: 30 00 30 00 30 00 30 00 0.0.0.0.
011f0: 30 00 38 00 63 00 64 00 0.8.c.d.
011f8: 30 00 30 00 30 00 30 00 0.0.0.0.
01200: 20 00 2d 00 20 00 30 00 .-. .0.
01208: 30 00 30 00 30 00 30 00 0.0.0.0.
01210: 30 00 30 00 30 00 30 00 0.0.0.0.
01218: 38 00 63 00 65 00 39 00 8.c.e.9.
01220: 30 00 30 00 30 00 3a 00 0.0.0.:.
01228: 20 00 43 00 3a 00 5c 00 .C.:.\.
01230: 44 00 6f 00 63 00 75 00 D.o.c.u.
01238: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01240: 73 00 20 00 61 00 6e 00 s. .a.n.
01248: 64 00 20 00 53 00 65 00 d. .S.e.
01250: 74 00 74 00 69 00 6e 00 t.t.i.n.
01258: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01260: 61 00 72 00 69 00 75 00 a.r.i.u.
01268: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01270: 20 00 44 00 6f 00 63 00 .D.o.c.
01278: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01280: 74 00 73 00 5c 00 56 00 t.s.\.V.
01288: 69 00 72 00 74 00 75 00 i.r.t.u.
01290: 61 00 6c 00 44 00 4a 00 a.l.D.J.
01298: 5c 00 50 00 6c 00 75 00 \.P.l.u.
012a0: 67 00 69 00 6e 00 73 00 g.i.n.s.
012a8: 5c 00 53 00 6f 00 75 00 \.S.o.u.
012b0: 6e 00 64 00 45 00 66 00 n.d.E.f.
012b8: 66 00 65 00 63 00 74 00 f.e.c.t.
012c0: 5c 00 62 00 61 00 63 00 \.b.a.c.
012c8: 6b 00 73 00 70 00 69 00 k.s.p.i.
012d0: 6e 00 2e 00 64 00 6c 00 n...d.l.
012d8: 6c 00 0d 00 0a 00 28 00 l.....(.
012e0: 30 00 30 00 30 00 30 00 0.0.0.0.
012e8: 30 00 30 00 30 00 30 00 0.0.0.0.
012f0: 30 00 38 00 64 00 37 00 0.8.d.7.
012f8: 30 00 30 00 30 00 30 00 0.0.0.0.
01300: 20 00 2d 00 20 00 30 00 .-. .0.
01308: 30 00 30 00 30 00 30 00 0.0.0.0.
01310: 30 00 30 00 30 00 30 00 0.0.0.0.
01318: 38 00 64 00 38 00 39 00 8.d.8.9.
01320: 30 00 30 00 30 00 3a 00 0.0.0.:.
01328: 20 00 43 00 3a 00 5c 00 .C.:.\.
01330: 44 00 6f 00 63 00 75 00 D.o.c.u.
01338: 6d 00 65 00 6e 00 74 00 m.e.n.t.
01340: 73 00 20 00 61 00 6e 00 s. .a.n.
01348: 64 00 20 00 53 00 65 00 d. .S.e.
01350: 74 00 74 00 69 00 6e 00 t.t.i.n.
01358: 67 00 73 00 5c 00 4d 00 g.s.\.M.
01360: 61 00 72 00 69 00 75 00 a.r.i.u.
01368: 73 00 5c 00 4d 00 79 00 s.\.M.y.
01370: 20 00 44 00 6f 00 63 00 .D.o.c.
01378: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01380: 74 00 73 00 5c 00 56 00 t.s.\.V.
01388: 69 00 72 00 74 00 75 00 i.r.t.u.
01390: 61 00 6c 00 44 00 4a 00 a.l.D.J.
01398: 5c 00 50 00 6c 00 75 00 \.P.l.u.
013a0: 67 00 69 00 6e 00 73 00 g.i.n.s.
013a8: 5c 00 53 00 6f 00 75 00 \.S.o.u.
013b0: 6e 00 64 00 45 00 66 00 n.d.E.f.
013b8: 66 00 65 00 63 00 74 00 f.e.c.t.
013c0: 5c 00 62 00 72 00 61 00 \.b.r.a.
013c8: 6b 00 65 00 2e 00 64 00 k.e...d.
013d0: 6c 00 6c 00 0d 00 0a 00 l.l.....
013d8: 28 00 30 00 30 00 30 00 (.0.0.0.
013e0: 30 00 30 00 30 00 30 00 0.0.0.0.
013e8: 30 00 30 00 38 00 65 00 0.0.8.e.
013f0: 31 00 30 00 30 00 30 00 1.0.0.0.
013f8: 30 00 20 00 2d 00 20 00 0. .-. .
01400: 30 00 30 00 30 00 30 00 0.0.0.0.
01408: 30 00 30 00 30 00 30 00 0.0.0.0.
01410: 30 00 38 00 65 00 39 00 0.8.e.9.
01418: 39 00 30 00 30 00 30 00 9.0.0.0.
01420: 3a 00 20 00 43 00 3a 00 :. .C.:.
01428: 5c 00 44 00 6f 00 63 00 \.D.o.c.
01430: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01438: 74 00 73 00 20 00 61 00 t.s. .a.
01440: 6e 00 64 00 20 00 53 00 n.d. .S.
01448: 65 00 74 00 74 00 69 00 e.t.t.i.
01450: 6e 00 67 00 73 00 5c 00 n.g.s.\.
01458: 4d 00 61 00 72 00 69 00 M.a.r.i.
01460: 75 00 73 00 5c 00 4d 00 u.s.\.M.
01468: 79 00 20 00 44 00 6f 00 y. .D.o.
01470: 63 00 75 00 6d 00 65 00 c.u.m.e.
01478: 6e 00 74 00 73 00 5c 00 n.t.s.\.
01480: 56 00 69 00 72 00 74 00 V.i.r.t.
01488: 75 00 61 00 6c 00 44 00 u.a.l.D.
01490: 4a 00 5c 00 50 00 6c 00 J.\.P.l.
01498: 75 00 67 00 69 00 6e 00 u.g.i.n.
014a0: 73 00 5c 00 53 00 6f 00 s.\.S.o.
014a8: 75 00 6e 00 64 00 45 00 u.n.d.E.
014b0: 66 00 66 00 65 00 63 00 f.f.e.c.
014b8: 74 00 5c 00 42 00 65 00 t.\.B.e.
014c0: 61 00 74 00 47 00 72 00 a.t.G.r.
014c8: 69 00 64 00 2e 00 64 00 i.d...d.
014d0: 6c 00 6c 00 0d 00 0a 00 l.l.....
014d8: 28 00 30 00 30 00 30 00 (.0.0.0.
014e0: 30 00 30 00 30 00 30 00 0.0.0.0.
014e8: 30 00 30 00 38 00 66 00 0.0.8.f.
014f0: 61 00 30 00 30 00 30 00 a.0.0.0.
014f8: 30 00 20 00 2d 00 20 00 0. .-. .
01500: 30 00 30 00 30 00 30 00 0.0.0.0.
01508: 30 00 30 00 30 00 30 00 0.0.0.0.
01510: 30 00 38 00 66 00 62 00 0.8.f.b.
01518: 31 00 30 00 30 00 30 00 1.0.0.0.
01520: 3a 00 20 00 43 00 3a 00 :. .C.:.
01528: 5c 00 44 00 6f 00 63 00 \.D.o.c.
01530: 75 00 6d 00 65 00 6e 00 u.m.e.n.
01538: 74 00 73 00 20 00 61 00 t.s. .a.
01540: 6e 00 64 00 20 00 53 00 n.d. .S.
01548: 65 00 74 00 74 00 69 00 e.t.t.i.
01550: 6e 00 67 00 73 00 5c 00 n.g.s.\.
01558: 4d 00 61 00 72 00 69 00 M.a.r.i.
01560: 75 00 73 00 5c 00 4d 00 u.s.\.M.
01568: 79 00 20 00 44 00 6f 00 y. .D.o.
01570: 63 00 75 00 6d 00 65 00 c.u.m.e.
01578: 6e 00 74 00 73 00 5c 00 n.t.s.\.
01580: 56 00 69 00 72 00 74 00 V.i.r.t.
01588: 75 00 61 00 6c 00 44 00 u.a.l.D.
01590: 4a 00 5c 00 50 00 6c 00 J.\.P.l.
01598: 75 00 67 00 69 00 6e 00 u.g.i.n.
015a0: 73 00 5c 00 53 00 6f 00 s.\.S.o.
015a8: 75 00 6e 00 64 00 45 00 u.n.d.E.
015b0: 66 00 66 00 65 00 63 00 f.f.e.c.
015b8: 74 00 5c 00 46 00 6c 00 t.\.F.l.
015c0: 69 00 70 00 70 00 69 00 i.p.p.i.
015c8: 6e 00 44 00 6f 00 75 00 n.D.o.u.
015d0: 62 00 6c 00 65 00 2e 00 b.l.e...
015d8: 64 00 6c 00 6c 00 0d 00 d.l.l...
015e0: 0a 00 28 00 30 00 30 00 ..(.0.0.
015e8: 30 00 30 00 30 00 30 00 0.0.0.0.
015f0: 30 00 30 00 31 00 30 00 0.0.1.0.
015f8: 30 00 30 00 30 00 30 00 0.0.0.0.
01600: 30 00 30 00 20 00 2d 00 0.0. .-.
01608: 20 00 30 00 30 00 30 00 .0.0.0.
01610: 30 00 30 00 30 00 30 00 0.0.0.0.
01618: 30 00 31 00 30 00 30 00 0.1.0.0.
01620: 30 00 39 00 30 00 30 00 0.9.0.0.
01628: 30 00 3a 00 20 00 43 00 0.:. .C.
01630: 3a 00 5c 00 50 00 72 00 :.\.P.r.
01638: 6f 00 67 00 72 00 61 00 o.g.r.a.
01640: 6d 00 20 00 46 00 69 00 m. .F.i.
01648: 6c 00 65 00 73 00 5c 00 l.e.s.\.
01650: 41 00 53 00 55 00 53 00 A.S.U.S.
01658: 5c 00 41 00 53 00 55 00 \.A.S.U.
01660: 53 00 20 00 44 00 69 00 S. .D.i.
01668: 72 00 65 00 63 00 74 00 r.e.c.t.
01670: 20 00 43 00 6f 00 6e 00 .C.o.n.
01678: 73 00 6f 00 6c 00 65 00 s.o.l.e.
01680: 5c 00 4d 00 53 00 4e 00 \.M.S.N.
01688: 48 00 4f 00 4f 00 4b 00 H.O.O.K.
01690: 2e 00 44 00 4c 00 4c 00 ..D.L.L.
01698: 0d 00 0a 00 28 00 30 00 ....(.0.
016a8: 30 00 30 00 30 00 35 00 0.0.0.5.
016b0: 61 00 64 00 37 00 30 00 a.d.7.0.
016b8: 30 00 30 00 30 00 20 00 0.0.0. .
016c0: 2d 00 20 00 30 00 30 00 -. .0.0.
016c8: 30 00 30 00 30 00 30 00 0.0.0.0.
016d0: 30 00 30 00 35 00 61 00 0.0.5.a.
016d8: 64 00 61 00 38 00 30 00 d.a.8.0.
016e0: 30 00 30 00 3a 00 20 00 0.0.:. .
016e8: 43 00 3a 00 5c 00 57 00 C.:.\.W.
016f0: 49 00 4e 00 44 00 4f 00 I.N.D.O.
016f8: 57 00 53 00 5c 00 73 00 W.S.\.s.
01700: 79 00 73 00 74 00 65 00 y.s.t.e.
01708: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01710: 75 00 78 00 74 00 68 00 u.x.t.h.
01718: 65 00 6d 00 65 00 2e 00 e.m.e...
01720: 64 00 6c 00 6c 00 0d 00 d.l.l...
01728: 0a 00 28 00 30 00 30 00 ..(.0.0.
01730: 30 00 30 00 30 00 30 00 0.0.0.0.
01738: 30 00 30 00 35 00 62 00 0.0.5.b.
01740: 30 00 61 00 30 00 30 00 0.a.0.0.
01748: 30 00 30 00 20 00 2d 00 0.0. .-.
01750: 20 00 30 00 30 00 30 00 .0.0.0.
01758: 30 00 30 00 30 00 30 00 0.0.0.0.
01760: 30 00 35 00 62 00 30 00 0.5.b.0.
01768: 61 00 37 00 30 00 30 00 a.7.0.0.
01770: 30 00 3a 00 20 00 43 00 0.:. .C.
01778: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01780: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01788: 53 00 5c 00 73 00 79 00 S.\.s.y.
01790: 73 00 74 00 65 00 6d 00 s.t.e.m.
01798: 33 00 32 00 5c 00 75 00 3.2.\.u.
017a0: 6d 00 64 00 6d 00 78 00 m.d.m.x.
017a8: 66 00 72 00 6d 00 2e 00 f.r.m...
017b0: 64 00 6c 00 6c 00 0d 00 d.l.l...
017b8: 0a 00 28 00 30 00 30 00 ..(.0.0.
017c0: 30 00 30 00 30 00 30 00 0.0.0.0.
017c8: 30 00 30 00 35 00 62 00 0.0.5.b.
017d0: 38 00 36 00 30 00 30 00 8.6.0.0.
017d8: 30 00 30 00 20 00 2d 00 0.0. .-.
017e0: 20 00 30 00 30 00 30 00 .0.0.0.
017e8: 30 00 30 00 30 00 30 00 0.0.0.0.
017f0: 30 00 35 00 62 00 38 00 0.5.b.8.
017f8: 62 00 35 00 30 00 30 00 b.5.0.0.
01800: 30 00 3a 00 20 00 43 00 0.:. .C.
01808: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01810: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01818: 53 00 5c 00 73 00 79 00 S.\.s.y.
01820: 73 00 74 00 65 00 6d 00 s.t.e.m.
01828: 33 00 32 00 5c 00 4e 00 3.2.\.N.
01830: 45 00 54 00 41 00 50 00 E.T.A.P.
01838: 49 00 33 00 32 00 2e 00 I.3.2...
01840: 64 00 6c 00 6c 00 0d 00 d.l.l...
01848: 0a 00 28 00 30 00 30 00 ..(.0.0.
01850: 30 00 30 00 30 00 30 00 0.0.0.0.
01858: 30 00 30 00 35 00 63 00 0.0.5.c.
01860: 64 00 37 00 30 00 30 00 d.7.0.0.
01868: 30 00 30 00 20 00 2d 00 0.0. .-.
01870: 20 00 30 00 30 00 30 00 .0.0.0.
01878: 30 00 30 00 30 00 30 00 0.0.0.0.
01880: 30 00 35 00 63 00 64 00 0.5.c.d.
01888: 37 00 37 00 30 00 30 00 7.7.0.0.
01890: 30 00 3a 00 20 00 43 00 0.:. .C.
01898: 3a 00 5c 00 57 00 49 00 :.\.W.I.
018a0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
018a8: 53 00 5c 00 73 00 79 00 S.\.s.y.
018b0: 73 00 74 00 65 00 6d 00 s.t.e.m.
018b8: 33 00 32 00 5c 00 73 00 3.2.\.s.
018c0: 65 00 72 00 77 00 76 00 e.r.w.v.
018c8: 64 00 72 00 76 00 2e 00 d.r.v...
018d0: 64 00 6c 00 6c 00 0d 00 d.l.l...
018d8: 0a 00 28 00 30 00 30 00 ..(.0.0.
018e0: 30 00 30 00 30 00 30 00 0.0.0.0.
018e8: 30 00 30 00 35 00 64 00 0.0.5.d.
018f0: 30 00 39 00 30 00 30 00 0.9.0.0.
018f8: 30 00 30 00 20 00 2d 00 0.0. .-.
01900: 20 00 30 00 30 00 30 00 .0.0.0.
01908: 30 00 30 00 30 00 30 00 0.0.0.0.
01910: 30 00 35 00 64 00 31 00 0.5.d.1.
01918: 32 00 61 00 30 00 30 00 2.a.0.0.
01920: 30 00 3a 00 20 00 43 00 0.:. .C.
01928: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01930: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01938: 53 00 5c 00 73 00 79 00 S.\.s.y.
01940: 73 00 74 00 65 00 6d 00 s.t.e.m.
01948: 33 00 32 00 5c 00 43 00 3.2.\.C.
01950: 4f 00 4d 00 43 00 54 00 O.M.C.T.
01958: 4c 00 33 00 32 00 2e 00 L.3.2...
01960: 64 00 6c 00 6c 00 0d 00 d.l.l...
01968: 0a 00 28 00 30 00 30 00 ..(.0.0.
01970: 30 00 30 00 30 00 30 00 0.0.0.0.
01978: 30 00 30 00 36 00 36 00 0.0.6.6.
01980: 32 00 62 00 30 00 30 00 2.b.0.0.
01988: 30 00 30 00 20 00 2d 00 0.0. .-.
01990: 20 00 30 00 30 00 30 00 .0.0.0.
01998: 30 00 30 00 30 00 30 00 0.0.0.0.
019a0: 30 00 36 00 36 00 33 00 0.6.6.3.
019a8: 30 00 38 00 30 00 30 00 0.8.0.0.
019b0: 30 00 3a 00 20 00 43 00 0.:. .C.
019b8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
019c0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
019c8: 53 00 5c 00 73 00 79 00 S.\.s.y.
019d0: 73 00 74 00 65 00 6d 00 s.t.e.m.
019d8: 33 00 32 00 5c 00 68 00 3.2.\.h.
019e0: 6e 00 65 00 74 00 63 00 n.e.t.c.
019e8: 66 00 67 00 2e 00 64 00 f.g...d.
019f0: 6c 00 6c 00 0d 00 0a 00 l.l.....
019f8: 28 00 30 00 30 00 30 00 (.0.0.0.
01a00: 30 00 30 00 30 00 30 00 0.0.0.0.
01a08: 30 00 36 00 38 00 38 00 0.6.8.8.
01a10: 66 00 30 00 30 00 30 00 f.0.0.0.
01a18: 30 00 20 00 2d 00 20 00 0. .-. .
01a20: 30 00 30 00 30 00 30 00 0.0.0.0.
01a28: 30 00 30 00 30 00 30 00 0.0.0.0.
01a30: 36 00 38 00 38 00 66 00 6.8.8.f.
01a38: 39 00 30 00 30 00 30 00 9.0.0.0.
01a40: 3a 00 20 00 43 00 3a 00 :. .C.:.
01a48: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01a50: 44 00 4f 00 57 00 53 00 D.O.W.S.
01a58: 5c 00 73 00 79 00 73 00 \.s.y.s.
01a60: 74 00 65 00 6d 00 33 00 t.e.m.3.
01a68: 32 00 5c 00 48 00 49 00 2.\.H.I.
01a70: 44 00 2e 00 44 00 4c 00 D...D.L.
01a78: 4c 00 0d 00 0a 00 28 00 L.....(.
01a88: 30 00 30 00 30 00 30 00 0.0.0.0.
01a90: 37 00 31 00 61 00 35 00 7.1.a.5.
01a98: 30 00 30 00 30 00 30 00 0.0.0.0.
01aa0: 20 00 2d 00 20 00 30 00 .-. .0.
01ab0: 30 00 30 00 30 00 37 00 0.0.0.7.
01ab8: 31 00 61 00 38 00 66 00 1.a.8.f.
01ac0: 30 00 30 00 30 00 3a 00 0.0.0.:.
01ac8: 20 00 43 00 3a 00 5c 00 .C.:.\.
01ad0: 57 00 49 00 4e 00 44 00 W.I.N.D.
01ad8: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01ae0: 73 00 79 00 73 00 74 00 s.y.s.t.
01ae8: 65 00 6d 00 33 00 32 00 e.m.3.2.
01af0: 5c 00 6d 00 73 00 77 00 \.m.s.w.
01af8: 73 00 6f 00 63 00 6b 00 s.o.c.k.
01b00: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01b08: 0d 00 0a 00 28 00 30 00 ....(.0.
01b18: 30 00 30 00 30 00 37 00 0.0.0.7.
01b20: 31 00 61 00 39 00 30 00 1.a.9.0.
01b28: 30 00 30 00 30 00 20 00 0.0.0. .
01b30: 2d 00 20 00 30 00 30 00 -. .0.0.
01b40: 30 00 30 00 37 00 31 00 0.0.7.1.
01b48: 61 00 39 00 38 00 30 00 a.9.8.0.
01b50: 30 00 30 00 3a 00 20 00 0.0.:. .
01b58: 43 00 3a 00 5c 00 57 00 C.:.\.W.
01b60: 49 00 4e 00 44 00 4f 00 I.N.D.O.
01b68: 57 00 53 00 5c 00 53 00 W.S.\.S.
01b70: 79 00 73 00 74 00 65 00 y.s.t.e.
01b78: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01b80: 77 00 73 00 68 00 74 00 w.s.h.t.
01b88: 63 00 70 00 69 00 70 00 c.p.i.p.
01b90: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01b98: 0d 00 0a 00 28 00 30 00 ....(.0.
01ba8: 30 00 30 00 30 00 37 00 0.0.0.7.
01bb0: 31 00 61 00 61 00 30 00 1.a.a.0.
01bb8: 30 00 30 00 30 00 20 00 0.0.0. .
01bc0: 2d 00 20 00 30 00 30 00 -. .0.0.
01bd0: 30 00 30 00 37 00 31 00 0.0.7.1.
01bd8: 61 00 61 00 38 00 30 00 a.a.8.0.
01be0: 30 00 30 00 3a 00 20 00 0.0.:. .
01be8: 43 00 3a 00 5c 00 57 00 C.:.\.W.
01bf0: 49 00 4e 00 44 00 4f 00 I.N.D.O.
01bf8: 57 00 53 00 5c 00 73 00 W.S.\.s.
01c00: 79 00 73 00 74 00 65 00 y.s.t.e.
01c08: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01c10: 57 00 53 00 32 00 48 00 W.S.2.H.
01c18: 45 00 4c 00 50 00 2e 00 E.L.P...
01c20: 64 00 6c 00 6c 00 0d 00 d.l.l...
01c28: 0a 00 28 00 30 00 30 00 ..(.0.0.
01c38: 30 00 30 00 37 00 31 00 0.0.7.1.
01c40: 61 00 62 00 30 00 30 00 a.b.0.0.
01c48: 30 00 30 00 20 00 2d 00 0.0. .-.
01c50: 20 00 30 00 30 00 30 00 .0.0.0.
01c60: 30 00 37 00 31 00 61 00 0.7.1.a.
01c68: 63 00 37 00 30 00 30 00 c.7.0.0.
01c70: 30 00 3a 00 20 00 43 00 0.:. .C.
01c78: 3a 00 5c 00 57 00 49 00 :.\.W.I.
01c80: 4e 00 44 00 4f 00 57 00 N.D.O.W.
01c88: 53 00 5c 00 73 00 79 00 S.\.s.y.
01c90: 73 00 74 00 65 00 6d 00 s.t.e.m.
01c98: 33 00 32 00 5c 00 57 00 3.2.\.W.
01ca0: 53 00 32 00 5f 00 33 00 S.2._.3.
01ca8: 32 00 2e 00 64 00 6c 00 2...d.l.
01cc8: 37 00 31 00 61 00 64 00 7.1.a.d.
01ce8: 30 00 30 00 30 00 37 00 0.0.0.7.
01cf0: 31 00 61 00 64 00 39 00 1.a.d.9.
01d28: 5c 00 77 00 73 00 6f 00 \.w.s.o.
01d30: 63 00 6b 00 33 00 32 00 c.k.3.2.
01d38: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
01d40: 0d 00 0a 00 28 00 30 00 ....(.0.
01d50: 30 00 30 00 30 00 37 00 0.0.0.7.
01d58: 32 00 32 00 38 00 30 00 2.2.8.0.
01d60: 30 00 30 00 30 00 20 00 0.0.0. .
01d68: 2d 00 20 00 30 00 30 00 -. .0.0.
01d78: 30 00 30 00 37 00 32 00 0.0.7.2.
01d80: 32 00 61 00 61 00 30 00 2.a.a.0.
01d88: 30 00 30 00 3a 00 20 00 0.0.:. .
01d90: 43 00 3a 00 5c 00 57 00 C.:.\.W.
01d98: 49 00 4e 00 44 00 4f 00 I.N.D.O.
01da0: 57 00 53 00 5c 00 73 00 W.S.\.s.
01da8: 79 00 73 00 74 00 65 00 y.s.t.e.
01db0: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01db8: 44 00 49 00 4e 00 50 00 D.I.N.P.
01dc0: 55 00 54 00 2e 00 44 00 U.T...D.
01dc8: 4c 00 4c 00 0d 00 0a 00 L.L.....
01dd0: 28 00 30 00 30 00 30 00 (.0.0.0.
01de0: 30 00 37 00 32 00 32 00 0.7.2.2.
01de8: 62 00 30 00 30 00 30 00 b.0.0.0.
01df0: 30 00 20 00 2d 00 20 00 0. .-. .
01df8: 30 00 30 00 30 00 30 00 0.0.0.0.
01e08: 37 00 32 00 32 00 62 00 7.2.2.b.
01e10: 35 00 30 00 30 00 30 00 5.0.0.0.
01e18: 3a 00 20 00 43 00 3a 00 :. .C.:.
01e20: 5c 00 57 00 49 00 4e 00 \.W.I.N.
01e28: 44 00 4f 00 57 00 53 00 D.O.W.S.
01e30: 5c 00 73 00 79 00 73 00 \.s.y.s.
01e38: 74 00 65 00 6d 00 33 00 t.e.m.3.
01e40: 32 00 5c 00 73 00 65 00 2.\.s.e.
01e48: 6e 00 73 00 61 00 70 00 n.s.a.p.
01e50: 69 00 2e 00 64 00 6c 00 i...d.l.
01e58: 6c 00 0d 00 0a 00 28 00 l.....(.
01e60: 30 00 30 00 30 00 30 00 0.0.0.0.
01e70: 37 00 32 00 64 00 31 00 7.2.d.1.
01e78: 30 00 30 00 30 00 30 00 0.0.0.0.
01e80: 20 00 2d 00 20 00 30 00 .-. .0.
01e88: 30 00 30 00 30 00 30 00 0.0.0.0.
01e90: 30 00 30 00 30 00 37 00 0.0.0.7.
01e98: 32 00 64 00 31 00 38 00 2.d.1.8.
01ea0: 30 00 30 00 30 00 3a 00 0.0.0.:.
01ea8: 20 00 43 00 3a 00 5c 00 .C.:.\.
01eb0: 57 00 49 00 4e 00 44 00 W.I.N.D.
01eb8: 4f 00 57 00 53 00 5c 00 O.W.S.\.
01ec0: 73 00 79 00 73 00 74 00 s.y.s.t.
01ec8: 65 00 6d 00 33 00 32 00 e.m.3.2.
01ed0: 5c 00 6d 00 73 00 61 00 \.m.s.a.
01ed8: 63 00 6d 00 33 00 32 00 c.m.3.2.
01ee0: 2e 00 64 00 72 00 76 00 ..d.r.v.
01ee8: 0d 00 0a 00 28 00 30 00 ....(.0.
01ef8: 30 00 30 00 30 00 37 00 0.0.0.7.
01f00: 32 00 64 00 32 00 30 00 2.d.2.0.
01f08: 30 00 30 00 30 00 20 00 0.0.0. .
01f10: 2d 00 20 00 30 00 30 00 -. .0.0.
01f20: 30 00 30 00 37 00 32 00 0.0.7.2.
01f28: 64 00 32 00 39 00 30 00 d.2.9.0.
01f30: 30 00 30 00 3a 00 20 00 0.0.:. .
01f38: 43 00 3a 00 5c 00 57 00 C.:.\.W.
01f40: 49 00 4e 00 44 00 4f 00 I.N.D.O.
01f48: 57 00 53 00 5c 00 73 00 W.S.\.s.
01f50: 79 00 73 00 74 00 65 00 y.s.t.e.
01f58: 6d 00 33 00 32 00 5c 00 m.3.2.\.
01f60: 77 00 64 00 6d 00 61 00 w.d.m.a.
01f68: 75 00 64 00 2e 00 64 00 u.d...d.
01f70: 72 00 76 00 0d 00 0a 00 r.v.....
01f88: 30 00 37 00 33 00 62 00 0.7.3.b.
01f90: 35 00 30 00 30 00 30 00 5.0.0.0.
01fb0: 37 00 33 00 62 00 36 00 7.3.b.6.
01fb8: 37 00 30 00 30 00 30 00 7.0.0.0.
01fd8: 5c 00 73 00 79 00 73 00 \.s.y.s.
01fe8: 32 00 5c 00 41 00 56 00 2.\.A.V.
01ff0: 49 00 46 00 49 00 4c 00 I.F.I.L.
01ff8: 33 00 32 00 2e 00 64 00 3.2...d.
02018: 30 00 37 00 33 00 65 00 0.7.3.e.
02020: 65 00 30 00 30 00 30 00 e.0.0.0.
02040: 37 00 33 00 65 00 65 00 7.3.e.e.
02048: 34 00 30 00 30 00 30 00 4.0.0.0.
02078: 32 00 5c 00 4b 00 73 00 2.\.K.s.
02080: 55 00 73 00 65 00 72 00 U.s.e.r.
02088: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
02090: 0d 00 0a 00 28 00 30 00 ....(.0.
020a0: 30 00 30 00 30 00 37 00 0.0.0.7.
020a8: 33 00 66 00 31 00 30 00 3.f.1.0.
020b0: 30 00 30 00 30 00 20 00 0.0.0. .
020b8: 2d 00 20 00 30 00 30 00 -. .0.0.
020c8: 30 00 30 00 37 00 33 00 0.0.7.3.
020d0: 66 00 36 00 63 00 30 00 f.6.c.0.
020d8: 30 00 30 00 3a 00 20 00 0.0.:. .
020e0: 43 00 3a 00 5c 00 57 00 C.:.\.W.
020e8: 49 00 4e 00 44 00 4f 00 I.N.D.O.
020f0: 57 00 53 00 5c 00 73 00 W.S.\.s.
020f8: 79 00 73 00 74 00 65 00 y.s.t.e.
02100: 6d 00 33 00 32 00 5c 00 m.3.2.\.
02108: 44 00 53 00 4f 00 55 00 D.S.O.U.
02110: 4e 00 44 00 2e 00 64 00 N.D...d.
02118: 6c 00 6c 00 0d 00 0a 00 l.l.....
02120: 28 00 30 00 30 00 30 00 (.0.0.0.
02130: 30 00 37 00 34 00 37 00 0.7.4.7.
02138: 32 00 30 00 30 00 30 00 2.0.0.0.
02140: 30 00 20 00 2d 00 20 00 0. .-. .
02148: 30 00 30 00 30 00 30 00 0.0.0.0.
02158: 37 00 34 00 37 00 36 00 7.4.7.6.
02160: 63 00 30 00 30 00 30 00 c.0.0.0.
02168: 3a 00 20 00 43 00 3a 00 :. .C.:.
02170: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02178: 44 00 4f 00 57 00 53 00 D.O.W.S.
02180: 5c 00 73 00 79 00 73 00 \.s.y.s.
02188: 74 00 65 00 6d 00 33 00 t.e.m.3.
02190: 32 00 5c 00 4d 00 53 00 2.\.M.S.
02198: 43 00 54 00 46 00 2e 00 C.T.F...
021a0: 64 00 6c 00 6c 00 0d 00 d.l.l...
021a8: 0a 00 28 00 30 00 30 00 ..(.0.0.
021b0: 30 00 30 00 30 00 30 00 0.0.0.0.
021b8: 30 00 30 00 37 00 35 00 0.0.7.5.
021c0: 61 00 37 00 30 00 30 00 a.7.0.0.
021c8: 30 00 30 00 20 00 2d 00 0.0. .-.
021d0: 20 00 30 00 30 00 30 00 .0.0.0.
021e0: 30 00 37 00 35 00 61 00 0.7.5.a.
021e8: 39 00 31 00 30 00 30 00 9.1.0.0.
021f0: 30 00 3a 00 20 00 43 00 0.:. .C.
021f8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02200: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02208: 53 00 5c 00 73 00 79 00 S.\.s.y.
02210: 73 00 74 00 65 00 6d 00 s.t.e.m.
02218: 33 00 32 00 5c 00 4d 00 3.2.\.M.
02220: 53 00 56 00 46 00 57 00 S.V.F.W.
02228: 33 00 32 00 2e 00 64 00 3.2...d.
02230: 6c 00 6c 00 0d 00 0a 00 l.l.....
02238: 28 00 30 00 30 00 30 00 (.0.0.0.
02248: 30 00 37 00 36 00 33 00 0.7.6.3.
02250: 38 00 30 00 30 00 30 00 8.0.0.0.
02258: 30 00 20 00 2d 00 20 00 0. .-. .
02268: 30 00 30 00 30 00 30 00 0.0.0.0.
02270: 37 00 36 00 33 00 38 00 7.6.3.8.
02278: 35 00 30 00 30 00 30 00 5.0.0.0.
02280: 3a 00 20 00 43 00 3a 00 :. .C.:.
02288: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02290: 44 00 4f 00 57 00 53 00 D.O.W.S.
02298: 5c 00 73 00 79 00 73 00 \.s.y.s.
022a0: 74 00 65 00 6d 00 33 00 t.e.m.3.
022a8: 32 00 5c 00 4d 00 53 00 2.\.M.S.
022b0: 49 00 4d 00 47 00 33 00 I.M.G.3.
022b8: 32 00 2e 00 64 00 6c 00 2...d.l.
022c0: 6c 00 0d 00 0a 00 28 00 l.....(.
022d0: 30 00 30 00 30 00 30 00 0.0.0.0.
022d8: 37 00 36 00 33 00 62 00 7.6.3.b.
022e0: 30 00 30 00 30 00 30 00 0.0.0.0.
022e8: 20 00 2d 00 20 00 30 00 .-. .0.
022f8: 30 00 30 00 30 00 37 00 0.0.0.7.
02300: 36 00 33 00 66 00 39 00 6.3.f.9.
02308: 30 00 30 00 30 00 3a 00 0.0.0.:.
02310: 20 00 43 00 3a 00 5c 00 .C.:.\.
02318: 57 00 49 00 4e 00 44 00 W.I.N.D.
02320: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02328: 73 00 79 00 73 00 74 00 s.y.s.t.
02330: 65 00 6d 00 33 00 32 00 e.m.3.2.
02338: 5c 00 63 00 6f 00 6d 00 \.c.o.m.
02340: 64 00 6c 00 67 00 33 00 d.l.g.3.
02348: 32 00 2e 00 64 00 6c 00 2...d.l.
02350: 6c 00 0d 00 0a 00 28 00 l.....(.
02360: 30 00 30 00 30 00 30 00 0.0.0.0.
02368: 37 00 36 00 36 00 30 00 7.6.6.0.
02370: 30 00 30 00 30 00 30 00 0.0.0.0.
02378: 20 00 2d 00 20 00 30 00 .-. .0.
02388: 30 00 30 00 30 00 37 00 0.0.0.7.
02390: 36 00 36 00 31 00 64 00 6.6.1.d.
02398: 30 00 30 00 30 00 3a 00 0.0.0.:.
023a0: 20 00 43 00 3a 00 5c 00 .C.:.\.
023a8: 57 00 49 00 4e 00 44 00 W.I.N.D.
023b0: 4f 00 57 00 53 00 5c 00 O.W.S.\.
023b8: 53 00 79 00 73 00 74 00 S.y.s.t.
023c0: 65 00 6d 00 33 00 32 00 e.m.3.2.
023c8: 5c 00 43 00 53 00 43 00 \.C.S.C.
023d0: 44 00 4c 00 4c 00 2e 00 D.L.L...
023d8: 64 00 6c 00 6c 00 0d 00 d.l.l...
023e0: 0a 00 28 00 30 00 30 00 ..(.0.0.
023f0: 30 00 30 00 37 00 36 00 0.0.7.6.
023f8: 37 00 39 00 30 00 30 00 7.9.0.0.
02400: 30 00 30 00 20 00 2d 00 0.0. .-.
02408: 20 00 30 00 30 00 30 00 .0.0.0.
02410: 30 00 30 00 30 00 30 00 0.0.0.0.
02418: 30 00 37 00 36 00 37 00 0.7.6.7.
02420: 39 00 63 00 30 00 30 00 9.c.0.0.
02428: 30 00 3a 00 20 00 43 00 0.:. .C.
02430: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02438: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02440: 53 00 5c 00 73 00 79 00 S.\.s.y.
02448: 73 00 74 00 65 00 6d 00 s.t.e.m.
02450: 33 00 32 00 5c 00 63 00 3.2.\.c.
02458: 72 00 79 00 70 00 74 00 r.y.p.t.
02460: 64 00 6c 00 6c 00 2e 00 d.l.l...
02468: 64 00 6c 00 6c 00 0d 00 d.l.l...
02470: 0a 00 28 00 30 00 30 00 ..(.0.0.
02478: 30 00 30 00 30 00 30 00 0.0.0.0.
02480: 30 00 30 00 37 00 36 00 0.0.7.6.
02488: 39 00 63 00 30 00 30 00 9.c.0.0.
02490: 30 00 30 00 20 00 2d 00 0.0. .-.
02498: 20 00 30 00 30 00 30 00 .0.0.0.
024a0: 30 00 30 00 30 00 30 00 0.0.0.0.
024a8: 30 00 37 00 36 00 61 00 0.7.6.a.
024b0: 37 00 34 00 30 00 30 00 7.4.0.0.
024b8: 30 00 3a 00 20 00 43 00 0.:. .C.
024c0: 3a 00 5c 00 57 00 49 00 :.\.W.I.
024c8: 4e 00 44 00 4f 00 57 00 N.D.O.W.
024d0: 53 00 5c 00 73 00 79 00 S.\.s.y.
024d8: 73 00 74 00 65 00 6d 00 s.t.e.m.
024e0: 33 00 32 00 5c 00 55 00 3.2.\.U.
024e8: 53 00 45 00 52 00 45 00 S.E.R.E.
024f0: 4e 00 56 00 2e 00 64 00 N.V...d.
024f8: 6c 00 6c 00 0d 00 0a 00 l.l.....
02500: 28 00 30 00 30 00 30 00 (.0.0.0.
02508: 30 00 30 00 30 00 30 00 0.0.0.0.
02510: 30 00 37 00 36 00 62 00 0.7.6.b.
02518: 34 00 30 00 30 00 30 00 4.0.0.0.
02520: 30 00 20 00 2d 00 20 00 0. .-. .
02528: 30 00 30 00 30 00 30 00 0.0.0.0.
02530: 30 00 30 00 30 00 30 00 0.0.0.0.
02538: 37 00 36 00 62 00 36 00 7.6.b.6.
02540: 64 00 30 00 30 00 30 00 d.0.0.0.
02548: 3a 00 20 00 43 00 3a 00 :. .C.:.
02550: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02558: 44 00 4f 00 57 00 53 00 D.O.W.S.
02560: 5c 00 73 00 79 00 73 00 \.s.y.s.
02568: 74 00 65 00 6d 00 33 00 t.e.m.3.
02570: 32 00 5c 00 57 00 49 00 2.\.W.I.
02578: 4e 00 4d 00 4d 00 2e 00 N.M.M...
02580: 64 00 6c 00 6c 00 0d 00 d.l.l...
02588: 0a 00 28 00 30 00 30 00 ..(.0.0.
02590: 30 00 30 00 30 00 30 00 0.0.0.0.
02598: 30 00 30 00 37 00 36 00 0.0.7.6.
025a0: 63 00 33 00 30 00 30 00 c.3.0.0.
025a8: 30 00 30 00 20 00 2d 00 0.0. .-.
025b0: 20 00 30 00 30 00 30 00 .0.0.0.
025b8: 30 00 30 00 30 00 30 00 0.0.0.0.
025c0: 30 00 37 00 36 00 63 00 0.7.6.c.
025c8: 35 00 65 00 30 00 30 00 5.e.0.0.
025d0: 30 00 3a 00 20 00 43 00 0.:. .C.
025d8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
025e0: 4e 00 44 00 4f 00 57 00 N.D.O.W.
025e8: 53 00 5c 00 73 00 79 00 S.\.s.y.
025f0: 73 00 74 00 65 00 6d 00 s.t.e.m.
025f8: 33 00 32 00 5c 00 57 00 3.2.\.W.
02600: 49 00 4e 00 54 00 52 00 I.N.T.R.
02608: 55 00 53 00 54 00 2e 00 U.S.T...
02610: 64 00 6c 00 6c 00 0d 00 d.l.l...
02618: 0a 00 28 00 30 00 30 00 ..(.0.0.
02620: 30 00 30 00 30 00 30 00 0.0.0.0.
02628: 30 00 30 00 37 00 36 00 0.0.7.6.
02630: 63 00 39 00 30 00 30 00 c.9.0.0.
02638: 30 00 30 00 20 00 2d 00 0.0. .-.
02640: 20 00 30 00 30 00 30 00 .0.0.0.
02648: 30 00 30 00 30 00 30 00 0.0.0.0.
02650: 30 00 37 00 36 00 63 00 0.7.6.c.
02658: 62 00 38 00 30 00 30 00 b.8.0.0.
02660: 30 00 3a 00 20 00 43 00 0.:. .C.
02668: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02670: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02678: 53 00 5c 00 73 00 79 00 S.\.s.y.
02680: 73 00 74 00 65 00 6d 00 s.t.e.m.
02688: 33 00 32 00 5c 00 49 00 3.2.\.I.
02690: 4d 00 41 00 47 00 45 00 M.A.G.E.
02698: 48 00 4c 00 50 00 2e 00 H.L.P...
026a0: 64 00 6c 00 6c 00 0d 00 d.l.l...
026a8: 0a 00 28 00 30 00 30 00 ..(.0.0.
026b0: 30 00 30 00 30 00 30 00 0.0.0.0.
026b8: 30 00 30 00 37 00 36 00 0.0.7.6.
026c0: 64 00 36 00 30 00 30 00 d.6.0.0.
026c8: 30 00 30 00 20 00 2d 00 0.0. .-.
026d0: 20 00 30 00 30 00 30 00 .0.0.0.
026d8: 30 00 30 00 30 00 30 00 0.0.0.0.
026e0: 30 00 37 00 36 00 64 00 0.7.6.d.
026e8: 37 00 39 00 30 00 30 00 7.9.0.0.
026f0: 30 00 3a 00 20 00 43 00 0.:. .C.
026f8: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02700: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02708: 53 00 5c 00 73 00 79 00 S.\.s.y.
02710: 73 00 74 00 65 00 6d 00 s.t.e.m.
02718: 33 00 32 00 5c 00 69 00 3.2.\.i.
02720: 70 00 68 00 6c 00 70 00 p.h.l.p.
02728: 61 00 70 00 69 00 2e 00 a.p.i...
02730: 64 00 6c 00 6c 00 0d 00 d.l.l...
02738: 0a 00 28 00 30 00 30 00 ..(.0.0.
02748: 30 00 30 00 37 00 36 00 0.0.7.6.
02750: 65 00 38 00 30 00 30 00 e.8.0.0.
02758: 30 00 30 00 20 00 2d 00 0.0. .-.
02760: 20 00 30 00 30 00 30 00 .0.0.0.
02768: 30 00 30 00 30 00 30 00 0.0.0.0.
02770: 30 00 37 00 36 00 65 00 0.7.6.e.
02778: 38 00 65 00 30 00 30 00 8.e.0.0.
02780: 30 00 3a 00 20 00 43 00 0.:. .C.
02788: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02790: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02798: 53 00 5c 00 73 00 79 00 S.\.s.y.
027a0: 73 00 74 00 65 00 6d 00 s.t.e.m.
027a8: 33 00 32 00 5c 00 72 00 3.2.\.r.
027b0: 74 00 75 00 74 00 69 00 t.u.t.i.
027b8: 6c 00 73 00 2e 00 64 00 l.s...d.
027c0: 6c 00 6c 00 0d 00 0a 00 l.l.....
027c8: 28 00 30 00 30 00 30 00 (.0.0.0.
027d0: 30 00 30 00 30 00 30 00 0.0.0.0.
027d8: 30 00 37 00 36 00 65 00 0.7.6.e.
027e0: 39 00 30 00 30 00 30 00 9.0.0.0.
027e8: 30 00 20 00 2d 00 20 00 0. .-. .
027f0: 30 00 30 00 30 00 30 00 0.0.0.0.
027f8: 30 00 30 00 30 00 30 00 0.0.0.0.
02800: 37 00 36 00 65 00 61 00 7.6.e.a.
02808: 32 00 30 00 30 00 30 00 2.0.0.0.
02810: 3a 00 20 00 43 00 3a 00 :. .C.:.
02818: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02820: 44 00 4f 00 57 00 53 00 D.O.W.S.
02828: 5c 00 73 00 79 00 73 00 \.s.y.s.
02830: 74 00 65 00 6d 00 33 00 t.e.m.3.
02838: 32 00 5c 00 72 00 61 00 2.\.r.a.
02840: 73 00 6d 00 61 00 6e 00 s.m.a.n.
02848: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
02850: 0d 00 0a 00 28 00 30 00 ....(.0.
02858: 30 00 30 00 30 00 30 00 0.0.0.0.
02860: 30 00 30 00 30 00 37 00 0.0.0.7.
02868: 36 00 65 00 62 00 30 00 6.e.b.0.
02870: 30 00 30 00 30 00 20 00 0.0.0. .
02878: 2d 00 20 00 30 00 30 00 -. .0.0.
02880: 30 00 30 00 30 00 30 00 0.0.0.0.
02888: 30 00 30 00 37 00 36 00 0.0.7.6.
02890: 65 00 64 00 66 00 30 00 e.d.f.0.
02898: 30 00 30 00 3a 00 20 00 0.0.:. .
028a0: 43 00 3a 00 5c 00 57 00 C.:.\.W.
028a8: 49 00 4e 00 44 00 4f 00 I.N.D.O.
028b0: 57 00 53 00 5c 00 73 00 W.S.\.s.
028b8: 79 00 73 00 74 00 65 00 y.s.t.e.
028c0: 6d 00 33 00 32 00 5c 00 m.3.2.\.
028c8: 54 00 41 00 50 00 49 00 T.A.P.I.
028d0: 33 00 32 00 2e 00 64 00 3.2...d.
028d8: 6c 00 6c 00 0d 00 0a 00 l.l.....
028e0: 28 00 30 00 30 00 30 00 (.0.0.0.
028e8: 30 00 30 00 30 00 30 00 0.0.0.0.
028f0: 30 00 37 00 36 00 65 00 0.7.6.e.
028f8: 65 00 30 00 30 00 30 00 e.0.0.0.
02900: 30 00 20 00 2d 00 20 00 0. .-. .
02908: 30 00 30 00 30 00 30 00 0.0.0.0.
02910: 30 00 30 00 30 00 30 00 0.0.0.0.
02918: 37 00 36 00 66 00 31 00 7.6.f.1.
02920: 63 00 30 00 30 00 30 00 c.0.0.0.
02928: 3a 00 20 00 43 00 3a 00 :. .C.:.
02930: 5c 00 57 00 49 00 4e 00 \.W.I.N.
02938: 44 00 4f 00 57 00 53 00 D.O.W.S.
02940: 5c 00 73 00 79 00 73 00 \.s.y.s.
02948: 74 00 65 00 6d 00 33 00 t.e.m.3.
02950: 32 00 5c 00 52 00 41 00 2.\.R.A.
02958: 53 00 41 00 50 00 49 00 S.A.P.I.
02960: 33 00 32 00 2e 00 44 00 3.2...D.
02968: 4c 00 4c 00 0d 00 0a 00 L.L.....
02970: 28 00 30 00 30 00 30 00 (.0.0.0.
02978: 30 00 30 00 30 00 30 00 0.0.0.0.
02980: 30 00 37 00 36 00 66 00 0.7.6.f.
02988: 32 00 30 00 30 00 30 00 2.0.0.0.
02990: 30 00 20 00 2d 00 20 00 0. .-. .
02998: 30 00 30 00 30 00 30 00 0.0.0.0.
029a0: 30 00 30 00 30 00 30 00 0.0.0.0.
029a8: 37 00 36 00 66 00 34 00 7.6.f.4.
029b0: 37 00 30 00 30 00 30 00 7.0.0.0.
029b8: 3a 00 20 00 43 00 3a 00 :. .C.:.
029c0: 5c 00 57 00 49 00 4e 00 \.W.I.N.
029c8: 44 00 4f 00 57 00 53 00 D.O.W.S.
029d0: 5c 00 73 00 79 00 73 00 \.s.y.s.
029d8: 74 00 65 00 6d 00 33 00 t.e.m.3.
029e0: 32 00 5c 00 44 00 4e 00 2.\.D.N.
029e8: 53 00 41 00 50 00 49 00 S.A.P.I.
029f0: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
029f8: 0d 00 0a 00 28 00 30 00 ....(.0.
02a00: 30 00 30 00 30 00 30 00 0.0.0.0.
02a08: 30 00 30 00 30 00 37 00 0.0.0.7.
02a10: 36 00 66 00 63 00 30 00 6.f.c.0.
02a18: 30 00 30 00 30 00 20 00 0.0.0. .
02a20: 2d 00 20 00 30 00 30 00 -. .0.0.
02a28: 30 00 30 00 30 00 30 00 0.0.0.0.
02a30: 30 00 30 00 37 00 36 00 0.0.7.6.
02a38: 66 00 63 00 36 00 30 00 f.c.6.0.
02a40: 30 00 30 00 3a 00 20 00 0.0.:. .
02a48: 43 00 3a 00 5c 00 57 00 C.:.\.W.
02a50: 49 00 4e 00 44 00 4f 00 I.N.D.O.
02a58: 57 00 53 00 5c 00 73 00 W.S.\.s.
02a60: 79 00 73 00 74 00 65 00 y.s.t.e.
02a68: 6d 00 33 00 32 00 5c 00 m.3.2.\.
02a70: 72 00 61 00 73 00 61 00 r.a.s.a.
02a78: 64 00 68 00 6c 00 70 00 d.h.l.p.
02a80: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
02a88: 0d 00 0a 00 28 00 30 00 ....(.0.
02a90: 30 00 30 00 30 00 30 00 0.0.0.0.
02a98: 30 00 30 00 30 00 37 00 0.0.0.7.
02aa0: 36 00 66 00 64 00 30 00 6.f.d.0.
02aa8: 30 00 30 00 30 00 20 00 0.0.0. .
02ab0: 2d 00 20 00 30 00 30 00 -. .0.0.
02ab8: 30 00 30 00 30 00 30 00 0.0.0.0.
02ac0: 30 00 30 00 37 00 37 00 0.0.7.7.
02ac8: 30 00 34 00 66 00 30 00 0.4.f.0.
02ad0: 30 00 30 00 3a 00 20 00 0.0.:. .
02ad8: 43 00 3a 00 5c 00 57 00 C.:.\.W.
02ae0: 49 00 4e 00 44 00 4f 00 I.N.D.O.
02ae8: 57 00 53 00 5c 00 73 00 W.S.\.s.
02af0: 79 00 73 00 74 00 65 00 y.s.t.e.
02af8: 6d 00 33 00 32 00 5c 00 m.3.2.\.
02b00: 43 00 4c 00 42 00 43 00 C.L.B.C.
02b08: 41 00 54 00 51 00 2e 00 A.T.Q...
02b10: 44 00 4c 00 4c 00 0d 00 D.L.L...
02b18: 0a 00 28 00 30 00 30 00 ..(.0.0.
02b20: 30 00 30 00 30 00 30 00 0.0.0.0.
02b28: 30 00 30 00 37 00 37 00 0.0.7.7.
02b30: 30 00 35 00 30 00 30 00 0.5.0.0.
02b38: 30 00 30 00 20 00 2d 00 0.0. .-.
02b40: 20 00 30 00 30 00 30 00 .0.0.0.
02b48: 30 00 30 00 30 00 30 00 0.0.0.0.
02b50: 30 00 37 00 37 00 31 00 0.7.7.1.
02b58: 31 00 35 00 30 00 30 00 1.5.0.0.
02b60: 30 00 3a 00 20 00 43 00 0.:. .C.
02b68: 3a 00 5c 00 57 00 49 00 :.\.W.I.
02b70: 4e 00 44 00 4f 00 57 00 N.D.O.W.
02b78: 53 00 5c 00 73 00 79 00 S.\.s.y.
02b80: 73 00 74 00 65 00 6d 00 s.t.e.m.
02b88: 33 00 32 00 5c 00 43 00 3.2.\.C.
02b90: 4f 00 4d 00 52 00 65 00 O.M.R.e.
02b98: 73 00 2e 00 64 00 6c 00 s...d.l.
02ba0: 6c 00 0d 00 0a 00 28 00 l.....(.
02ba8: 30 00 30 00 30 00 30 00 0.0.0.0.
02bb0: 30 00 30 00 30 00 30 00 0.0.0.0.
02bb8: 37 00 37 00 31 00 32 00 7.7.1.2.
02bc0: 30 00 30 00 30 00 30 00 0.0.0.0.
02bc8: 20 00 2d 00 20 00 30 00 .-. .0.
02bd0: 30 00 30 00 30 00 30 00 0.0.0.0.
02bd8: 30 00 30 00 30 00 37 00 0.0.0.7.
02be0: 37 00 31 00 61 00 62 00 7.1.a.b.
02be8: 30 00 30 00 30 00 3a 00 0.0.0.:.
02bf0: 20 00 43 00 3a 00 5c 00 .C.:.\.
02bf8: 57 00 49 00 4e 00 44 00 W.I.N.D.
02c00: 4f 00 57 00 53 00 5c 00 O.W.S.\.
02c08: 73 00 79 00 73 00 74 00 s.y.s.t.
02c10: 65 00 6d 00 33 00 32 00 e.m.3.2.
02c18: 5c 00 4f 00 4c 00 45 00 \.O.L.E.
I don't want to complain. I just want to give you all the info I can in order to help you figure what is this crush about. I hope I
haven't been misunderstood because of my bad English. I have an asus g2p laptop (core 2 duo t7200 cpu, 2 GB ram at 667mhz, ati
mobility x1700 graphic card with 512mb dedicated memory). I use windows xp 2002 version sp3 and I have had 2 crashes in few days.
Before xp I was using win7 since it was released and I have had 2 crashes in few months. I think I will install win7 again. I
wonder what compatibility problem was the first one I have posted. And if there is a compatibility problem why it has happened only
to me? Maybe you can advise me about installing win7 or not. Thank you.
You have a LOT running whilst using Virtual DJ and have also stated that when Virtual DJ crashed Strong DC exited. Perhaps you should minimize the number of programs you use when using Virtual DJ, especially p2p programs which consume a lot of system time. With your hardware specification you should probably be able to use the highest quality setting with keylock, but your system is too overloaded.
I agree with Andrew...
Why do you need the p2p program running? If you're worried about the odd track that someone may ask for that you haven't got then use NetSearch - or as we used to do "back in the day":
1. Smile and nod
2. Say "Left it at home"
and for 1, when they come back at the end of the night to complain, just say you ran out of time...
Roy
I don't think it's a CPU issue but more linked to what is written above. There is clearly a conflict with VDJ, P2P program and your HDD. So I would say a issue with the flow of data.
Do you use Write-caching on your HD ?
Microsoft wrote :
“Write caching” in a storage device refers to the use of high-speed volatile memory to collect write commands sent to data storage devices and cache them until the slower storage media (either physical disks or low-cost flash memory) can accommodate them. Most devices that use write caching require that power be supplied continuously.
Systems that have write-caching enabled at any point in path between the application and the storage device must be stable and not prone to power loss. When a device attached to a system uses write-caching, the device’s algorithms for caching are designed with the expectation that power will continuously be available to operate both the cache and the movement of the data in and out of the cache. If your system or power source has known issues with sustaining power, you should not use these features.
I counted 19 different icons in the bottom right corner of your taskbar. When I DJ I only have 3... The sound speaker icon, video options icon and network icon (that has been disabled in hardware).
You have yahoo messenger open, firefox on a youtube clip, plus a few other apps running. Im pretty certain you'd be running a virus scanner at this point (which you shouldnt be needing to run while DJing). Maybe even some background file organiser/caching is operating? All that stuff should not even be loaded on a DJ computer.
Ive had only one crash this year and that was my own fault for having the external drive go to sleep while I was DJing from the C Drive (yes I know, big mistake, I had run out room on the external but ive got a bigger drive now and disabled that sleep option!) No crashes last year for the entire year. My DJ laptop has nothing except for XP, VDJ, k-lite codec & the video & sound software. I beleive the biggest mistake people make is they dont realise that a DJ computer should only be used for DJing and nothing else. Install all the other stuff on another computer to do all your Internet and office work.
Hi there and thank you for the answers.
grug wrote :
I counted 19 different icons in the bottom right corner of your taskbar .
Ok guys...the last crush I have had happend when I was at home not on a gig...that explains those programs running. When I go to a gig I close most of that(even wireless adapter)
I agree with you and I hope someday I will have another pc so I can use my laptop only for djing.
I use write cacheing only on the laptop's hdd. External hdd is set to quick removal. And when I am djing I use an UPS for power backup.
I still don't understand what was the compatibility problem that Action center in win7 has reported as I have wrote in my first post. I have to know if that compatibility problem is real before I will install w7 again. Thanks again for your answers. Bye.
Go to control pannels and delete stuff. You dont need all that. A dj laptop is different from a home laptop. The home laptop, you can have a million things running at the same time. The DJ laptop is only for windows OS and a few updates. No lime wire, p2p, No firefox, Aol IM, Etc, etc.. Turn off wireless, turn off bluetooth, Disable the Virus protection,
I agree, have a little as possible running when DJing. I'm using windows 7 and a PC with 3.00Ghz Duo core, 4Gb RAM, 512Mb radeon card and it has been perfect (touch wood) so far. 12 gigs or so without a blip! If you have room you could se it as a dual boot system and have all your AV, P2P stuff on an install of XP/Vista etc. Then so long as you don't conenct to the web you don't even have to run Anti Virus software when DJing as when you boot into the other OS you can run you scans, downloads etc in there.
Cheers, Mark
I can't believe it, if I not see it...
For me it's a combine problem. First I notice... Performance settings on VirtualDJ with a T7200 Intel processor.
Use OVERCLOCK checked and put the performance slider on FASTEST. Anyway without testing, I'm sure your laptop has to be set on 3/4 of total range of performance slider and keep it on the left.
please check all your current running programs, p2p are forbidden while mixing.
I'm using a T7100 Intel Processor based laptop with Windows Vista Business 32 bits and works fine.
I 'm sure you have a configuration problem. Need to tune your computer to perform as best as possible.
77%
