I have 6.0.2 with my database intact....
As many know, I have been using 3.4 for years. I still love it and will still use it out at gigs until I am comfortable with 6.0.2 but....
mp3jrick and cstoll dragged me kicking and screaming into the present day.
Wish me luck on my learning curve.
Thank you mp3jrick and cstoll. It only took 5 years.
geposted Tue 22 Sep 09 @ 9:17 pm
You will not be sorry City, my old friend...
geposted Tue 22 Sep 09 @ 9:26 pm
I loaded 6.0.2 on a brand new system. 3.4 is still on my older system.
geposted Tue 22 Sep 09 @ 9:39 pm
Why I don't get it, why would you use an old version? couldn't you afford the upgrade :)
geposted Wed 23 Sep 09 @ 7:32 am
Well there was some messed up stuff on your system that Chris was finally able to firgure out, but we had 3 guys working on it.
Still waiting on the details, just glad its finally resolved.
geposted Wed 23 Sep 09 @ 7:56 am
Rick, Chris,
Outstanding work. Thanks for hanging in there with me over the years. If your ever in the D.C. area, Look me up and i'll treat you to a beer or two. Or 3 or 4.
Believe it or not, i'm still trying to find out where to put my skins. I think I found where to put effects and samples but if you could clarify this for me...
Also, I have been looking into the NUO 5 mixer but I don't think it's gonna work out for me. What's the word on the nanopad doing what I need it to do?
From another post...
How about the Ecler NUO 5?
Will this work for me? Will it be able to scroll folders and files, load songs, trigger cue points, trigger effects, trigger samples, trigger beatmatch?
That's about all I need a midi mixer to do.
I can get the mixer for $450 including a Road Ready Case but I have to move fast.
If the NUO 5 Won't do this, will the Nanopad?
geposted Wed 23 Sep 09 @ 8:40 am
Everything is now in the My Documets\VirtualDJ folder ... if you read the v5 manual (in the first few pages) it explains where everything now is since v5.
So always look to My Documents\VirtualDJ folder
= Skins
= Effects
= etc.
geposted Wed 23 Sep 09 @ 1:07 pm
Thanks...Ya know, I looked everywhere else but my documents.
Still getting used to the changes from 3.4 to 6
geposted Wed 23 Sep 09 @ 2:19 pm
The v5 manual that should be in the My Documents\VirtualDJ folder should help in the first few pages with the 'big' changes of locations and some of the features.
The v6 manual will just get into just the v6 new features.
geposted Wed 23 Sep 09 @ 4:41 pm
