Okay so I have sucessfully been using Cue ver 5.2.1 Pro with barely a hicup for glitch for almost 2 solid years. Dell Inspiron laptop vista 32 bit, not the fasted but does music very well. I also use the DMC2 controller and the Numark CM200USB mixer. Like I haave said I have been happily using this for a while. I have upgraded to Cue 6 and at first look I am really digging it. Then I am hooking it all up for a test run, and I cannot for the life of me figure out why I cannot get 2 seperate channels to work with the upgrade. i can play from both decks but only comes out one channel.
Sound set up before on same system looked like this...
inputs (none)
Output (External Mixer)
Sound Card (2+usb)
Audio Drivers
first option (Primary sound driver)
second option (usb codec)
Left Deck First card/right deck socond card
Installed version 5.2.1 onto aternative laptop with success and both channels using the same configuration as above, same cords, external drives and all.
Please if you have any insight I am on the verge of pulling out whats left of my hair.
Thanks
Kevin
inputs (none)
Sound Card (2+usb)
Audio Drivers
Thanks
Kevin
geposted Thu 24 Sep 09 @ 11:59 pm
does it give you the asio driver option?
geposted Fri 25 Sep 09 @ 1:34 pm
I had the same problem and found that all I had to do was bring up the volumn on channel 2, and then both channels were fine
geposted Fri 25 Sep 09 @ 5:38 pm
It Does give the option of ASIO driver from the sound card setup. But since I am not using an ASIO device I am not sure why I would select it.
geposted Mon 28 Sep 09 @ 10:36 am
I have experimented with this and so far no luck.
geposted Mon 28 Sep 09 @ 10:38 am
