sorry if I posted in wrong forum
I have the RMX with VDJ 6.0.2
when I hook it up and play with it, I cannot hear anything through my laptop
is there a way to fix that? I dont have a way to hook up external speakers when I am practicing on the RMX
I use headphones, but would prefer sound from the computer speakers
thanks
dj4nse
thanks
dj4nse
geposted Fri 25 Sep 09 @ 4:12 am
It sounds like the config is set up to use the RMX as the sound card.
Go in to Config abd change the sound card from the RMX to your lappy sound card.
Remember you will probably lose the ability to que and mix though, that's what the RMX gives you.
Even if you have a set of PC speakers that have RCA (phono) connection on, you can hook them up to outputs 1 & 2 on the RMX to experience the full benefit.
Cheers,
Roy
Cheers,
Roy
geposted Fri 25 Sep 09 @ 4:33 am
