The picth sliders of my Hercules RMX do sometimes not react to slight changes in the pitch. Usually I do not have a problem with the song that I will mix in, but with the song that is playing, the pitch slider does not react to slight changes of pitch. Only when I make brutal movements on the pitch slider the VDJ software picks it up but then the pitch adjustments are too big. Anybody any idea of how to correct this? It is not related to the -12/+12 settings I use as I have tried bringing it to -6/+6 and the problem remains.
Many thanks,
Johan
Many thanks,
Johan
geposted Sat 26 Sep 09 @ 2:15 am
johan ive had this problem also.if you use sync ive noticed that you have to move slider to mark then you can adjust slider to whateva you want not sure if this is what you mean
geposted Sat 26 Sep 09 @ 5:05 am
I am having the same problem.......irrelevant of the sync button, any suggestions?
geposted Fri 02 Oct 09 @ 10:15 am
You can try mapping the pitch slider as this:
pitch_relative
Hope this helps.
pitch_relative
Hope this helps.
geposted Fri 02 Oct 09 @ 2:40 pm
I will give that a try, thanks.
geposted Fri 02 Oct 09 @ 3:00 pm
