i need to format as im having this weird video issue that some videos are not loading, so im just going to format and reinstall
i have had no issues with vista whatsoever, but i was thinkin of loading on xp to my laptop. This is strictly for DJING.
Would i benefit from XP a lot over vista. Again i never really had issues with vista, but maybe XP would run better?
Thanks.
Thanks.
geposted Sun 27 Sep 09 @ 1:18 am
Can't comment on your video issue :-(. I'm running vista myself on a lappy without issue.
One thing you'll probably notice with XP compared to Vista is resource utilisation! XP isn't as resource-hungry as Vista. Vista just seems to need a lot more than XP to get the same job done! XP is generally regarded as a more stable OS. I personally prefer it to Vista, but I'm gonna wait until Windows 7 is officially supported and move to that. (As Vista is working fine for me at the moment, I don't see it as being worth while going through the pain of moving to XP when a move to Windows 7 is 'round the corner!).
Good luck in whatever you decide...
geposted Sun 27 Sep 09 @ 6:30 am
Thanks.
Thanks.
Good move.!
geposted Sun 27 Sep 09 @ 5:27 pm
bryantpb wrote :
Good move.!
Good move.!
....which one?
Are you recommending he moves to XP or what? Please state your reasons why? Just curious....
geposted Sun 27 Sep 09 @ 8:52 pm
actually im not moving..
i found out that the issue is with cue 6 and not vdj 6
check my vdj 6.0.2 vs cue 6.0.2 thread..
geposted Sun 27 Sep 09 @ 9:07 pm
bryantpb wrote :
Good move.!
Thanks.
Thanks.
Good move.!
Also to each his own!!! If he has a DX10 vid card designed for Vista it may not play nice with XP. Been using Vista for a few years now on a custom built system with little issues and the issues I DID have were rip related.
geposted Mon 28 Sep 09 @ 5:35 am
