I have a question about my PC. I run VDJ on a double-boot system. The PC is HP Pavillion Dual-core 32-bit OS 4GB RAM with a Denon HC-4500. When I run the Vista setup my PC runs with less CPU-usage and the Safe mode and Overclocked is unticked. This is with a resizing cstoll modified skin. The same in XP-mode VDJ uses at least 30% CPU and I have to run it in overclocked mode. Can anyone tell me why? It's working but I'm just curious about why there is a difference. I've been thinking that the XP is not using the dual-core in a efficient way. I'm a right?
geposted Tue 29 Sep 09 @ 11:42 am
Is your dual core a amd by any chance.
If so go to amd webite and download the amd dual core optimizer.
geposted Tue 29 Sep 09 @ 1:42 pm
I'm sorry I should have mentioned that it's an Intel Centrino Duo.
geposted Tue 29 Sep 09 @ 11:42 pm
I see not much i can say about this one then.
geposted Wed 30 Sep 09 @ 3:23 am
I believe Vista uses a different driver for the Audio cards giving it a more direct connection to the software. also it could just be the vista driver is better.
geposted Wed 30 Sep 09 @ 7:00 am
