Hi guys!
I have VDJ 6 and Numark Total Control. In the TotalControl mapper under SCRATCH it says vinyl_mode. Which value do I have to change so the jogwheel is used as a pitchbender and not as a scratch wheel. It's really annoying because the song stopps as soon as you touch the wheel! Can anybody help me? I just want to go into cd mode. What do I do? Thanks for any help!!
Greets
Greets
geposted Tue 29 Sep 09 @ 3:23 pm
Hi alexis,
you have to change your mapper.
I believe something like vinyl_mode='0', but i'm not sure ;-)
Haui
Haui
geposted Wed 30 Sep 09 @ 5:54 am
If the controller has a SCRATCH or WHEEL MODE button, simply press it to toggle scratching on/off. When off, the jogwheel will pitch bend when it's turned instead of scratching.
If it doesn't have a button to toggle scratch, simply assign a keyboard shortcut to toggle this - Go to CONFIG -> Mappers, make sure Keyboard is selected and click + (Add.)
Press an appropriate key, e.g: CTRL+S and then type the following in the action box: vinyl_mode
NOTE: When the song is stopped/paused, VirtualDJ will always scratch for cueing the song up. It does not have a frame cue (Stutter) cueing mode.
geposted Wed 30 Sep 09 @ 12:19 pm
