The software sometimes freezes when i change video transition, the video that is playing keeps playing but
the rest of the software freezes.
It's a problem with the software or the SBDJ square video transition,
i think every time the software froze it was because i wanted to go from the SBDJ square transition to another transition.
Any help would be nice!
Thanks
Xavier
Thanks
Xavier
geposted Tue 29 Sep 09 @ 4:21 pm
I would be surprised if it is a plugin fault by SBDJ (although i am not saying it definately is or not)
I have experienced lots of video problems over the past couple of weeks. Probably where i am using my system a lot more often now. But i can't use Clipbank at all on the Mac side as it constantly locks the software up - although the audio keeps playing, you can't do anything.
I have got so frustrated to point of running Bootcamp now.
I love OSX but VDJ doesnt meet the grade at the moment - in my opinion.
I know that doesnt really help you out directly but it might be worth looking at Bootcamp too??
geposted Tue 29 Sep 09 @ 4:32 pm
No Bootcamp might actually be a solution,
Can you mix videos pefectly with bootcamp? Where do you download it?
Thanks mate!
Xavier
Thanks mate!
Xavier
geposted Wed 30 Sep 09 @ 6:28 am
