Hi just joined and need some advice.
Can someone tell me how to setup and what i need to buy to get deck 1 on one stereo output and deck two on another. I use a laptop that conects to an multi chanel mixer.
Thanks
Mark
Thanks
Mark
geposted Wed 30 Sep 09 @ 4:36 pm
Maya44 USB card should do the trick if you're not going to use timecode etc. Cheap and reliable.
geposted Wed 30 Sep 09 @ 5:05 pm
Almost any usb surroundcard will do.
(if you dont intent to use timecode)
geposted Wed 30 Sep 09 @ 5:28 pm
Thanks, just got Sound Blaster X-Fi should do the trick
geposted Wed 30 Sep 09 @ 5:37 pm
Yap, should work fine .. ;)
SOME soundblasters have a bit weird internal routing of the outputs. Post back if you have any issues.
Easy to fix with a little change in registry.
geposted Wed 30 Sep 09 @ 5:39 pm
Thanks for advice will do
geposted Wed 30 Sep 09 @ 5:42 pm
