Good morning everyone.
Video FX:
In VDJ 6 I have Sonique as the default effect when playing MP3s and also run the SBDJ TextScroller most of the time. I occasionally trigger 'ShowLogo' and now and then use 'SlideShow'. What frustrates (slightly) is that when I trigger one of these Video FX and then go back to Text Scroller I have to reload the Text Scroller file.
Is it possible to keep TextScroller running even if I trigger showlogo or slideshow?
Audio FX
Is it possible to set an Audio FX to always be active unless I deactivate it?
I like to have an EQ plugin running to take the edge of the bass and give me a nicer sound but everytime I load a new track I have to trigger the effect.
Cheers.
Martin
Video FX:
Audio FX
Cheers.
Martin
geposted Thu 01 Oct 09 @ 12:00 am
Video FX:
Should be possible. How are you triggering the effect out of interest? From a skin dropdown box, a shortcut or from the effects browser? Give it a try from the effect browser and see if that works for you.
Audio FX:
In VDJ6: Config -> Options -> FX Reset On Load -> Disabled
In VDJ5 and earlier: Registry Tool -> ClearEffectOnLoad -> Untick
Regards,
Scott
Audio FX:
Regards,
Scott
geposted Thu 01 Oct 09 @ 5:08 am
I want to put text/lyrics on to secondary video screen. I'm not particularly clever with this VDJ (but its great) so is there an easy way ?
geposted Tue 27 Oct 09 @ 1:30 pm
