I'll try my best to describe my problem
I have a Regga Horn in my samples. To activate this i press F7.
If i press F7, the horn plays. If i press F7 real quickly (So the horn makes a short, repative noise) it's a constant loop. Ie, no matter how fast you press F7 you can't get the horn to beep any faster.
Now i have found that if you press SHIFT + F7 (I can only assume this applies to all samples) it's 'Tempory' meaning i can press the buttons as many times as i like and the horn will be super fast. It will blast every time i press it, no matter how fast i do it.
The problem is, i don't want to press SHIFT + F7 to make it blast out as fast as i like, i just want to press F7 and be able to do this (Saving me using 2 fingers)
I hope you understand what i mean, i've tried my best to expalin it clearly.
Many Thanks
Dan
Many Thanks
Dan
geposted Sat 03 Oct 09 @ 6:15 pm
so go into your Keyboard Mapping and copy the mapping from the Shift+F7 entry and replace the F7 mapping with it.
Config -> Mapper -> select Keyboard from the drop-down if it is not already selected.
geposted Sat 03 Oct 09 @ 6:20 pm
I forgot to mention. When i did this it dosn't work, at the same time it playes the 'Sierens' sample as well as the horn, but still dosn't let me press the button as fast as i like. its notmal still if you understand what i mean?
Thanks for the quick reply!
geposted Sat 03 Oct 09 @ 7:19 pm
Hi,
Turn off the beatlock in the sample-field
regards,
John
regards,
John
geposted Sun 04 Oct 09 @ 12:00 am
The beat lock are off on ALL the samples.
I'm still very confused.
Thanks
Dan
Thanks
Dan
geposted Sun 04 Oct 09 @ 6:20 am
