Hi,
Sorry if this is a repost, but I have searched and can't find the answer.
I currently use version 5.2.1 with the Numark DMC-1 (serial controller) with the mod chip. I have loaded version 6 of VDJ, but it wont work with my controller. Is the DMC-1 supported in version 6?
I don't really want to buy another controller as this one seems to meet all my needs.
If it doesn't support this hardware, is there any way that it could be modified using a plugin to enable support?
Many thanks for any advice.
Mark
Mark
geposted Mon 05 Oct 09 @ 5:31 am
Works just dandy. Get the DAC2/DMC1 mapper from hardware tools.
I LOVE mine. BUT, you must have the upgrade chip.
geposted Mon 05 Oct 09 @ 11:48 am
I have a similar issue with my DAC2, but it seems to be a Vsta issue. My DAC2 will not work with VDJ versions 5x or 6x. I am still using 4x on my gig computer. What is this "mod chip" that is mentioned in this post?
geposted Thu 08 Oct 09 @ 1:52 am
Thanks for that.
I take it you are referring to https://virtualdj.com/addons/8495/DAC-2_Mapper.html mapper?
Where do you install the mapper xml file? is it under the mappers directory? Seems like a daft quastion, but just want to make sure!
Thanks again,
Mark
geposted Thu 08 Oct 09 @ 8:17 am
Well, after a lot of messing around I used VDJ 6 over the weekend and all seemed really stable which is good.
Only a couple of small issues : -
1. DMC-1 displays elapsed time, is there a way of changing this to remain?
2. On VDJ 5 I used keyboard mappers so that key "1" would play deck 1 and change the video crossfader to deck 1. It seems that is version 6 one key cannot do 2 actions, is this correct or is there a way round it?
Regards,
Mark
Regards,
Mark
geposted Mon 12 Oct 09 @ 5:53 am
Page the author here and he will help.
I made a couple tweeks myself. But he is the resident authority.
And before you ask... the outer wheel is not mappable yet.
geposted Tue 13 Oct 09 @ 8:42 am
You can sting multiple actions together in VDJ 6 by using &,. e.g:
deck 1 play & video_crossfader 0%
deck 2 play & video_crossfader 100%
See https://virtualdj.com/wiki/VDJscript.html and https://virtualdj.com/wiki/VDJscript_verbs.html for further information.
geposted Tue 13 Oct 09 @ 12:54 pm
Guys,
Thank you so much for the advice, version 6 rocks lol!
I now have all my keyboard shortcuts back and finally a DMC-1 that works to its full potential! Got things lit up on the display I didn't even knew exsited!!!
Thank you from a very hapy customer!
Mark
Mark
geposted Tue 13 Oct 09 @ 2:21 pm
HI this works in 6.0.4
map OUTERWHEEL to this action
param_smaller 0.01 ? seek -64 : param_smaller 0.08 ? seek -32 : param_smaller 0.15 ? seek -16 : param_smaller 0.22 ? seek -8 : param_smaller 0.29 ? seek -4 : param_smaller 0.36 ? seek -2 : param_smaller 0.43 ? seek -1 : param_smaller 0.52 ? seek 0 : param_smaller 0.58 ? seek +1 : param_smaller 0.65 ? seek +2 : param_smaller 0.72 ? seek +4 : param_smaller 0.80 ? seek +8 : param_smaller 0.87 ? seek +16 : param_smaller 0.94 ? seek +32 : param_smaller 1.1 ? seek +64 : nothing
geposted Thu 03 Dec 09 @ 5:53 pm
