can't update properly.......
tried to run updates , there were 6 , 1 installed , other 5 didn't and the help isn't ......i have Vista home premium 64 bit
at the moment the updates are turned completely off .......
Vista SP2 is installed .......
i turned the updates off AFTER it refused to update properly , not b4 ......
geposted Mon 05 Oct 09 @ 11:26 am
Hey mate,
i had a issue, when i install Vista and at the same time (Update) the Internet Explorer8.
After i turn off, the IE8 installation and let the other updates run, all was fine.
You have already installed SP2?
If yes, you can try, to let one by one update run.
good luck mate
Haui
good luck mate
Haui
geposted Mon 05 Oct 09 @ 12:11 pm
Get Windows 7 and don't look back.
geposted Mon 05 Oct 09 @ 6:18 pm
This has always worked for me and doesn't appear to have negative consequences but exercise caution:
- Start 'Task Manager' (ctrl + shift + escape) and click 'Show processes from all users' to elevate permissions.
- Enter the 'Services' tab and locate the service with description 'Windows Update'. Right-click on it and select 'Stop Service'.
- User 'Explorer' to browse to 'C:\Windows\SoftwareDistribution', delete all files in this directory.
- Either start the 'Windows Update' service using 'Task Manager' or restart your computer.
- Run 'Windows Update', it will act as if it's never been run before but will not display already installed updates.
geposted Mon 05 Oct 09 @ 6:53 pm
thanks Andrew , i may have a virus cuz i'm getting error 1791 windows installer not working .........it dl's the updates it doesn't install them ...
geposted Thu 08 Oct 09 @ 1:10 pm
