Hello,
I have been using vdj for over a year now and some of my songs come up blank (track title) . Even if i rename it my right clicking the same happens . How can i fix this ?
geposted Wed 07 Oct 09 @ 6:10 pm
jesse1210 wrote :
Hello,
If you can explain this a little better I may be able to help you. (Even if i rename it my right clicking the same happens.)
Joey....
geposted Wed 07 Oct 09 @ 6:27 pm
The artest shows up but the song title dont . I right click on the song and go to file infos
geposted Wed 07 Oct 09 @ 6:42 pm
Go to the actual song file on the hd and name it artist - title.mp3 (or whatever format it is ur renaming). Then rescan it in vdj to get your bpms and such.
geposted Wed 07 Oct 09 @ 7:02 pm
Hi jesse1210
After you right click the song and click the info option see if underneath the song title field is blank, some times the info is there listed, just to the left corner bottom of the field is a button with an icon like this ^ click on it to update from tag infomation if it's listed in the tag it will pull the info to that field.
Good Luck.
Joey....
Good Luck.
Joey....
geposted Thu 08 Oct 09 @ 12:14 pm
hoily crap it worked ! and i been using it that way for over a year . THANKS !!!!!!!
geposted Fri 09 Oct 09 @ 12:55 am
Hi jesse1210
Glad to hear it worked out for you.
Joey....
Joey....
geposted Fri 09 Oct 09 @ 8:29 am
