Can someone tell me if i can legally install VDJ onto two laptops using the same serail number?
I have VDJ on my gigging Laptop but would like it on my Desktop as well, as it would make life alot easier doing playlists etc.
Thanks for any info/help.
geposted Fri 09 Oct 09 @ 9:20 am
What you are describing is legal. The E.U.L.A. allows installing VDJ on up to two (2) computers.
geposted Fri 09 Oct 09 @ 9:26 am
Super Fast Response thank you.
Thanks for info.
Mark
Thanks for info.
Mark
geposted Fri 09 Oct 09 @ 9:31 am
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix Productions.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
geposted Fri 09 Oct 09 @ 12:24 pm
I see, but I have a question.
What if I installed VDJ on 2 laptops, and I get a new laptop. Can I replace my new laptop with one of the two laptops, without trouble?
Or once I install VDJ on 2 laptops, I can only use those two laptops?
Thanks!
Thanks!
geposted Fri 09 Oct 09 @ 3:29 pm
Have a look to the post from jpboggis.
If you have legal licence, is this the way to be save.
There is all you need ;-)
OLD:
Notebook A = VDJ1
Notebook B = VDJ2
New:
Notebook A = none (deinstalled)
Notebook B = VDJ2
Notebook C = VDJ1
And yes, you can use your licence only on your two Notebook's or PC's.
Not share your licence with friends or so.
See you
Haui
OLD:
Notebook A = VDJ1
Notebook B = VDJ2
New:
Notebook B = VDJ2
Notebook C = VDJ1
See you
Haui
geposted Sat 10 Oct 09 @ 6:50 am
