not sure if thats even the right word but heres my situation, i have a laptop that i use to run vdj on but i have and external monitor when i set vdj on the external monitor everythign is fine except the scroll of the mp3 its choppy,is there a way to adjust this in vdj or would this be purely a hardwaer/software issue
any respnonse is appreciated
geposted Fri 09 Oct 09 @ 5:00 pm
Do you use dual display, ie same picture on all monitors or span across? Is the problem worse when loadind a track?
Daz
Daz
geposted Fri 09 Oct 09 @ 5:13 pm
i tried a lot of setups,i made the external monitor the only monitor cause i figured that would speed it up but no luck,the problem isnt with the mouse or anything but at the top of the screen where u see the visual display of the track scrolls past very choppy,other then that there is no problems with the display
geposted Fri 09 Oct 09 @ 6:34 pm
i has to do with your laptop capabilities. What is the configuration of your laptop CPU,RAM, VGA
geposted Fri 09 Oct 09 @ 6:54 pm
problem solved, i was using the overflow at 1400x 900 and i just found the overflow 1200x800 and its running fine, i needed this new skin because of the scratch function
but im running vista 32 bit on a gateway laptop with a 1.60GHz processor and 1014mb ram,vga im not sure what that is
geposted Fri 09 Oct 09 @ 7:22 pm
You certainly need a better vga card to run a secondary screen. Your laptop configuration doesnt help you. Since you found a better performance with a less resolution skin, this shows that it has to do with video graphics.
geposted Sat 10 Oct 09 @ 6:35 pm
there is a zoom control function a little to the right of the middle top. full zoom control
geposted Thu 19 Nov 09 @ 11:11 am
