Hi,
Can anyone explain to me how save a cue point so that remains even after I've closed virtualDJ and opened it again?
Thanks
Xavier
Thanks
Xavier
geposted Sun 11 Oct 09 @ 4:06 am
as long as u shut down vdj properly it should be saved next time u load it as long as the file is from the same location it was when u added the cuepoints
geposted Thu 15 Oct 09 @ 9:38 pm
I'm having the same problem. Closing the app using Apple Q... Also all of my DB info (BPM n such) goes away as well. I am guessing I am doing something wrong or have not configured the DB properly. I imagine Xavier is having these problems as well. Been reviewing the manual to no avail.
geposted Mon 19 Oct 09 @ 5:19 pm
Pls continue here..
http://www.virtualdj.com/forums/117426/MAC_Version_Technical_Support/How_to_save_Cue_points____SOLVED_.html
It is not necessary to have same thread on different forum. It will create confusion;)
Thread Lock.
Thread Lock.
geposted Tue 20 Oct 09 @ 9:45 am
