Why?
geposted Sun 11 Oct 09 @ 11:59 pm
I think you need a explanation for
Well, the button action works but the image not.
For example:
I have "crossfader_curve 'smooth'" selected - the button is on(selected)
Then I select "crossfader_curve 'cut'" - the "crossfader_curve 'smooth'"button is stil on(selected)
and the "crossfader_curve 'cut'"button still off. But the crossfader is working with the "crossfader_curve 'cut'".
Best regards,
John
Quote :
action="crossfader_curve 'cut'" is not working visually.
For example:
Best regards,
John
geposted Mon 12 Oct 09 @ 11:34 pm
Yes, the team knows, but I do not know if they have a solution
geposted Tue 13 Oct 09 @ 4:39 pm
OK thanks Pasco123.
geposted Tue 13 Oct 09 @ 10:44 pm
